    Brasil.
    Padrão [dica] 48 - ubnt - mib completa ubiquiti
    https://www.facebook.com/MikrotikRio...03008476454086
    Mikrotik Rio - Brasil
    Opções para esta história
    [DICA] 48 - UBNT - MIB COMPLETA UBIQUITI
    [DICA] 48 - UBNT - MIB - SNMP
    UBNT-MIB DEFINITIONS ::= BEGIN
    IMPORTS
    MODULE-IDENTITY, OBJECT-TYPE, Integer32, Gauge32, Counter32, Counter64,
    IpAddress, TimeTicks, enterprises FROM SNMPv2-SMI
    DisplayString, TruthValue, MacAddress FROM SNMPv2-TC
    OBJECT-GROUP FROM SNMPv2-CONF;
    ubntMIB MODULE-IDENTITY
    LAST-UPDATED "201312180000Z"
    ORGANIZATION "Ubiquiti Networks, Inc."
    CONTACT-INFO "[email protected]"
    DESCRIPTION "The MIB module for Ubiquiti Networks, Inc. entities"
    REVISION "201312180000Z"
    DESCRIPTION "Initial revision"
    ::= { ubnt 1 }
    ubnt OBJECT IDENTIFIER ::= { enterprises 41112 }
    ubntSnmpInfo OBJECT IDENTIFIER ::= { ubntMIB 2 }
    ubntSnmpGroups OBJECT IDENTIFIER ::= { ubntSnmpInfo 1}
    ubntAirosGroups OBJECT IDENTIFIER ::= { ubntSnmpInfo 2}
    -- Ubiquiti Networks OR table
    ubntORTable OBJECT-TYPE
    SYNTAX SEQUENCE OF UbntOREntry
    MAX-ACCESS not-accessible
    STATUS current
    DESCRIPTION "Capabilities"
    ::= { ubntMIB 1 }
    ubntOREntry OBJECT-TYPE
    SYNTAX UbntOREntry
    STATUS current
    DESCRIPTION "An entry in the ubntORTable"
    INDEX { ubntORIndex }
    ::= { ubntORTable 1 }
    UbntOREntry ::= SEQUENCE {
    ubntORIndex Integer32,
    ubntORID OBJECT IDENTIFIER,
    ubntORDescr DisplayString
    ubntORIndex OBJECT-TYPE
    SYNTAX Integer32 (1..255)
    STATUS current
    DESCRIPTION "Index for the ubntORTable"
    ::= { ubntOREntry 1 }
    ubntORID OBJECT-TYPE
    SYNTAX OBJECT IDENTIFIER
    MAX-ACCESS read-only
    STATUS current
    DESCRIPTION "OR ID"
    ::= { ubntOREntry 2 }
    ubntORDescr OBJECT-TYPE
    SYNTAX DisplayString
    STATUS current
    DESCRIPTION "Description of idenfifier"
    ::= { ubntOREntry 3 }
    ubntORInfoGroup OBJECT-GROUP OBJECTS {
    ubntORID, ubntORDescr
    STATUS current
    DESCRIPTION ""
    ::= { ubntSnmpGroups 1 }
    ubntAirMAX OBJECT IDENTIFIER ::= { ubntMIB 4 }
    -- radio table
    ubntRadioTable OBJECT-TYPE
    SYNTAX SEQUENCE OF UbntRadioEntry
    STATUS current
    DESCRIPTION "Radio status & statistics"
    ::= { ubntAirMAX 1 }
    ubntRadioEntry OBJECT-TYPE
    SYNTAX UbntRadioEntry
    STATUS current
    DESCRIPTION "An entry in the ubntRadioTable"
    INDEX { ubntRadioIndex }
    ::= { ubntRadioTable 1 }
