    Padrão Squid bloqueando acesso a intranet de uma empresa externa
    O squid esta bloqueando o acesso a intranet de um parceiro.
    se eu digitar no navegador intranet.empresa.com.br aparece a tela solicitando usuario e senha. isso sem passar pelo proxy. seu passar pelo proxy a tela fica em branco.
    não sei oque pode ser e gostaria de ajuda dos colegas.
    segue meu script do squid.
    # WELCOME TO SQUID 3.0.STABLE10
    ################# Autenticação de Usuários ##########################
    #auth_param basic program <uncomment and complete this line>
    #auth_param basic children 5
    #auth_param basic realm Squid proxy-caching web server
    #auth_param basic credentialsttl 2 hours
    #acl password proxy_auth REQUIRED//Qdo for usar a autent. descomentar
    acl localhost src 127.0.0.1/32
    #acl localnet src 10.0.0.0/8 # RFC1918 possible internal network
    #acl localnet src 172.16.0.0/12 # RFC1918 possible internal network
    acl redetoctao src 192.168.0.0/24 # RFC1918 possible internal network
    ##################### Regras ########################################
    acl Safe_ports port 20 # programa oi
    acl SSL_ports port 443 563 # https
    acl Safe_ports port 553 # Autenticacao do outlook
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 8021
    acl Safe_ports port 2121
    acl Safe_ports port 89 # juridico 2ccago
    acl IPliberados src "/etc/squid/regras/IPliberado.txt"
    acl youtube_bloq url_regex -i www.youtube.com
    #acl down_bloq url_regex -i \.zip$ \.rar$ \.pdf$ \.xlx$
    acl libera-msn src "/etc/squid/regras/libera-msn.txt"
    acl libera-youtube src "/etc/squid/regras/libera-youtube.txt"
    acl bloqueados url_regex -i "/etc/squid/regras/bloqueados.txt"
    acl imo url_regex -i imo.im:443
    acl ultrasurf dstdom_regex -i ([0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}($|:.+|/))
    acl msn url_regex -i gateway.dll ADSAdClient31.dll
    acl msn_bloq dstdomain "/etc/squid/regras/msn_bloq.txt"
    acl msn1 url_regex passport.com confi.messenger.msn.com
    acl msn2 req_mime_type -i ^application/x-msn-messenger
    acl CONNECT method CONNECT
    acl bloq_Talk url_regex -i chatenabled.gmail.com
    #acl videos_uol dstdomain tvuol.uol.com.br
    #always_direct allow videos_uol
    http_access deny manager
    http_access deny !Safe_ports
    ####################### Permisões das Regras ########################
    http_access allow IPliberados
    #http_access allow videos_uol
    http_access deny bloqueados
    http_access deny bloq_Talk
    #http_access deny down_bloq
    http_access deny imo
    http_access deny CONNECT ultrasurf
    http_access allow libera-msn
    http_access deny msn !libera-msn
    http_access deny msn_bloq !libera-msn
    http_access deny msn1 !libera-msn
    http_access deny msn2 !libera-msn
    http_access allow libera-youtube
    http_access deny youtube_bloq
    http_access allow redetoctao
    http_access allow localhost
    http_access deny all
    icp_access allow redetoctao
    icp_access deny all
    ############### Endereço do Servidor e Porta para Acesso############
    http_port 192.168.0.246:3128 transparent
    hierarchy_stoplist cgi-bin ?
    ######################## Tamanhos das Cache ########################
    cache_dir ufs /var/cache/squid 2048 16 256
    cache_swap_low 90
    cache_swap_high 95
    ########################### Caminhos dos Logs ######################
    access_log /var/log/squid/access.log squid
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    #######################Controle de Acessos #########################
    refresh_pattern (cgi-bin|\?) 0 0% 0
    refresh_pattern . 0 20% 4320
    icp_port 3230
    coredump_dir /var/cache/squid
    Padrão Re: Squid bloqueando acesso a intranet de uma empresa externa
    a intranet tem porta?
    Consegui resolve com esta regra no firewall
    $IPTABLES -t nat -I PREROUTING -s 192.168.0.0/24 -d intranet.opusxxxxxx.com.br -p tcp --dport 80 -j ACCEPT
    Já solicionou esse problema?
    Citação Postado originalmente por andrecharamos Ver Post
    icp_access deny all
    cache_swap_low 90
    cache_swap_high 95
    icp_port 3230
