Andei olhando o log do molden, um tompson tg508.ESTAO TENTANDO ACESSAR MINHA REDE USANDO PORTSCAM, GOSTARIA DE SABER COMO ME LIVRAR DISSO, POIS TA APARECENDO ISSO JA FAIS 1 MES.
GOSTARIA DE SABER O SIGNIFICADO DO QUE SUBLINHEI EM VERMELHO.
SAO VARIAS AS VESES E DE IPS DIFERENTES Q VEM ESSES PORTSCAN, COLOQUEI SO ALGUNS.
DESCONFIO Q ALGUEM DENTRO DA REDE TEM ALGUM TROJAN, OU ALGUMA MAQUINA COM VIRUS Q FORNECE O MEU IP AI VARIOS SERVIDORES ZUMBIS PROCURAM ALGUMA PORTA DE ALGUM SERVIÇO ABERTA.
ALGUEM JA PASSOU POR ISSO??
SE ALGUEM SOUBER, FICO AGRADECIDO
[Tue Jun 12 18:17:21 2012]:[FW] **Port Scan Detected** 200.180.4.79 -> 187.55.227.10, deny 200.180.4.79 for 5 mins
[Tue Jun 12 18:27:24 2012]:[FW] **Port Scan Detected** 200.180.4.79 -> 187.55.227.10, deny 200.180.4.79 for 5 mins
[Tue Jun 12 19:06:24 2012]:[FW] **Port Scan Detected** 201.14.187.125 -> 187.55.227.10, deny 201.14.187.125 for 5 mins
[Tue Jun 12 19:12:10 2012]:[FW] **Port Scan Detected** 201.14.187.125 -> 187.55.227.10, deny 201.14.187.125 for 5 mins
[Tue Jun 12 19:35:03 2012]:[FW] **Port Scan Detected** 201.14.187.125 -> 187.55.227.10, deny 201.14.187.125 for 5 mins
[Tue Jun 12 20:17:20 2012]:[POE] Rcv unknown ETHERTYPE_PPPOE_SESSS(64623)
[Tue Jun 12 20:22:56 2012]:[POE] Rcv unknown ETHERTYPE_PPPOE_SESSS(579)
[Tue Jun 12 20:26:47 2012]:[POE] Rcv unknown ETHERTYPE_PPPOE_SESSS(2239)
OBRIGADO A TODOS QUE COLABORAREM
Citação