    UbntRadioEntry ::= SEQUENCE {
    ubntRadioIndex INTEGER,
    ubntRadioMode INTEGER,
    ubntRadioCCode INTEGER,
    ubntRadioFreq INTEGER,
    ubntRadioDfsEnabled TruthValue,
    ubntRadioTxPower INTEGER,
    ubntRadioDistance INTEGER,
    ubntRadioChainmask INTEGER,
    ubntRadioAntenna DisplayString
    ubntRadioIndex OBJECT-TYPE
    SYNTAX INTEGER (1..255)
    STATUS current
    DESCRIPTION "Index for the ubntRadioTable"
    ::= { ubntRadioEntry 1 }
    ubntRadioMode OBJECT-TYPE
    SYNTAX INTEGER {
    sta(1),
    ap(2),
    ap-repeater(3),
    ap-wds(4)
    STATUS current
    DESCRIPTION "Radio mode"
    ::= { ubntRadioEntry 2 }
    ubntRadioCCode OBJECT-TYPE
    SYNTAX INTEGER
    STATUS current
    DESCRIPTION "Country code"
    ::= { ubntRadioEntry 3 }
    ubntRadioFreq OBJECT-TYPE
    SYNTAX INTEGER (1..65535)
    STATUS current
    DESCRIPTION "Operating frequency"
    ::= { ubntRadioEntry 4 }
    ubntRadioDfsEnabled OBJECT-TYPE
    SYNTAX TruthValue
    STATUS current
    DESCRIPTION "DFS status"
    ::= { ubntRadioEntry 5 }
    ubntRadioTxPower OBJECT-TYPE
    STATUS current
    DESCRIPTION "Transmit power"
    ::= { ubntRadioEntry 6 }
    ubntRadioDistance OBJECT-TYPE
    STATUS current
    DESCRIPTION "Distance"
    ::= { ubntRadioEntry 7 }
    ubntRadioChainmask OBJECT-TYPE
    STATUS current
    DESCRIPTION "Chainmask"
    ::= { ubntRadioEntry 8 }
    ubntRadioAntenna OBJECT-TYPE
    STATUS current
    DESCRIPTION "Antenna"
    ::= { ubntRadioEntry 9 }
    ubntRadioRssiTable OBJECT-TYPE
    SYNTAX SEQUENCE OF UbntRadioRssiEntry
    STATUS current
    DESCRIPTION "Radio RSSI per chain"
    ::= { ubntAirMAX 2 }
    ubntRadioRssiEntry OBJECT-TYPE
    SYNTAX UbntRadioRssiEntry
    STATUS current
    DESCRIPTION "An entry in the ubntRadioRssiTable"
    INDEX { ubntRadioIndex, ubntRadioRssiIndex }
    ::= { ubntRadioRssiTable 1 }
    UbntRadioRssiEntry ::= SEQUENCE {
    ubntRadioRssiIndex Integer32,
    ubntRadioRssi Integer32,
    ubntRadioRssiMgmt Integer32,
    ubntRadioRssiExt Integer32
    ubntRadioRssiIndex OBJECT-TYPE
    STATUS current
    DESCRIPTION "Index for the ubntRadioRssiTable"
    ::= { ubntRadioRssiEntry 1 }
    ubntRadioRssi OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION ""
    ::= { ubntRadioRssiEntry 2 }
    ubntRadioRssiMgmt OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION ""
    ::= { ubntRadioRssiEntry 3 }
    ubntRadioRssiExt OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION ""
    ::= { ubntRadioRssiEntry 4 }
    Brasil.
