  1. pessoal tenho rb 450g com 4 linhas, estou usando both-addresses soque tem hora nao consigo entrar no email do hotmail e do yahoo e tem horas q entrar normal, alguem ja teve mesmo problema como foi resolveu ??
  2. Olha colega,tbm com o mesmo problema no hotmail,ainda nao consegui resolver!!!
  3. Qual a Ballance que vocês usam, eu uso o PCC e ainda não tive esse problema "pelo menos nas vezes que entro" e nenhum cliente chegou a reclamar nada sobre isso...
  4. /ip firewall mangle
    add action=accept chain=prerouting comment=EXCESSOES disabled=no \
    dst-address-list=loopback in-interface=saida
    add action=accept chain=prerouting comment="" disabled=no dst-address-list=\
    SafeSite in-interface=saida
    add action=accept chain=prerouting comment="" disabled=no dst-port=443 \
    in-interface=saida protocol=tcp
    add action=mark-connection chain=input comment="MARCAR ENTRADAS" disabled=no \
    in-interface=pppoe-wan1 new-connection-mark=ISP1_conn passthrough=yes
    add action=mark-connection chain=input comment="" disabled=no in-interface=\
    pppoe-wan2 new-connection-mark=ISP2_conn passthrough=yes
    pppoe-wan3 new-connection-mark=ISP3_conn passthrough=yes
    pppoe-wan4 new-connection-mark=ISP4_conn passthrough=yes
    add action=mark-routing chain=output comment="MARCAR SAIDAS (LB to SAIDA)" \
    connection-mark=ISP1_conn disabled=no new-routing-mark=to_ISP1 \
    passthrough=yes
    add action=mark-routing chain=output comment="" connection-mark=ISP2_conn \
    disabled=no new-routing-mark=to_ISP2 passthrough=yes
    add action=mark-routing chain=output comment="" connection-mark=ISP3_conn \
    disabled=no new-routing-mark=to_ISP3 passthrough=yes
    add action=mark-routing chain=output comment="" connection-mark=ISP4_conn \
    disabled=no new-routing-mark=to_ISP4 passthrough=yes
    add action=mark-connection chain=prerouting comment=\
    "MARCAR ROUND-ROBIN (8 canais) (ESSE OU O DE BAIXO)" connection-state=\
    new disabled=no dst-address-type=!local in-interface=saida \
    new-connection-mark=ISP2_conn passthrough=yes per-connection-classifier=\
    both-addresses:4/0
    add action=mark-connection chain=prerouting comment="" connection-state=new \
    new-connection-mark=ISP3_conn passthrough=yes per-connection-classifier=\
    both-addresses:4/1
    new-connection-mark=ISP4_conn passthrough=yes per-connection-classifier=\
    both-addresses:4/2
    new-connection-mark=ISP1_conn passthrough=yes per-connection-classifier=\
    both-addresses:4/3
    add action=mark-routing chain=prerouting comment=\
    "MARCAR ROTA SAIDA( RETORNO PACOTE)" connection-mark=ISP1_conn disabled=\
    no in-interface=saida new-routing-mark=to_ISP1 passthrough=yes
    add action=mark-routing chain=prerouting comment="" connection-mark=\
    ISP2_conn disabled=no in-interface=saida new-routing-mark=to_ISP2 \
    passthrough=yes
    ISP3_conn disabled=no in-interface=saida new-routing-mark=to_ISP3 \
    passthrough=yes
    ISP4_conn disabled=no in-interface=saida new-routing-mark=to_ISP4 \
    passthrough=yes
    add action=change-mss chain=forward comment="Mudar MMS - MSN" disabled=no \
    new-mss=1380 out-interface=saida protocol=tcp tcp-flags=syn
    /ip route
    add comment="" disabled=no distance=4 dst-address=0.0.0.0/0 gateway=\
    pppoe-wan1 routing-mark=to_ISP1 scope=30 target-scope=10
    add comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
    pppoe-wan2 routing-mark=to_ISP2 scope=30 target-scope=10
    add comment="" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=\
    pppoe-wan3 routing-mark=to_ISP3 scope=30 target-scope=10
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    pppoe-wan4 routing-mark=to_ISP4 scope=30 target-scope=10
    add check-gateway=ping comment="" disabled=no distance=1 dst-address=\
    0.0.0.0/0 gateway=pppoe-wan3 scope=30 target-scope=10
    add check-gateway=ping comment="" disabled=no distance=2 dst-address=\
    0.0.0.0/0 gateway=pppoe-wan2 scope=30 target-scope=10
    add check-gateway=ping comment="" disabled=no distance=3 dst-address=\
    0.0.0.0/0 gateway=pppoe-wan1 scope=30 target-scope=10
    add check-gateway=ping comment="" disabled=no distance=4 dst-address=\
    0.0.0.0/0 gateway=pppoe-wan4 scope=30 target-scope=10
  5. Citação Postado originalmente por robertopc95 Ver Post
    Você tem que cria uma regra para pode passa por fora qualquer coisa me add
    que conversamos.
    Sds. Anderson souza silva
    Graduando em Redes de Computadores pela Unijorge/Salvador - BA
    Contato: 71 8624 9467 / e-mail: anderson.souza.silva@live.com / Skype: anderson.souza.sillva
  1. Load Balance com problemas atrás do ProxyFull
    Por fredericoafd no fórum Mikrotik
    Respostas: 5
    Último Post: 27-08-2016, 13:13
  2. Problemas com Hotmail e Yahoo!
    Por VNInfo no fórum Redes
    Respostas: 6
    Último Post: 22-12-2011, 07:35
  3. Respostas: 1
    Último Post: 19-06-2009, 21:45
  4. Load Balance com problema cruel
    Por parreira13 no fórum Redes
    Último Post: 23-12-2007, 23:43
  5. Load Balance Com Problemas Em Bancos
    Por klemensonleal no fórum Redes
    Último Post: 31-05-2007, 03:16
