    Padrão Erro em conexão VPN PPTP
    Amigos... um bom dia!
    Tenho uma VPN PPTP configurada no meu Debian, na qual eu tento conexão via Windows nele a tem horas que vai e outras não.
    Verifiquei o Syslog em uma tentativa de conexão sem sucesso... segue abaixo o log.
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: MGR: Launching /usr/sbin/pptpctrl to handle client
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: local address = 192.168.0.250
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: remote address = 192.168.0.222
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: pppd options file = /etc/ppp/pptpd-options
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: Client 187.67.123.9 control connection started
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: Received PPTP Control Message (type: 1)
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: Made a START CTRL CONN RPLY packet
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: I wrote 156 bytes to the client.
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: Sent packet to client
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: Received PPTP Control Message (type: 7)
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: Set parameters to 100000000 maxbps, 64 window size
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: Made a OUT CALL RPLY packet
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: Starting call (launching pppd, opening GRE)
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: pty_fd = 6
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: tty_fd = 7
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: CTRL: I wrote 32 bytes to the client.
    Jan 30 21:13:31 ssav-bastion pptpd[17096]: CTRL (PPPD Launcher): program binary = /usr/sbin/pppd
    Jan 30 21:13:31 ssav-bastion pptpd[17096]: CTRL (PPPD Launcher): local address = 192.168.0.250
    Jan 30 21:13:31 ssav-bastion pptpd[17096]: CTRL (PPPD Launcher): remote address = 192.168.0.222
    Jan 30 21:13:31 ssav-bastion pppd[17096]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
    Jan 30 21:13:31 ssav-bastion pppd[17096]: pptpd-logwtmp: $Version$
    Jan 30 21:13:31 ssav-bastion pptpd[17095]: GRE: Bad checksum from pppd.
    Jan 30 21:13:32 ssav-bastion pptpd[17095]: CTRL: Received PPTP Control Message (type: 15)
    Jan 30 21:13:32 ssav-bastion pptpd[17095]: CTRL: Got a SET LINK INFO packet with standard ACCMs
    Jan 30 21:14:02 ssav-bastion pptpd[17095]: GRE: read(fd=6,buffer=8058640,len=8196) from PTY failed: status = -1 error = Input/output error, usually caused by unexpected termination of pppd, check option syntax and pppd logs
    Jan 30 21:14:02 ssav-bastion pptpd[17095]: CTRL: PTY read or GRE write failed (pty,gre)=(6,7)
    Jan 30 21:14:02 ssav-bastion pptpd[17095]: CTRL: Reaping child PPP[17096]
    Jan 30 21:14:02 ssav-bastion pptpd[17095]: CTRL: Client 187.67.123.9 control connection finished
    Jan 30 21:14:02 ssav-bastion pptpd[17095]: CTRL: Exiting now
    Jan 30 21:14:02 ssav-bastion pptpd[6026]: MGR: Reaped child 17095
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: MGR: Launching /usr/sbin/pptpctrl to handle client
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: local address = 192.168.0.250
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: remote address = 192.168.0.222
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: pppd options file = /etc/ppp/pptpd-options
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: Client 187.67.123.9 control connection started
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: Received PPTP Control Message (type: 1)
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: Made a START CTRL CONN RPLY packet
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: I wrote 156 bytes to the client.
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: Sent packet to client
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: Received PPTP Control Message (type: 7)
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: Set parameters to 100000000 maxbps, 64 window size
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: Made a OUT CALL RPLY packet
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: Starting call (launching pppd, opening GRE)
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: pty_fd = 6
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: tty_fd = 7
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: CTRL: I wrote 32 bytes to the client.
    Jan 30 21:14:03 ssav-bastion pptpd[17127]: CTRL (PPPD Launcher): program binary = /usr/sbin/pppd
    Jan 30 21:14:03 ssav-bastion pptpd[17127]: CTRL (PPPD Launcher): local address = 192.168.0.250
    Jan 30 21:14:03 ssav-bastion pptpd[17127]: CTRL (PPPD Launcher): remote address = 192.168.0.222
    Jan 30 21:14:03 ssav-bastion pppd[17127]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
    Jan 30 21:14:03 ssav-bastion pppd[17127]: pptpd-logwtmp: $Version$
    Jan 30 21:14:03 ssav-bastion pptpd[17126]: GRE: Bad checksum from pppd.