    Padrão Re: [dica] 48 - ubnt - mib completa ubiquiti
    ---> Continuação
    -- airMAX table
    ubntAirMaxTable OBJECT-TYPE
    SYNTAX SEQUENCE OF UbntAirMaxEntry
    STATUS current
    DESCRIPTION "airMAX protocol statistics"
    ::= { ubntAirMAX 6 }
    ubntAirMaxEntry OBJECT-TYPE
    SYNTAX UbntAirMaxEntry
    STATUS current
    DESCRIPTION "An entry in the ubntAirMaxTable"
    INDEX { ubntAirMaxIfIndex }
    ::= { ubntAirMaxTable 1 }
    UbntAirMaxEntry ::= SEQUENCE {
    ubntAirMaxIfIndex INTEGER,
    ubntAirMaxEnabled TruthValue,
    ubntAirMaxQuality Integer32,
    ubntAirMaxCapacity Integer32,
    ubntAirMaxPriority INTEGER,
    ubntAirMaxNoAck TruthValue
    ubntAirMaxIfIndex OBJECT-TYPE
    STATUS current
    DESCRIPTION "Index for the ubntAirMaxTable"
    ::= { ubntAirMaxEntry 1 }
    ubntAirMaxEnabled OBJECT-TYPE
    SYNTAX TruthValue
    STATUS current
    DESCRIPTION "airMAX status - on/off"
    ::= { ubntAirMaxEntry 2 }
    ubntAirMaxQuality OBJECT-TYPE
    SYNTAX Integer32 (0..100)
    STATUS current
    DESCRIPTION "airMAX quality - percentage"
    ::= { ubntAirMaxEntry 3 }
    ubntAirMaxCapacity OBJECT-TYPE
    STATUS current
    DESCRIPTION "airMAX capacity - percentage"
    ::= { ubntAirMaxEntry 4 }
    ubntAirMaxPriority OBJECT-TYPE
    SYNTAX INTEGER {
    high(0),
    medium(1),
    low(2),
    none(3)
    STATUS current
    DESCRIPTION "airMAX priority - none/high/low/medium"
    ::= { ubntAirMaxEntry 5 }
    ubntAirMaxNoAck OBJECT-TYPE
    SYNTAX TruthValue
    STATUS current
    DESCRIPTION "airMAX NoACK mode - on/off"
    ::= { ubntAirMaxEntry 6 }
    -- airSync table
    ubntAirSyncTable OBJECT-TYPE
    SYNTAX SEQUENCE OF UbntAirSyncEntry
    STATUS current
    DESCRIPTION "airSync protocol statistics"
    ::= { ubntAirMAX 3 }
    ubntAirSyncEntry OBJECT-TYPE
    SYNTAX UbntAirSyncEntry
    STATUS current
    DESCRIPTION "An entry in the ubntAirSyncTable"
    INDEX { ubntAirSyncIfIndex }
    ::= { ubntAirSyncTable 1 }
    UbntAirSyncEntry ::= SEQUENCE {
    ubntAirSyncIfIndex INTEGER,
    ubntAirSyncMode INTEGER,
    ubntAirSyncCount INTEGER,
    ubntAirSyncDownUtil INTEGER,
    ubntAirSyncUpUtil INTEGER
    ubntAirSyncIfIndex OBJECT-TYPE
    STATUS current
    DESCRIPTION "Index for the ubntAirSyncTable"
    ::= { ubntAirSyncEntry 1 }
    ubntAirSyncMode OBJECT-TYPE
    SYNTAX INTEGER {
    disabled(0),
    master(1),
    slave(2)
    STATUS current
    DESCRIPTION "airSync mode - master/slave"
    ::= { ubntAirSyncEntry 2 }
    ubntAirSyncCount OBJECT-TYPE
    SYNTAX INTEGER (0..255)
    STATUS current
    DESCRIPTION "airSync client count"
    ::= { ubntAirSyncEntry 3 }
    ubntAirSyncDownUtil OBJECT-TYPE
    SYNTAX INTEGER (0..100)
    STATUS current
    DESCRIPTION "airSync down utilization"
    ::= { ubntAirSyncEntry 4 }
    ubntAirSyncUpUtil OBJECT-TYPE
    STATUS current
    DESCRIPTION "airSync up utilization"
    ::= { ubntAirSyncEntry 5 }
    -- airSelect table
    ubntAirSelTable OBJECT-TYPE
    SYNTAX SEQUENCE OF UbntAirSelEntry
    STATUS current
    DESCRIPTION "airSelect protocol statistics"
    ::= { ubntAirMAX 4 }
    ubntAirSelEntry OBJECT-TYPE
    SYNTAX UbntAirSelEntry
    STATUS current
    DESCRIPTION "An entry in the ubntAirSelTable"
    INDEX { ubntAirSelIfIndex }
    ::= { ubntAirSelTable 1 }
    UbntAirSelEntry ::= SEQUENCE {
    ubntAirSelIfIndex INTEGER,
    ubntAirSelEnabled TruthValue,
    ubntAirSelInterval Integer32
    ubntAirSelIfIndex OBJECT-TYPE
    STATUS current
    DESCRIPTION "Index for the ubntAirSelTable"
    ::= { ubntAirSelEntry 1 }
    ubntAirSelEnabled OBJECT-TYPE
    SYNTAX TruthValue
    STATUS current
    DESCRIPTION "airSelect status - on/off"
    ::= { ubntAirSelEntry 2 }
    ubntAirSelInterval OBJECT-TYPE
    SYNTAX Integer32 (0..65535)
    STATUS current
    DESCRIPTION "airSelect hop interval (miliseconds)"
    ::= { ubntAirSelEntry 3 }
    Brasil.
