  1. Boa tarde,
    Pessoal a GVT não quer mais Fazer upgrade aqui na região mais está vendendo links de 100mb ai me patrão comprou 300mb 3x100mb. Como posso fazer para subir meu bgp pelos 3?
  2. Configuração
    No Router A:
    # loopback interface
    /interface bridge add name=lobridge
    # addresses
    /ip address add address=1.1.1.1/24 interface=ether1
    /ip address add address=2.2.2.1/24 interface=ether2
    /ip address add address=3.3.3.1/24 interface=ether3
    /ip address add address=9.9.9.1/32 interface=lobridge
    # ECMP route to peer's loopback
    /ip route add dst-address=9.9.9.2/32 gateway=1.1.1.2,2.2.2.2,3.3.3.2
    # BGP
    /routing bgp instance set default as=65000
    /routing bgp add name=peer1 remote-address=9.9.9.2 remote-as=65000 update-source=lobridge
    No Router B:
    # addresses
    /ip address add address=1.1.1.2/24 interface=ether1
    /ip address add address=2.2.2.2/24 interface=ether2
    /ip address add address=3.3.3.2/24 interface=ether3
    /ip address add address=9.9.9.2/32 interface=lobridge
    /ip route add dst-address=9.9.9.1/32 gateway=1.1.1.1,2.2.2.1,3.3.3.1
    # BGP
    /routing bgp add name=peer1 remote-address=9.9.9.1 remote-as=65000 update-source=lobridge
    # a route to advertise
    /routing bgp network add network=4.4.4.0/24
    Resultados
    Checke esta BGP connection se esta estabelicida:
    [filipe@B] > /routing bgp peer print status
    Flags: X - disabled
    0 name="peer1" instance=default remote-address=9.9.9.1 remote-as=65000
    tcp-md5-key="" nexthop-choice=default multihop=no route-reflect=no hold-time=3m
    ttl=255 in-filter="" out-filter="" address-families=ip
    update-source=lobridge default-originate=no remote-id=1.1.1.1
    local-address=9.9.9.2 uptime=28s prefix-count=0 updates-sent=1
    updates-received=0 withdrawn-sent=0 withdrawn-received=0 remote-hold-time=3m
    used-hold-time=3m used-keepalive-time=1m refresh-capability=yes
    as4-capability=yes state=established
    Route table no Router A:
    [filipe@A] > /ip route print
    Flags: X - disabled, A - active, D - dynamic,
    C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
    B - blackhole, U - unreachable, P - prohibit
    # DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTER...
    0 ADC 1.1.1.0/24 1.1.1.1 0 ether1
    1 ADC 2.2.2.0/24 2.2.2.1 0 ether2
    2 ADC 3.3.3.0/24 3.3.3.1 0 ether3
    3 ADb 4.4.4.0/24 r 9.9.9.2 200 ether1
    ether2
    4 ADC 9.9.9.1/32 9.9.9.1 0 lobridge
    5 A S 9.9.9.2/32 r 1.1.1.2 1 ether1
    r 2.2.2.2 ether2
    r 3.3.3.2 ether3
    [filipe@A] > /ip route print detail
    0 ADC dst-address=1.1.1.0/24 pref-src=1.1.1.1 interface=ether1 distance=0 scope=10
    1 ADC dst-address=2.2.2.0/24 pref-src=2.2.2.1 interface=ether2 distance=0 scope=10
    2 ADC dst-address=3.3.3.0/24 pref-src=3.3.3.1 interface=ether3 distance=0 scope=10
    3 ADb dst-address=4.4.4.0/24 gateway=9.9.9.2 interface=ether1,ether2,ether3
    gateway-state=recursive distance=200 scope=40 target-scope=30
    bgp-local-pref=100 bgp-origin=igp received-from=9.9.9.2
    4 ADC dst-address=9.9.9.1/32 pref-src=9.9.9.1 interface=lobridge distance=0 scope=10
    5 A S dst-address=9.9.9.2/32 gateway=1.1.1.2,2.2.2.2,3.3.3.2 interface=ether1,ether2,ether3
    gateway-state=reachable,reachable distance=1 scope=30 target-scope=10
    a routa 4.4.4.0./24 esta instalada em Linux kernel agora com tres nexthops: 1.1.1.2 (on ether1) ,
    2.2.2.2 (on ether2) and 3.3.3.2 (on ether3).
    Exemplo com eBGP
    Configuracao
    O exemplo dado acima é desenvolvido para o caso eBGP. Por padrão, os pares eBGP são obrigatórios
    para ser acessado diretamente. Se estamos usando interfaces loopback, que tecnicamente não são, por
    isso, multihop=yes configuração deve ser especificada.
    No Router A:
    /routing bgp set peer1 remote-address=9.9.9.2 remote-as=65001 update-source=lobridge multihop=yes
    No Router B:
    /routing bgp instance set default as=65001
    /routing bgp set peer1 remote-address=9.9.9.1 remote-as=65000 update-source=lobridge multihop=yes
    Resultados
    Se agora imprimir a tabela de roteamento no router A, vemos que a rota de Router B está lá, mas é
    não ativo:
    2 Db dst-address=4.4.4.0/24 gateway=9.9.9.2 interface="" gateway-state=unreachable
    distance=20 scope=40 target-scope=10 bgp-as-path="65001" bgp-origin=igp
    Isso ocorre porque as rotas eBGP são instalados com menor target-scope por padrão. Para resolver
    isso, a configuração
    filtro que define de maior escopo de destino de roteamento:
    /routing filter add chain=bgp-in set-target-scope=30
    /routing bgp set peer1 in-filter=bgp-in
    Ou então, modificar atributo âmbito da rota estática:
    /ip route set [find dst-address=9.9.9.2/32] scope=10
    de qualquer a maenira a routa para 4.4.4.0/24 deveria estar ativo agora:
    2 ADb dst-address=4.4.4.0/24 gateway=9.9.9.2 interface=ether1,ether2,ether3
    gateway-state=recursive distance=20 scope=40 target-scope=10
    bgp-as-path="65001" bgp-origin=igp received-from=9.9.9.2
  3. Mais nesse caso vou ter que usar 3 roteador de borda né? quero usar somente de um pois tenho uma coldcore a 36
    Citação Postado originalmente por parreira13 Ver Post
    Configuração
    No Router A:
    # addresses
    # BGP
    No Router B:
    # addresses
    # BGP
    Resultados
    Flags: X - disabled
    ether2
    r 2.2.2.2 ether2
    r 3.3.3.2 ether3
    Exemplo com eBGP
    Configuracao
    No Router A:
    No Router B:
    Resultados
    não ativo:
  4. voce coloca as configuracoes na mikrotik ccr36 depois voce vai sair com o link para onde?
  5. Tenho sairá para minha rede
  1. Respostas: 2
    Último Post: 04-12-2013, 07:33
  2. Bloqueio no acesso a mikrotik da mesma operadora
    Por peritinaicos no fórum Redes
    Respostas: 18
    Último Post: 27-02-2012, 09:26
  3. Respostas: 35
    Último Post: 18-01-2012, 16:32
  4. serie cisco 2500 conf 2 link da mesma operadora
    Por sjp210220 no fórum Cisco
    Último Post: 19-04-2011, 18:38
  5. Cyclades PR1000 com link da Telefonica
    Por dordetto no fórum Redes
    Respostas: 5
    Último Post: 28-12-2006, 22:36
