    Padrão DNS Reverso Fedora 17
    Estou tentando configurar o bind no fedora 17, porém estou enfrentando problema na resolução de endereço reverso.
    seguem meus arquivos.
    Meu /etc/named.conf:
    // named.conf
    // Provided by Red Hat bind package to configure the ISC BIND named(8) DNS
    // server as a caching only nameserver (as a localhost DNS resolver only).
    // See /usr/share/doc/bind*/sample/ for example named configuration files.
    options {
    listen-on port 53 { 127.0.0.1; 189.50.0.106; };
    listen-on-v6 port 53 { ::1; };
    directory "/var/named";
    dump-file "/var/named/data/cache_dump.db";
    statistics-file "/var/named/data/named_stats.txt";
    memstatistics-file "/var/named/data/named_mem_stats.txt";
    allow-query { localhost; 189.50.0.106; };
    recursion yes;
    dnssec-enable yes;
    dnssec-validation yes;
    dnssec-lookaside auto;
    /* Path to ISC DLV key */
    bindkeys-file "/etc/named.iscdlv.key";
    managed-keys-directory "/var/named/dynamic";
    zone "tcc.teste" IN {
    type master;
    file "tcc.teste";
    zone "0.50.189.in-addr.arpa" IN {
    type master;
    file "189.50.0.db";
    allow-update { none; };
    logging {
    channel default_debug {
    file "data/named.run";
    severity dynamic;
    zone "." IN {
    type hint;
    file "named.ca";
    include "/etc/named.rfc1912.zones";
    include "/etc/named.root.key";
    meu arquivo /var/named/tcc.teste:
    ; Zone file for dominio.com.br
    $TTL 86400
    @ IN SOA localhost.tcc.teste. localhost.tcc.teste. (
    2012010100 ; serial
    7200 ; refresh
    1800 ; retry
    1209600 ; expire
    300 ) ; minimum
    NS localhost
    TXT "v=spf1 mx -all"
    HINFO PC-Intel-2.4GHz "Linux 2.6"
    A 189.50.0.106
    localhost A 189.50.0.106
    ifes A 189.50.0.106
    www CNAME @
    _ldap._tcp.tcc.teste. SRV 0 0 389 ifes.tcc.teste.
    _kerberos._tcp.tcc.teste. SRV 0 0 88 ifes.tcc.teste.
    ftp CNAME www
    meu arquivo /var/named/189.50.0.db :
    ; Reverse zone file for dominio.com.br
    $ORIGIN 0.50.189.in-addr.arpa.
    $TTL 86400
    @ IN SOA tcc.teste. localhost.tcc.teste. (
    2012010100 ; serial
    7200 ; refresh
    1800 ; retry
    1209600 ; expire
    300 ) ; minimum
    @ IN NS tcc.teste.
    1 PTR tcc.teste
    vejam os resultados da utilização do comando nslookup
    nslookup ifes.tcc.teste
    Server: 189.50.0.106
    Address: 189.50.0.106#53
    nslookup 189.50.0.106
    ** server can't find 106.0.50.189.in-addr.arpa.: NXDOMAIN
    Os testes nslookup foram realizados na mesma máquina que está configurada o bind.
    Alguém tem alguma dica sobre esse problema? pois eu sigo a risca os tutorais.
    Att
    Padrão Re: DNS Reverso Fedora 17
    Quem fornece os IPs para vcs fez a delegação do range para que vc possa fazer as configurações do reverso em seu DNS?
    Perdão,
    Acho que não entendi a sua pergunta.
    Eu possui esse endereço (189.50.0.106) configurado na mesma máquina onde configurei o DNS, e estou fazendo os testes de
    nslookup na mesma máquina.
    Existe algo que deve ser feito além do habitual?
    Att,
    Você não vai conseguir definir o reverso deste IP, se a zona 0.50.189.in-addr.arpa não for delegada a você. Ou te delegam a zona, ou o fornecedor (seu provedor) do IP deve cadastrar o reverso.
    Como pode ser visto no whois, esse ip faz parte de um /20 da empresa Viprede. Ou eles cadastrarm o reverso ou eles delegam a zona.
    Código :
    [email protected]:~$ whois 189.50.0.106
    % Joint Whois - whois.lacnic.net
    %  This server accepts single ASN, IPv4 or IPv6 queries
    % Brazilian resource: whois.registro.br
    % Copyright (c) Nic.br
    %  The use of the data below is only permitted as described in
    %  full by the terms of use (http://registro.br/termo/en.html),
    %  being prohibited its distribution, comercialization or
    %  reproduction, in particular, to use it for advertising or
    %  any similar purpose.
    %  2012-12-13 10:44:44 (BRST -02:00)
    inetnum:     189.50.0/20
    aut-num:     AS28323
    abuse-c:     GKNFE
    owner:       VIPRede Telecomunica��es Ltda
    ownerid:     005.805.349/0001-14
    responsible: Giuseppe Kenji Nagatani Feitoza
    country:     BR
    owner-c:     GKNFE
    tech-c:      GKNFE
    inetrev:     189.50.0/24
    nserver:     ns.viprede.com.br
    nsstat:      20121208 AA
    nslastaa:    20121208
    nserver:     ns2.viprede.com.br
    nsstat:      20121208 AA
    nslastaa:    20121208
    created:     20070716
    changed:     20070716
    nic-hdl-br:  GKNFE
    person:      Giuseppe Kenji Nagatani Feitoza
    e-mail:      [email protected]
    created:     20070226
    changed:     20120210
    % Security and mail abuse issues should also be addressed to
    % cert.br, http://www.cert.br/, respectivelly to [email protected]
    % and [email protected]
    % whois.registro.br accepts only direct match queries. Types
    % of queries are: domain (.br), ticket, provider, ID, CIDR
    % block, IP and ASN.
    [COLOR=#3E3E3E][/COLOR]
    De uma lida em documentos sobre DNS para entender melhor
    Entendo,
    Porém, se eu configuro um servidor DNS em uma máquina e altero o /etc/resolv.conf para que o
    servidor DNS seja ele mesmo, e faço o teste de nslookup, dig, host na mesma máquina, em nenhum
    momento uma requisição sai para "fora" do computador, tudo está sendo tratado localmente, não?
    Tanto é que eu consigo resolver o nome sem problema.
    A grande questão é o endereço reverso.
    Se vc quer resolver apenas internamente tudo bem, ai teoricamente funciona, mas no seu arquivo 189.50.0.db, não tem o .106, apenas o .1 (segundo o que vc colou anteriormente).
    Ok
    Obrigado, vou verificar isso.
    Att,
