    Padrão Problemas Hotspot + THUNDER CACHE + cache full
    SENHORES BOA NOITE, GOSTARIA DE UMA AJUDA COM VCS!!!!
    HJ A MINHA ESTRUTURA É A SEGUINTE:
    TENHO UMA RB 750GL PARA LOAD BALANCE, E UMA RB 750 GL PARA O HOTSPOT E THUNDER CACHE COM CACHEFULL..
    O Q OCORRE É Q NÃO CONSIGO MAIS FAZER APARECER A TELA DE USUDINGSARIO E SENHA PARA QUE OS CLIENTES AUTENTIQUEM, FICA O TEMPO TODO ABERTA, SÓ CONSIGO LIMITAR INDO EM IP BINDINGS E AO INVES DE REGULAR DEIXAR COMO BLOQUED. ACONTECE Q AS VEZES EU SAIU PARA FAZER INSTALAÇÕES E PRECISO OU CADASTRAR O EQUIPAMENTO ANTES DE IR AO CLIENTE OU DEIXAR TUDO EM IP BINDINGS!!!!
    UTILIZO MANGLE PARA REDIRECIONAR PARA O CACHE E USAR O CACHE FULL. VOU POSTAR AQUI AS REGRAS PARA VER SE ALGUEM CONSEGUE ME AJUDAR.. DESDE JÁ AGRADEÇO;
    Fazer redirecionamento do ThunderCACHE 7 usando mangle e CACHE FULL
    ###Cria ROTA Thunder
    /ip route add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.0.0.2 routing-mark=Thunder_router scope=30 target-scope=10
    ###Habilita Mascaramento Thunder
    /ip firewall nat add action=masquerade chain=srcnat comment="MASCARAMENTO DO THUNDER CACHE 7" disabled=no src-address=10.0.0.0/30
    ###Redireciona Thunder Via Mangle e Regra Cache Full
    /ip firewall mangle
    add action=mark-routing chain=prerouting comment="REDIRECT THUNDERCACHE" disabled=no dst-address-list=!NO_CACHE dst-port=80 in-interface=!ether2-ThunderCache new-routing-mark=Thunder_router passthrough=no protocol=tcp src-address=192.168.0.0/24
    add action=mark-packet chain=postrouting comment="CACHE FULL THUNDER 7" disabled=no dscp=18 new-packet-mark="cache full" passthrough=yes
    ### Habilita Limite CACHE FULL
    /queue type add kind=pcq name=Thunder pcq-classifier=dst-address pcq-limit=50 pcq-rate=0 pcq-total-limit=5000000 set default-small kind=pfifo name=default-small pfifo-limit=10
    /queue tree add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=20M name="CACHE FULL" packet-mark="cache full" parent=global-out priority=8 queue=Thunder
    Rio de Janeiro - RJ
    Padrão Re: Problemas Hotspot + THUNDER CACHE + cache full
    primeiro amigo utilize letras minusculas, pois assim da impressao que esta gritando
    no forum do thunder existe diversas regras que poderá verificar,
    vai no overnix