    ---> Continuação
    -- wireless statistics table
    ubntWlStatTable OBJECT-TYPE
    SYNTAX SEQUENCE OF UbntWlStatEntry
    STATUS current
    DESCRIPTION "Wireless statistics"
    ::= { ubntAirMAX 5 }
    ubntWlStatEntry OBJECT-TYPE
    SYNTAX UbntWlStatEntry
    STATUS current
    DESCRIPTION "An entry in the ubntWlStatTable"
    INDEX { ubntWlStatIndex }
    ::= { ubntWlStatTable 1 }
    UbntWlStatEntry ::= SEQUENCE {
    ubntWlStatIndex INTEGER,
    ubntWlStatSsid DisplayString,
    ubntWlStatHideSsid TruthValue,
    ubntWlStatApMac MacAddress,
    ubntWlStatSignal Integer32,
    ubntWlStatRssi Integer32,
    ubntWlStatCcq Integer32,
    ubntWlStatNoiseFloor Integer32,
    ubntWlStatTxRate Integer32,
    ubntWlStatRxRate Integer32,
    ubntWlStatSecurity DisplayString,
    ubntWlStatWdsEnabled TruthValue,
    ubntWlStatApRepeater TruthValue,
    ubntWlStatChanWidth Integer32,
    ubntWlStatStaCount Gauge32
    ubntWlStatIndex OBJECT-TYPE
    STATUS current
    DESCRIPTION "Index for the ubntWlStatTable"
    ::= { ubntWlStatEntry 1 }
    ubntWlStatSsid OBJECT-TYPE
    STATUS current
    DESCRIPTION "SSID"
    ::= { ubntWlStatEntry 2 }
    ubntWlStatHideSsid OBJECT-TYPE
    SYNTAX TruthValue
    STATUS current
    DESCRIPTION "Hide SSID - on/off"
    ::= { ubntWlStatEntry 3 }
    ubntWlStatApMac OBJECT-TYPE
    SYNTAX MacAddress
    STATUS current
    DESCRIPTION "AP MAC address"
    ::= { ubntWlStatEntry 4 }
    ubntWlStatSignal OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION "Signal strength, dBm"
    ::= { ubntWlStatEntry 5 }
    ubntWlStatRssi OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION "RSSI, dBm"
    ::= { ubntWlStatEntry 6 }
    ubntWlStatCcq OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION "CCQ in %"
    ::= { ubntWlStatEntry 7 }
    ubntWlStatNoiseFloor OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION "Noise floor"
    ::= { ubntWlStatEntry 8 }
    ubntWlStatTxRate OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION "TX rate"
    ::= { ubntWlStatEntry 9 }
    ubntWlStatRxRate OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION "RX rate"
    ::= { ubntWlStatEntry 10 }
    ubntWlStatSecurity OBJECT-TYPE
    STATUS current
    DESCRIPTION "Wireless security mode"
    ::= { ubntWlStatEntry 11 }
    ubntWlStatWdsEnabled OBJECT-TYPE
    SYNTAX TruthValue
    STATUS current
    DESCRIPTION "WDS - on/off"
    ::= { ubntWlStatEntry 12 }
    ubntWlStatApRepeater OBJECT-TYPE
    SYNTAX TruthValue
    STATUS current
    DESCRIPTION "AP repeater - on/off"
    ::= { ubntWlStatEntry 13 }
    ubntWlStatChanWidth OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION "Channel Width"
    ::= { ubntWlStatEntry 14 }
    ubntWlStatStaCount OBJECT-TYPE
    SYNTAX Gauge32
    STATUS current
    DESCRIPTION "Station count"
    ::= { ubntWlStatEntry 15 }
    -- station list table
    ubntStaTable OBJECT-TYPE
    SYNTAX SEQUENCE OF UbntStaEntry
    STATUS current
    DESCRIPTION "Station list"
    ::= { ubntAirMAX 7 }
    ubntStaEntry OBJECT-TYPE
    SYNTAX UbntStaEntry
    STATUS current
    DESCRIPTION "An entry in the ubntStaEntry"
    INDEX { ubntWlStatIndex, ubntStaMac }
    ::= { ubntStaTable 1 }
    UbntStaEntry ::= SEQUENCE {
    ubntStaMac MacAddress,
    ubntStaName DisplayString,
    ubntStaSignal Integer32,
    ubntStaNoiseFloor Integer32,
    ubntStaDistance Integer32,
