    Padrão Trafego por portas.
    Pessoal, tenho uma rb 1100x2 autenticando 140 users via pppoe com planos de 1,2 e 3mb, nela chega 35mb adsl e 5mb dedicado, fiz um balance de portas, deixei a porta 80 para o adsl, e as seguintes portas para o dedicado,
    /ip firewall mangle
    add action=mark-routing chain=prerouting comment="Porta 80" disabled=no \
    dst-port=80 new-routing-mark=Adsl passthrough=yes protocol=tcp
    add action=mark-routing chain=prerouting comment="Porta 443" disabled=no \
    dst-port=443 new-routing-mark="Link Dedicado" passthrough=yes protocol=tcp
    add action=mark-routing chain=prerouting comment="Porta 21" disabled=no \
    dst-port=21 new-routing-mark="Link Dedicado" passthrough=yes protocol=tcp
    add action=mark-routing chain=prerouting comment="Porta 22" disabled=no \
    dst-port=22 new-routing-mark="Link Dedicado" passthrough=yes protocol=tcp
    add action=mark-routing chain=prerouting comment="Porta 23" disabled=no \
    dst-port=23 new-routing-mark="Link Dedicado" passthrough=yes protocol=tcp
    add action=mark-routing chain=prerouting comment="Porta 25" disabled=no \
    dst-port=25 new-routing-mark="Link Dedicado" passthrough=yes protocol=tcp
    add action=mark-routing chain=prerouting comment="Porta 110" disabled=no \
    dst-port=110 new-routing-mark="Link Dedicado" passthrough=yes protocol=tcp
    add action=mark-routing chain=prerouting comment="Porta 1080" disabled=no \
    dst-port=1080 new-routing-mark="Link Dedicado" passthrough=yes protocol=tcp
    add action=mark-routing chain=prerouting comment=P2P disabled=no \
    new-routing-mark="Link Dedicado" p2p=all-p2p passthrough=yes protocol=tcp
    /ip route
    add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ip valido \
    routing-mark="Link Dedicado" scope=30 target-scope=10
    add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 \
    routing-mark=Adsl scope=30 target-scope=10
    O problema e que de acordo o com print abaixo, tem muitas portas saindo pelo adsl, alguem pode me ajudar a fazer uma regra para sair somente a porta 80 pelo adsl e todo o restante pelos 5mb dedicado? se alguem tiver uma ideia melhor, por favor, me de uma luz.
    12:34:44 firewall,info forward: in:<[email protected]> outppoe-out1
    , proto TCP (SYN), 172.16.10.68:8757->91.193.230.28:16435, len 52
    12:34:45 firewall,info forward: in:<[email protected]> outppoe-out1
    , proto TCP (SYN), 172.16.10.68:8753->91.226.139.80:56992, len 52
    , proto TCP (SYN), 172.16.10.68:8754->91.194.191.221:19102, len 52
    12:34:46 firewall,info forward: in:<[email protected]> outppoe-out1
    , proto UDP, 172.16.10.68:40913->91.226.139.80:56992, len 58
    , proto UDP, 172.16.10.68:40913->91.194.191.221:19102, len 58
    , proto UDP, 172.16.10.68:40913->188.234.48.22:46803, len 95
    , proto UDP, 172.16.10.68:40913->88.141.250.89:34924, len 95
    , proto UDP, 172.16.10.68:40913->31.129.53.202:35691, len 95
    , proto UDP, 172.16.10.68:40913->187.80.65.175:45237, len 95
    , proto UDP, 172.16.10.68:40913->88.250.108.170:32707, len 95
    , proto TCP (SYN), 172.16.10.68:8740->115.222.240.209:47909, len 48
    , proto TCP (SYN), 172.16.10.68:8742->37.113.100.113:20282, len 48
    , proto TCP (SYN), 172.16.10.68:8758->92.133.16.12:38389, len 52
    , proto TCP (SYN), 172.16.10.68:8759->85.157.224.185:64686, len 52
    , proto TCP (SYN), 172.16.10.68:8760->79.115.91.199:56706, len 52
    , proto UDP, 172.16.10.68:40913->91.135.198.42:56130, len 58
    , proto TCP (SYN), 172.16.10.68:8761->91.135.198.42:56130, len 52
    Vlw.
    Padrão Re: Trafego por portas.
    Vc pode criar uma regra dizendo que Dst-port=!80 "not" marca rota para o Dedicado, ou seja qualquer porta que não seja a porta 80 recebera aquela marca de rota Dedicado.
    bom espero ter ajudado ....
    consegui fazer uma regra melhor, tudo com destino a porta 80 vai para o dedicado, criei uma adress list com varios ips do youtube, joguei tudo que estiver na adrres list para o adsl, assim os videos do yotube nao irao pesar o dedicado, agora so preciso descobrir quais site da porta 80 estao consumindo mais link para jogar na adrs list, pensei em tirar o baixaki, netfix ou algum outro de filmes online, mas a duvida é: como saber quais sites consomen muita banda? alguem sabe alguma regra? Desde ja agradeço. Vlw.
