Pessoal, tenho a seguinte topologia:
Não tenho problemas aparentes, mas recentemente estava cá mexendo com o tcpdump e observei as seguntes saídas na interface wan da máquina que roda o Asterisk:
tcpdump -n -i eth0
10:21:08.001839 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.043776 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.085721 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.127651 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.169588 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.211525 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.253462 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.295412 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.337337 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.379273 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.421210 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.463147 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.505086 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.547022 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.588960 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.630897 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.672834 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.714771 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.756708 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.798646 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.840582 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.882519 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.924460 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
10:21:08.966394 48:9c:fe:e6:39:67 > 01:80:c2:00:00:01, ethertype MPCP (0x8808), length 60: MPCP, Opcode Pause, length 46
Esse bolo de coisas aparecem continuamente, o tempo inteiro. E isso tudo é de apenas 01 segundo.
Já na outra máquina, a que tem o proxy, o tcpdump não captura esse tipo de pacote.
Salvei esses pacotes em arquivo e abri no wireshark e o único detalhe a mais era a descrição do STP como Spanning-tree Protocol.
Procurando no google encontrei poucas informações a respeito, falando que o Opcode Pause seria uma flag do protocolo STP normalmente utilizado em switches e mesmo assim quando se trabalha com redundância entre eles. Serviria para inibir o trafego nas porta redundantes enquanto a porta principal estivesse ativa.
Foi isso que entendi sobre esse pacote.
Sobre o MAC de destino, seria um endereço multicast para onde o pacote é despachado, o que "justificaria" a captura desse pacote em todas as portas do switch wan.
Sobre o MAC de origem, não identifiquei ainda. Não sei se é do switch wan ou do roteador, pois com certeza não são das duas máquinas linux.
O Switch WAN é gerenciavel, um antiguinho intel 460T.
No momento a rede se comporta bem, navegante e downloads/uploads estão dentro dos limites do link de internet.
Minhas dúvidas:
- O que seriam realmente esses pacotes capturados pela interface wan da máquina que roda asterisk?
- Porque esses pacotes não são capturados pela interface wan da máquina que tem o proxy?
- O volume desses pacotes não é exageradamente alto? Não estariam consumindo recursos do switch?
- É possível detalhar melhor a captura dos pacotes com o tcpdump ao invés de utiilizar o wireshark para isso?
Agradeço e aguardo a ajuda da comunidade!
