Olá amigos do underlinux, venho aqui pedir a ajudar de vcs.
Tenho 3 LoadBalance na minha rede
1 Load Balance: 3 ADSL RB750g
2 Load Balance: 4 ADSL RB1100
3 Load Balance: É a entradas dos 2 link RB750g, RB1100
Bem coloco o script pra rodar no 1 load balance, roda perfeito, porem quando ele muda de ip ele ja pega o ip da rede 2 Load Balance, sendo q quando ele muda de ip nao consigo mais acessar o load balance 1 e sim o load balance 2 e assim vice verso.
Como posso fazer para que o script rodando em apenas um load balance, pode me dar acesso a toda rede tanto um como o outro mesmo mudando o ip.
# Dynamic DNS Update / Simple Edition
# Written by Sam Norris, ChangeIP.com
# Copyright ChangeIP.com 2009-2010
# For support send mail to Support@ChangeIP.com
# 2009-06-22 RouterOS 3.25 Tested
# 2009-10-05 RouterOS 4.01rc1 Tested
# OVERVIEW: %
# This script will update a ChangeIP.com dynamic dns hostname
# with an ip address located directly on an interface.
# NOTES: %
# IF THIS SCRIPT DOES NOT PRODUCE ANY OUTPUT PLEASE COPY AND PASTE IT
# AGAIN. THERE PROBABLY IS A LINE BREAK IN THE WRONG PLACE! Once you
# have created this script and tested that it works by running it
# manually you can schedule it to run every few minutes.
# CONFIGURATION FIELD DEFINITIONS:
# ddnsuser: Enter your ChangeIP.com user id.
# ddnspass: Enter your ChangeIP.com password.
# ddnshost: Enter the hostname (www.example.com) to update.
# ddnsinterface: Enter an interface name - case sensative.
# EDIT YOUR DETAILS / CONFIGURATION HERE
:global ddnsuser ""
:global ddnspass ""
:global ddnshost ""
:global ddnsinterface "pppoe-out1"
# END OF USER DEFINED CONFIGURATION
:global ddnssystem ("mt-" . [/system package get [/system package find name=system] version] )
:global ddnsip [ /ip address get [/ip address find interface=$ddnsinterface] address ]
:global ddnslastip
:if ([:len [/interface find name=$ddnsinterface]] = 0 ) do={ :log info "DDNS: No interface named $ddnsinterface, please check configuration." }
:if ([ :typeof $ddnslastip ] = "nothing" ) do={ :global ddnslastip 0.0.0.0/0 }
:if ([ :typeof $ddnsip ] = "nothing" ) do={
:log info ("DDNS: No ip address present on " . $ddnsinterface . ", please check.")
} else={
:if ($ddnsip != $ddnslastip) do={
:log info "DDNS: Sending UPDATE!"
:log info [ut [/tool dns-update name=$ddnshost address=[
ick $ddnsip 0 [:find $ddnsip "/"] ] key-name=$ddnsuser key=$ddnspass ] ]
:global ddnslastip $ddnsip
} else={
:log info "DDNS: No changes necessary."
# END OF SCRIPT
