    Padrão Executando script do MikroTik, pelo prompt de comando do Windows
    GALERA FIZ UM SCRIPT EM DOS (.BAT) PRA RODAR OS SCRIPT DO MIKROTIK.
    VOU POSTAR O SCRIPT E MARCAR EM NEGRITO ONDE PODE ALTERAR, E VOU DISPONIBILIZAR PRA DOWNLOAD, OU E SO COPIAR COLAR NUM BLOCO DE NOTAS E SALVAR COMO "SEUARQUIVO.BAT".
    REM ***** INICIO BATCH *****
    rem #################################################
    rem ## TESTE ##
    @echo off
    title TITULO QUALQUER
    setlocal
    set OK=N
    :mmenu
    cls
    @echo ##############
    @echo # Menu: #
    @echo [1] SCRIPT-01
    @echo [2] SCRIPT-02
    @echo [0] Exit...
    set /p choice=INSIRA O NUMERO:
    if /i [%choice%]==[0] endlocal&goto end
    if [%choice%]==[] goto mmenu
    if [%choice%]==[1] goto m1
    if [%choice%]==[2] goto m2
    set /p x=Invalid option, press Enter and insert valid option...
    goto mmenu
    :f1
    cls
    @echo Enabling Firewall ...
    @netsh firewall set opmode enable
    set /p x=Operation Completed, press Enter...
    goto mpmenu
    rem Main Menu Options
    :m1
    cls
    :: CONFIG ::::::::::::::::::::::::::::::::::\
    @set user=USUARIOMK
    @set pass=SENHA
    @set ip=IPMK
    :: END CONFIG ::::::::::::::::::::::::::::::/
    @echo Configuring network interface...
    @echo /sys script run NOMEDOSEUSCRIPT-01>script.auto.rsc
    :: ftp commands to upload script
    @echo user %user%> ftp.dat
    @echo %pass%>> ftp.dat
    @echo put script.auto.rsc>> ftp.dat
    @echo quit>> ftp.dat
    :: upload script
    @ftp -n -s:ftp.dat %ip%> NUL
    :: cleanup
    @del /q ftp.dat
    @del /q script.auto.rsc
    goto mmenu
    :m2
    cls
    @set user=USUARIOMK
    @set pass=SENHA
    @set ip=IPMK
    @echo /sys script run NOMEDOSEUSCRIPT-02>script.auto.rsc
    :: upload script
    :: cleanup
    @del /q ftp.dat
    goto mmenu
    :end
    cls
    @echo isacloko
    @echo testes
    ***** FIM BATCH *****
    AH NAO ESQUECA QUE O FTP DO MK TEM QUE ESTA ATIVO NA PORTA 21
    AGORA E SO USAR A IMAGINAÇÃO PRA VARIAS OUTRAS COISAS, EU FIZ OUTRO AKI QUE CRIA USUARIO NO HOTSPOT.
    PRA EDITAR O ARQUIVO DO DOWNLOAD E SO EXTRAIR E CLICAR COM O BOTAO DIREITO E CLICA EM EDITAR.
    TESTE.rar
    Deus acima de tudo!
    Jul 2009
    Paulista - Pernambuco
    Padrão Re: Executando script do MikroTik, pelo prompt de comando do Windows
    Muito bom mesmo amigo.
    Parabéns, gostei. Vou testar com alguns scripts aqui básicos como backup e etc... E depois digo como foi.
    Se possível manda o outro que cria o usuário direto no hotspot.
    Abração e sucesso!
