Bom dia pessoal,
Estou precisando fazer umas VLAN's para transportar alguns links para minha empresa. Da forma simples, que tem no WIKI do Mikrotik vai de boa. Mas eu precisava implementar um pouco mais.
Vou colocar a screen do esquema que tem no site da Mikrotik e em seguida coloco a minha, que estou desenvolvendo e testando.
MIKROTIK WIKI
Minha necessidade
VLAN - MIKROTIK Devices RB2011iL-IN - Filial 1
interface vlan add name=vlandsl102 vlan-id=102 interface=ether1 disabled=no
interface vlan add name=vlandsl103 vlan-id=103 interface=ether1 disabled=no
interface vlan add name=vlandsl104 vlan-id=104 interface=ether1 disabled=no
interface vlan add name=vlandsl105 vlan-id=105 interface=ether1 disabled=no
interface vlan add name=vlandsl106 vlan-id=106 interface=ether1 disabled=no
interface vlan add name=vlandsl107 vlan-id=107 interface=ether1 disabled=no
interface vlan add name=vlandsl108 vlan-id=108 interface=ether1 disabled=no
interface vlan add name=vlandsl109 vlan-id=109 interface=ether1 disabled=no
interface vlan add name=vlandsl110 vlan-id=110 interface=ether1 disabled=no
interface bridge add name=Bridgevlandsl102 disabled=no
interface bridge add name=Bridgevlandsl103 disabled=no
interface bridge add name=Bridgevlandsl104 disabled=no
interface bridge add name=Bridgevlandsl105 disabled=no
interface bridge add name=Bridgevlandsl106 disabled=no
interface bridge add name=Bridgevlandsl107 disabled=no
interface bridge add name=Bridgevlandsl108 disabled=no
interface bridge add name=Bridgevlandsl109 disabled=no
interface bridge add name=Bridgevlandsl110 disabled=no
interface bridge port add interface="vlandsl102" bridge="Bridgevlandsl102" disabled=no
interface bridge port add interface="ether2" bridge="Bridgevlandsl102" disabled=no
interface bridge port add interface="vlandsl103" bridge="Bridgevlandsl103" disabled=no
interface bridge port add interface="ether3" bridge="Bridgevlandsl103" disabled=no
interface bridge port add interface="vlandsl104" bridge="Bridgevlandsl104" disabled=no
interface bridge port add interface="ether4" bridge="Bridgevlandsl104" disabled=no
interface bridge port add interface="vlandsl105" bridge="Bridgevlandsl105" disabled=no
interface bridge port add interface="ether5" bridge="Bridgevlandsl105" disabled=no
interface bridge port add interface="vlandsl106" bridge="Bridgevlandsl106" disabled=no
interface bridge port add interface="ether6" bridge="Bridgevlandsl106" disabled=no
interface bridge port add interface="vlandsl107" bridge="Bridgevlandsl107" disabled=no
interface bridge port add interface="ether7" bridge="Bridgevlandsl107" disabled=no
interface bridge port add interface="vlandsl108" bridge="Bridgevlandsl108" disabled=no
interface bridge port add interface="ether8" bridge="Bridgevlandsl108" disabled=no
interface bridge port add interface="vlandsl109" bridge="Bridgevlandsl109" disabled=no
interface bridge port add interface="ether9" bridge="Bridgevlandsl109" disabled=no
interface bridge port add interface="vlandsl110" bridge="Bridgevlandsl110" disabled=no
interface bridge port add interface="ether10" bridge="Bridgevlandsl110" disabled=no
VLAN - MIKROTIK Devices RB2011UiAS-RM - Filial 2
interface vlan add name=vlandsl112 vlan-id=112 interface=ether1 disabled=no
interface vlan add name=vlandsl113 vlan-id=113 interface=ether1 disabled=no
interface vlan add name=vlandsl114 vlan-id=114 interface=ether1 disabled=no
interface vlan add name=vlandsl115 vlan-id=115 interface=ether1 disabled=no