    Jan 30 21:14:04 ssav-bastion pptpd[17126]: CTRL: Received PPTP Control Message (type: 15)
    Jan 30 21:14:04 ssav-bastion pptpd[17126]: CTRL: Got a SET LINK INFO packet with standard ACCMs
    Jan 30 21:14:24 ssav-bastion pptpd[17126]: CTRL: Received PPTP Control Message (type: 15)
    Jan 30 21:14:24 ssav-bastion pptpd[17126]: CTRL: Got a SET LINK INFO packet with standard ACCMs
    Jan 30 21:14:32 ssav-bastion pptpd[17126]: CTRL: Received PPTP Control Message (type: 12)
    Jan 30 21:14:32 ssav-bastion pptpd[17126]: CTRL: Made a CALL DISCONNECT RPLY packet
    Jan 30 21:14:32 ssav-bastion pptpd[17126]: CTRL: Received CALL CLR request (closing call)
    Jan 30 21:14:32 ssav-bastion pptpd[17126]: CTRL: Reaping child PPP[17127]
    Jan 30 21:14:32 ssav-bastion pptpd[17126]: CTRL: Client 187.67.123.9 control connection finished
    Jan 30 21:14:32 ssav-bastion pptpd[17126]: CTRL: Exiting now
    Jan 30 21:14:32 ssav-bastion pptpd[6026]: MGR: Reaped child 17126
    Padrão Re: Erro em conexão VPN PPTP
    Vou da uma olhada ok.
    Código :
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: MGR: Launching /usr/sbin/pptpctrl to handle client
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: local address = 192.168.0.222
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: remote address = 192.168.1.222
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: pppd options file = /etc/ppp/pptpd-options
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: Client 201.29.129.29 control connection started
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: Received PPTP Control Message (type: 1)
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: Made a START CTRL CONN RPLY packet
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: I wrote 156 bytes to the client.
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: Sent packet to client
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: Received PPTP Control Message (type: 7)
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: Set parameters to 100000000 maxbps, 64 window size
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: Made a OUT CALL RPLY packet
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: Starting call (launching pppd, opening GRE)
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: pty_fd = 6
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: tty_fd = 7
    Feb  3 11:38:49 ssav-bastion pptpd[18123]: CTRL (PPPD Launcher): program binary = /usr/sbin/pppd
    Feb  3 11:38:49 ssav-bastion pptpd[18123]: CTRL (PPPD Launcher): local address = 192.168.0.222
    Feb  3 11:38:49 ssav-bastion pptpd[18123]: CTRL (PPPD Launcher): remote address = 192.168.1.222
    Feb  3 11:38:49 ssav-bastion pppd[18123]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
    Feb  3 11:38:49 ssav-bastion pppd[18123]: pptpd-logwtmp: $Version$
    Feb  3 11:38:49 ssav-bastion pppd[18123]: debug#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: dump#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: plugin /usr/lib/pptpd/pptpd-logwtmp.so#011#011# (from command line)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: auth#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: refuse-pap#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: refuse-chap#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: refuse-mschap#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: name pptp#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: pptpd-original-ip 201.29.129.29#011#011# (from command line)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: lock#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: mru 1490#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: mtu 1490#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: ms-dns xxx # [don't know how to print value]#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: nodefaultroute#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: proxyarp#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: nobsdcomp#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: require-mppe-128#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pppd[18123]: noipx#011#011# (from /etc/ppp/pptpd-options)
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: I wrote 32 bytes to the client.
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: GRE: Bad checksum from pppd.
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: GRE: read(fd=7,buffer=80505a0,len=8260) from network failed: status = -1 error = Protocol not available
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: GRE read or PTY write failed (gre,pty)=(7,6)
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: Reaping child PPP[18123]
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: Client 201.29.129.29 control connection finished
    Feb  3 11:38:49 ssav-bastion pptpd[18122]: CTRL: Exiting now
    Feb  3 11:38:49 ssav-bastion pptpd[16141]: MGR: Reaped child 18122
