  1. Bom dia,
    Utilizo o Zimbra 8 e nessa versão não encontrei o local para colocar os emails para passar por fora de listas RBL ( sorbes.net)
    Alguém poderia me da uma luz??
    Desde já agradeço
  2. Consegui resolver o problema caso alguem tenha interesse segue abaixo
    Postfix whitelist when using RBL's
    If you are using RBLs (such as zen.spamhaus.org) to block spam, the whitelist method above does not work, because it is for spamassasin not postfix.
    Postfix will check incoming messages against the RBL first, and allow/reject accordingly. So if you have a sender listed on a RBL, you need to whitelist them in Postfix.
    To do this in Zimbra: {commands in italics}
    Login and change to zimbra user
    vi /opt/zimbra/conf/postfix_rbl_override
    list all IP addresses or host names (one per line!) that you want to whitelist:
    1.2.3.4 OK 1.2.3.5 OK mail.freemailer.tld OK postmap /opt/zimbra/conf/postfix_rbl_override
    vi /opt/zimbra/conf/zmconfigd /postfix_recipient_restrictions.cf
    under: reject_unauth_destination
    add: check_client_access hash:/opt/zimbra/conf/postfix_rbl_override
    e.g.:
    reject_unauth_destination check_client_access hash:/opt/zimbra/conf/postfix_rbl_override reject_unlisted_recipient zmmtactl restart
    Each time you add a new one, you need to do the postmap command then zmmtactl restart (Also, this may be removed after a Zimbra upgrade)
  3. Magnorm, obrigado pela dica, aqui também funcionou!
