    Apr 2008
    São Paulo / Interior
    Padrão RouterOS v6.19 released
    Vamos ver o que fica bugado agora.......rsrsrsrsrsrsrs
    What's new in 6.19 (2014-Aug-26 14:05):
    *) wireless - improvements for nv2 and 802.11ac
    *) sstp - make sstp work on i386 as well;
    *) ippool - improve performance when acquiring address without preference;
    *) partitions - copying partitions did not work on some boards;
    *) bridge - added "Auto Isolate" stp enhancement (802.1q-2011, 13.25.6)
    *) ipsec - when peer config is changed kill only relevant SAs;
    *) vpls - do not abort BGP connection when receiving invalid 12 byte
    nexthop encoding;
    *) dns-update - fix zone update;
    *) dhcpv4 server - support multiple radius address lists;
    *) console - added unary operator 'any' that evaluates to true if argument
    is not null or nothing value;
    *) CCR - improved performance;
    *) firewall - packet defragmenting will only happen with connection tracking enabled;
    *) firewall - optimized option matching order with-in a rule;
    *) firewall - rules that require CONNTRACK to work will now have Invalid flag
    when CONNTRACK is disabled;
    *) firewall - rules that require use-ip-firewall to work will now have invalid flag
    when use-ip-firewall is disabled;
    *) firewall - rules that have interface with "Slave" flag specified as in-/out-interface
    will now have Invalid flag;
    *) firewall - rules that have interface without "Slave" flag specified as in-/out-bridge-port
    *) firewall - rules with Invalid flags will now be auto-commented to explain why;
    *) l2tp - force l2tp to not use MPPE encryption if IPsec is used;
    *) sstp - force sstp to not use MPPE encryption (it already has TLS one);
    *) sstp - make it work for x86 systems
    *) winbox - added dual PSU stats in health menu
    *) ipv6 - Gre6 can now correctly fragment large packets
    *) simple queue performance optimisation/improvement for multi-core RouterOS devices (especially CCR)
    If you already run some RouterOS v6.x version, simply click “Check for updates” in QuickSet, Webfig or Winbox packages menu.
    Others: http://www.mikrotik.com/download
    Padrão Re: RouterOS v6.19 released
    pessoal tem um bug ai quem ta usando o thunder que a rota nao ta subindo ta ficando em azul a rota estática do thunder
    para quem acontecer basta reiniciar mais 1x a rb que sobe em pretinho
    Apr 2008
    nao ta marcando pacote no mangle para redirecionar para o thunder
    É verdade, manda e-mail lá para eles reclamando para atualizar o "what´s new".
    Eu q nao saio da 6.7 na ccr nem fudendo!
