    Padrão Netgear R6300 pode oferecer até 1,3Gbps de transferência.
    Depois da AirFiber vem aí o Netgear R6300, dando-nos uma chance de podemos competir com as teles.
    CARACTERÍSTICAS APLICAÇÕES
    WiFi
    Tecnologia
    Acelerar Série NETGEAR
    Genie ®
    Seguro
    de conexão
    Fácil
    instalação
    ReadySHARE
    acesso USB
    Simultâneo
    Dual Band
    Gigabit
    com fios
    Gigabit
    WiFi
    E-mail, Chat, Surf,
    Vídeo, Música
    On-line
    de jogos
    HD
    streaming
    Multiple HD
    streaming
    N150 Até
    150Mbps †
    http://www.netgear.com/images/wirele...-118-51173.png http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg
    N300 Até
    300Mbps †
    http://www.netgear.com/images/wirele...-218-51174.png http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg
    N600 Até
    300 300 Mbps †
    http://www.netgear.com/images/wirele...-318-51177.png http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg
    N900 Até
    450 450 Mbps †
    http://www.netgear.com/images/wirele...-418-51176.png http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg http://www.netgear.com/images/checkm...ter18-8118.jpg
    AC1750 Até
    450 1300 ‡ Mbps †
    http://www.netgear.com/images/wirele...-518-51175.png http://www.netgear.com/images/checkm...ack18-8137.jpg http://www.netgear.com/images/checkm...ack18-8137.jpg http://www.netgear.com/images/checkm...ack18-8137.jpg http://www.netgear.com/images/checkm...ack18-8137.jpg http://www.netgear.com/images/checkm...ack18-8137.jpg http://www.netgear.com/images/checkm...ack18-8137.jpg http://www.netgear.com/images/checkm...ack18-8137.jpg http://www.netgear.com/images/checkm...ack18-8137.jpg http://www.netgear.com/images/checkm...ack18-8137.jpg http://www.netgear.com/images/checkm...ack18-8137.jpg http://www.netgear.com/images/checkm...ack18-8137.jpg
    • R6300 Router Wi-Fi
    • Cabo Ethernet
    • Guia de instalação rápida
    • Adaptador de alimentação, localizada ao país de venda
    Especificações físicas
    • Dimensões: 205 x 255 x 77 mm (8,07 x 10,04 x 3,03) em
    • Peso: 654g (1,44 lb)
    Padrões
    • Dois (2) portas USB 2.0
    • IEEE ® 802.11 b / g / n de 2,4 GHz
    • IEEE 802.11 a / n / ac 5,0 GHz
    • Cinco (5) 10/100/1000 (1 WAN e 4 LAN) portas Gigabit Ethernet com auto-sensing tecnologia
    Garantia
    • Limitada mínimo garantia de 1 ano ou mais, se previsto em lei. Mais de 90 dias de suporte ao cliente básico. Para garantia e suporte em detalhes sua visita região support.netgear.com .
    Requisitos de Sistema
    • Microsoft ® Windows 7, Vista ® , XP ® de 2000, Mac OS ® , UNIX ® ou Linux ®
    • Microsoft ® Internet Explorer ® 5.0, o Firefox ® 2.0, Safari ® 1.4, ou do Google Chrome ™ 11,0 navegadores ou superior
    • Use laptop com placa de 3x3 Mbps 450 como Centrino ® 6300/5300, ou adaptador 802.11ac 3x3 para o máximo desempenho
    Execução
    • Reforço WiFi com amplificadores de alta potência de rádio
    • Memória: 128 MB de Flash e 128 MB de RAM
    • Avançado da Qualidade de Serviço (QoS)
    • Suporte IPv6 (Internet Protocol Version 6)
    Facilidade de uso
    • NETGEAR Genie ® App-Personal dashboard para monitorar, controlar e reparar sua rede doméstica
    • Push 'N' Conectar usando Wi-Fi Protected Setup ® (WPS) 1
    Segurança
    • Wi-Fi Protected Access ® (WPA/WPA2-PSK)
    • Dupla proteção firewall (SPI e NAT firewall)
    • Denial-of-service (DoS) prevenção de ataques
    May 2010
    Carapicuíba, Brazil, Brazil
    Padrão Re: Netgear R6300 pode oferecer até 1,3Gbps de transferência.
    este netgear me deu a impressão de ser uma coisa mas para ponto de acesso interno ,enquanto o unbt e feito para area externa propria para enlaces .
    sendo assim não vai concorrer direto com o airfiber .
    Jul 2011
    Criciuma/SC
    concordo com naldo vejo este equipamento para uso indoor e nao outdoor seria muita falta de informacao comparar com o equipamento da unbt
    Obrigado por comentar Naldo864, você está totalmente correto com sua afirmação, inicialmente seu uso é em indoor, porém ele trabalha com o novo padrão ac, podendo até comunicar com padrões antériores tais como; a / b / g / n, Não sei se pensam de uma forma positivista como eu de futuramente a Netgear lançar um produtos para uso externo no padrão "ac" em outdoor, para assim podemos passar uma largura de banda maior ao nossos clientes ao pequeno custo! Vi uma matéria no Tecmundo que o lançamento sairá em maio por volta dos U$299,00 que sinal um valor pequenos.
    Mas olha, ele com uma caixa hermética, fazendo pequenos ptp deve ser bom.
    tem que ver o processador e quantidades de pps.
    tálves futuras verções sejãm boas opções como clientes, por agora não vejo vantagem nesse produto, alem da chegada do novo padrão. mas já e um começo.
