Boa noite,
Estou encontrando uma grande dificuldade em configura dois link embratel no cisco 2801, segue a configuracao abaixo que fiz,
onde e q estou errando?, alguem poderia me ajudar?
Agradeço,
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname ERS
boot-start-marker
boot-end-marker
enable secret 5 $1$blQm$LudWIFbANJ/
no aaa new-model
ip cef
ip name-server 8.8.8.8
ip name-server 8.8.4.4
voice-card 0
interface FastEthernet0/0
ip address 189.xxx.xxx.62 255.255.255.240
no ip redirects
no ip mroute-cache
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
no ip address
no ip redirects
no ip mroute-cache
speed 100
full-duplex
interface Serial0/3/0
ip address 200.xxx.xxx.2 255.255.255.252
encapsulation ppp
interface Serial0/3/1
no ip address
shutdown
ip route 0.0.0.0 0.0.0.0 200.xxx.xxx.1
no ip mroute-cache
duplex auto
speed auto
no cdp enable
no ip http server
no ip http secure-server
snmp-server community mac RO
control-plane
line con 0
password 7 114836352341
login
line aux 0
line vty 0 4
password 7 015029346F30F
login
scheduler allocate 20000 1000
end
#########################LOG SERIAL##########################
Serial0/3/0 is up, line protocol is up
Hardware is GT96K Serial
Internet address is 200.xxx.xxx.2/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation PPP, LCP Open
Listen: IPCP, CDPCP, loopback not set
Keepalive set (10 sec)
Last input 06:58:01, output 00:00:02, output hang never
Last clearing of "show interface" counters 06:58:28
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
4961 packets input, 79408 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
4961 packets output, 79374 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 output buffer failures, 0 output buffers swapped out
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Citação