interface vlan add name=vlandsl116 vlan-id=116 interface=ether1 disabled=no
interface vlan add name=vlandsl117 vlan-id=117 interface=ether1 disabled=no
interface vlan add name=vlandsl118 vlan-id=118 interface=ether1 disabled=no
interface vlan add name=vlandsl119 vlan-id=119 interface=ether1 disabled=no
interface vlan add name=vlandsl120 vlan-id=120 interface=ether1 disabled=no
interface bridge add name=Bridgevlandsl112 disabled=no
interface bridge add name=Bridgevlandsl113 disabled=no
interface bridge add name=Bridgevlandsl114 disabled=no
interface bridge add name=Bridgevlandsl115 disabled=no
interface bridge add name=Bridgevlandsl116 disabled=no
interface bridge add name=Bridgevlandsl117 disabled=no
interface bridge add name=Bridgevlandsl118 disabled=no
interface bridge add name=Bridgevlandsl119 disabled=no
interface bridge add name=Bridgevlandsl120 disabled=no
interface bridge port add interface="vlandsl112" bridge="Bridgevlandsl112" disabled=no
interface bridge port add interface="ether2" bridge="Bridgevlandsl112" disabled=no
interface bridge port add interface="vlandsl113" bridge="Bridgevlandsl113" disabled=no
interface bridge port add interface="ether3" bridge="Bridgevlandsl113" disabled=no
interface bridge port add interface="vlandsl114" bridge="Bridgevlandsl114" disabled=no
interface bridge port add interface="ether4" bridge="Bridgevlandsl114" disabled=no
interface bridge port add interface="vlandsl115" bridge="Bridgevlandsl115" disabled=no
interface bridge port add interface="ether5" bridge="Bridgevlandsl115" disabled=no
interface bridge port add interface="vlandsl116" bridge="Bridgevlandsl116" disabled=no
interface bridge port add interface="ether6" bridge="Bridgevlandsl116" disabled=no
interface bridge port add interface="vlandsl117" bridge="Bridgevlandsl117" disabled=no
interface bridge port add interface="ether7" bridge="Bridgevlandsl117" disabled=no
interface bridge port add interface="vlandsl118" bridge="Bridgevlandsl118" disabled=no
interface bridge port add interface="ether8" bridge="Bridgevlandsl118" disabled=no
interface bridge port add interface="vlandsl119" bridge="Bridgevlandsl119" disabled=no
interface bridge port add interface="ether9" bridge="Bridgevlandsl119" disabled=no
interface bridge port add interface="vlandsl120" bridge="Bridgevlandsl120" disabled=no
interface bridge port add interface="ether10" bridge="Bridgevlandsl120" disabled=no
VLAN - MIKROTIK Devices RB750GL - Torre
interface bridge port add interface="ether1" bridge="BridgevlandslRB750GL" disabled=no
interface bridge port add interface="ether2" bridge="BridgevlandslRB750GL" disabled=no
interface bridge port add interface="ether3" bridge="BridgevlandslRB750GL" disabled=no
VLAN - MIKROTIK Devices RB1100 - Matriz
interface bridge port add interface="ether6" bridge="Bridgevlandsl102" disabled=no
interface bridge port add interface="ether7" bridge="Bridgevlandsl103" disabled=no
interface bridge port add interface="ether8" bridge="Bridgevlandsl104" disabled=no
interface bridge port add interface="ether9" bridge="Bridgevlandsl105" disabled=no
interface bridge port add interface="ether10" bridge="Bridgevlandsl106" disabled=no
interface bridge port add interface="ether11" bridge="Bridgevlandsl107" disabled=no
interface bridge port add interface="ether12" bridge="Bridgevlandsl108" disabled=no
interface bridge port add interface="ether13" bridge="Bridgevlandsl109" disabled=no
Citação
