    Avatar de awmoreira
    Aug 2013
    Angra dos Reis, Rio de Janeiro, Brazil, Brazil
    Cool Minha chamada não sai! (Freepx + Asterisk)
    Executing [[email protected]:19] ExecIf("SIP/6600-00000034", "1?Set(CONNECTEDLINE(num,i)=26881847)") in new stack
    -- Executing [[email protected]:20] ExecIf("SIP/6600-00000034", "1?Set(CONNECTEDLINE(name,i)=CID:11328005)") in new stack
    -- Executing [[email protected]:21] GotoIf("SIP/6600-00000034", "0?customtrunk") in new stack
    -- Executing [[email protected]:22] Dial("SIP/6600-00000034", "SIP/voipxxxxx/26881847,300,") in new stack
    == Using SIP RTP TOS bits 184
    == Using SIP RTP CoS mark 5
    -- Called SIP/voipxxxxx/26881847
    > doing dnsmgr_lookup for 'xxxxx-rj.br'
    -- SIP/voipxxxxx-00000035 is circuit-busy
    == Everyone is busy/congested at this time (1:0/1/0)
    -- Executing [[email protected]:23] NoOp("SIP/6600-00000034", "Dial failed for some reason with DIALSTATUS = CONGESTION and HANGUPCAUSE = 0") in new stack
    -- Executing [[email protected]:24] Goto("SIP/6600-00000034", "s-CONGESTION,1") in new stack
    -- Goto (macro-dialout-trunk,s-CONGESTION,1)
    -- Executing [[email protected]:1] Set("SIP/6600-00000034", "RC=0") in new stack
    -- Executing [[email protected]:2] Goto("SIP/6600-00000034", "0,1") in new stack
    -- Goto (macro-dialout-trunk,0,1)
    -- Executing [[email protected]:1] Goto("SIP/6600-00000034", "continue,1") in new stack
    -- Goto (macro-dialout-trunk,continue,1)
    -- Executing [[email protected]:1] GotoIf("SIP/6600-00000034", "1?noreport") in new stack
    -- Goto (macro-dialout-trunk,continue,3)
    -- Executing [[email protected]:3] NoOp("SIP/6600-00000034", "TRUNK Dial failed due to CONGESTION HANGUPCAUSE: 0 - failing through to other trunks") in new stack
    -- Executing [[email protected]:4] Set("SIP/6600-00000034", "CALLERID(number)=6600") in new stack
    -- Executing [[email protected]:6] Macro("SIP/6600-00000034", "outisbusy,") in new stack
    -- Executing [[email protected]:1] Progress("SIP/6600-00000034", "") in new stack
    -- Executing [[email protected]:2] Playback("SIP/6600-00000034", "all-circuits-busy-now,noanswer") in new stack
    -- <SIP/6600-00000034> Playing 'all-circuits-busy-now.gsm' (language 'en')
    -- Executing [[email protected]:3] Playback("SIP/6600-00000034", "pls-try-call-later,noanswer") in new stack
    -- <SIP/6600-00000034> Playing 'pls-try-call-later.gsm' (language 'en')
    -- Executing [[email protected]:4] Macro("SIP/6600-00000034", "hangupcall") in new stack
    -- Executing [[email protected]:1] GotoIf("SIP/6600-00000034", "1?theend") in new stack
    -- Goto (macro-hangupcall,s,3)
    -- Executing [[email protected]:3] Hangup("SIP/6600-00000034", "") in new stack
    == Spawn extension (macro-hangupcall, s, 3) exited non-zero on 'SIP/6600-00000034' in macro 'hangupcall'
    == Spawn extension (macro-outisbusy, s, 4) exited non-zero on 'SIP/6600-00000034' in macro 'outisbusy'
    == Spawn extension (from-internal, 726881847, 6) exited non-zero on 'SIP/6600-00000034'
    -- Executing [[email protected]:1] Hangup("SIP/6600-00000034", "") in new stack
    == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/6600-00000034'
    Estou aprendendo e implantando ao mesmo tempo.
    Ficaria muito grato se alguém me ajudasse. Abraços!
    Padrão Re: Minha chamada não sai! (Freepx + Asterisk)
    Citação Postado originalmente por awmoreira Ver Post
    que tipo de tronco voce esta usando?
    Avatar de awmoreira
    Aug 2013
    O tronco é SIP. Eu consegui!!!! Parece que o módulo SIP Settings que eu instalei estava dando algum conflito, pois depois que tirei funfo.
    Vlw gente!