    ubntStaCcq Integer32,
    ubntStaAmp Integer32,
    ubntStaAmq Integer32,
    ubntStaAmc Integer32,
    ubntStaLastIp IpAddress,
    ubntStaTxRate Integer32,
    ubntStaRxRate Integer32,
    ubntStaTxBytes Counter64,
    ubntStaRxBytes Counter64,
    ubntStaConnTime TimeTicks
    ubntStaMac OBJECT-TYPE
    SYNTAX MacAddress
    STATUS current
    DESCRIPTION "Station MAC address"
    ::= { ubntStaEntry 1 }
    ubntStaName OBJECT-TYPE
    STATUS current
    DESCRIPTION "Station name"
    ::= { ubntStaEntry 2 }
    ubntStaSignal OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    ::= { ubntStaEntry 3 }
    ubntStaNoiseFloor OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    ::= { ubntStaEntry 4 }
    ubntStaDistance OBJECT-TYPE
    STATUS current
    ::= { ubntStaEntry 5 }
    ubntStaCcq OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    ::= { ubntStaEntry 6 }
    ubntStaAmp OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION "airMAX priority"
    ::= { ubntStaEntry 7 }
    ubntStaAmq OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION "airMAX quality"
    ::= { ubntStaEntry 8 }
    ubntStaAmc OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    DESCRIPTION "airMAX capacity"
    ::= { ubntStaEntry 9 }
    ubntStaLastIp OBJECT-TYPE
    SYNTAX IpAddress
    STATUS current
    DESCRIPTION "Last known IP address"
    ::= { ubntStaEntry 10 }
    ubntStaTxRate OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    ::= { ubntStaEntry 11 }
    ubntStaRxRate OBJECT-TYPE
    SYNTAX Integer32
    STATUS current
    ::= { ubntStaEntry 12 }
    ubntStaTxBytes OBJECT-TYPE
    SYNTAX Counter64
    STATUS current
    DESCRIPTION "TX bytes"
    ::= { ubntStaEntry 13 }
    ubntStaRxBytes OBJECT-TYPE
    SYNTAX Counter64
    STATUS current
    ::= { ubntStaEntry 14 }
    ubntStaConnTime OBJECT-TYPE
    SYNTAX TimeTicks
    STATUS current
    DESCRIPTION "Connection Time in seconds"
    ::= { ubntStaEntry 15 }
    END
    amigo explica ai para os leigo igual a eu o que significa isso.
    Brasil.
    Antes de definir o que é uma MIB, será introduzido o conceito de objetos gerenciados.
    Um objeto gerenciado é a visão abstrata de um recurso real do sistema. Assim, todos os recursos da rede que devem ser gerenciados são modelados, e as estruturas de dados resultantes são os objetos gerenciados. Os objetos gerenciados podem ter permissões para serem lidos ou alterados, sendo que cada leitura representará o estado real do recurso e, cada alteração também será refletida no próprio recurso.
    Dessa forma, a MIB (Management Information Base) é o conjunto dos objetos gerenciados, que procura abranger todas as informações necessárias para a gerência da rede, possibilitando assim, a automatização de grande parte das tarefas de gerência.
    Os padrões de gerenciamento OSI e Internet definiram MIBs que representam os objetos necessários para a gerência de seus recursos. Neste hiperdocumento serão apresentadas considerações sobre a MIB da OSI e a MIB Internet, bem como as diferenças entre as MIBs desses dois padrões.
    Fonte: http://penta.ufrgs.br/gr952/trab1/2conceit.html Acessado em 02 de mar. de 2014 as 10:41
    Fazendo uso da MIB é possível criar o monitoramento no gráfico, como por exemplo no THE DUDE.
    No Facebook, tenho 4 dicas do THE DUDE. Segue uma bem simples.
    https://www.facebook.com/notes/mikro...44057035682565
