| Requirement |
Cisco Command |
| Set a console password to cisco |
Router(config)#line con 0
Router(config-line)#login
Router(config-line)#password cisco |
| Set a telnet password |
Router(config)#line vty 0 4
| Stop console timing out |
Router(config-line)#exec-timeout 0 0 |
| Set the enable password to cisco |
Router(config)#enable password cisco |
Set the enable secret password to peter. This password overrides the enable password
and is encypted within the config file |
Router(config)#enable secret peter |
| Enable an interface |
Router(config-if)#no shutdown |
| To disable an interface |
Router(config-if)#shutdown |
| Set the clock rate for a router with a DCE cable to 64K |
Router(config-if)clock rate 64000 |
| Set a logical bandwidth assignment of 64K to the serial interface |
Router(config-if)bandwidth 64
Note that the zeroes are not missing |
| To add an IP address to a interface |
Router(config-if)#ip addr 10.1.1.1 255.255.255.0 |
| To enable RIP on all 172.16.x.y interfaces |
Router(config)#router rip
Router(config-router)#network 172.16.0.0 |
| Disable RIP |
Router(config)#no router rip |
| To enable IRGP with a AS of 200, to all interfaces |
Router(config)#router igrp 200
| Disable IGRP |
Router(config)#no router igrp 200 |
| Static route the remote network is 172.16.1.0, with a mask of 255.255.255.0, the next hop is 172.16.2.1, at a cost of 5 hops |
Router(config)#ip route 172.16.1.0 255.255.255.0 172.16.2.1 5 |
| Disable CDP for the whole router |
Router(config)#no cdp run |
| Enable CDP for he whole router |
Router(config)#cdp run |
| Disable CDP on an interface |
Router(config-if)#no cdp enable |
