  1. Pessoal,
    Quando envio email ele retorna isso:
    Delivery to the following recipient failed permanently:
    usuario@xxx.xxx.br
    Technical details of permanent failure:
    Google tried to deliver your message, but it was rejected by the server for the recipient domain xxx.xxx.br by xxx.xxx.xxx.br. [xx.xx.xx.x].
    The error that the other server returned was:
    554 Service unavailable; Client host [209.85.220.182] blocked using relays.orbs.org
    Testes que eu fiz :
    http://www.blacklistalert.org/
    Result for xxx.xx.xx.x in LHSBL Blocklists (Alphabetic order):
    0spam.fusionzero.com OK
    aspews.ext.sorbs.net OK
    b.barracudacentral.org OK
    bl.mailspike.net OK
    bl.spameatingmonkey.net OK
    bl.spamcop.net OK
    bl.spamcannibal.org OK
    bl.tiopan.com No Result (SERVFAIL)
    blackholes.five-ten-sg.com OK
    blackholes.intersil.net OK
    bogons.cymru.com OK
    cbl.abuseat.org OK
    combined.njabl.org No Result (SERVFAIL)
    db.wpbl.info OK
    dnsbl.ahbl.org No Result (REFUSED)
    dnsbl.inps.de OK
    dnsbl.justspam.org OK
    dnsbl.mags.net OK
    dnsbl.sorbs.net OK
    dnsbl.rangers.eu.org OK
    dnsbl-0.uceprotect.net OK
    dnsbl-1.uceprotect.net OK
    dnsbl-2.uceprotect.net OK
    dnsbl-3.uceprotect.net OK
    dyna.spamrats.com OK
    ip.v4bl.org Listed! See why
    ips.backscatterer.org OK
    ix.dnsbl.manitu.net OK
    l2.apews.org Listed! See why
    no-more-funn.moensted.dk OK
    noptr.spamrats.com OK
    psbl.surriel.com OK
    rbl.efnet.org OK
    spam.abuse.ch OK
    spam.dnsbl.anonmails.de OK
    spam.spamrats.com OK
    spamguard.leadmon.net OK
    t1.dnsbl.net.au OK
    tor.dan.me.uk OK
    tor.dnsbl.sectoor.de OK
    ubl.unsubscore.com OK
    virbl.dnsbl.bit.nl OK
    zen.spamhaus.org OK
    RHSBL-Test for xxx.xx.xx.x's PTR catedral2.ceftru.unb.br (Alphabetic order):
    abuse.rfc-ignorant.org OK
    bogusmx.rfc-ignorant.org OK
    dbl.spamhaus.org OK
    dsn.rfc-ignorant.org OK
    dynamic.rhs.mailpolice.com LISTED!
    l1.apews.org OK
    list.anonwhois.net OK
    multi.surbl.org OK
    multi.uribl.com LISTED! See why
    postmaster.rfc-ignorant.org OK
    rddn.dnsbl.net.au OK
    rhsbl.ahbl.org OK
    rhsbl.sorbs.net OK
    webmail.rhs.mailpolice.com LISTED!
    DNS REverso tudo OK
    http://mail.terra.com.br/postmaster/reverso.cgi
    O DNS do IP [xxx.xx.xx.x] está corretamente configurado
    Vi que meu servidor de email caiu na black list, so que os sites que diz que tem problema não tem opção de remover ou não sei fazer isso!!!
    Alguma luz ai pessoal,valeu
  2. Isso é bem chato cara, normalmente antes de vc tentar remover o seu site dessas blacklists vc teria que tentar solucionar o problema que gerou essa inclusão.
    Algumas blacklists não tem mesmo a opção de remover, basta vc aguardar algumas horas ou dias sem que o problema volte a ocorrer que eles automaticamente "esquecem" de vc, outras tem a opção de remoção, porém ao primeiro sinal do mesmo problema lá vai vc novamente para a blacklist, outras ainda são mais chatas (normalmente as corporativas), essas vc tem que tentar um contato informando o problema que vc passou, a solução que vc adotou para evitar problemas futuros e então solicitar a remoção do seu servidor de lá.
    Boa sorte e bem vindo ao mundo dos e-mails...
  1. Problema no envio de e-mail Qmail
    Por pixe00 no fórum Servidores de Rede
    Respostas: 5
    Último Post: 04-04-2007, 14:02
  2. Problema no envio de e-mail externos, QMAIL
    Por ThiagoOverseer no fórum Servidores de Rede
    Último Post: 08-02-2007, 14:57
  3. Sendmail - problemas no tempo de envio de mail's
    Por maam no fórum Servidores de Rede
    Último Post: 21-06-2006, 12:31
  4. Problema no envio de e-mail no Sendmail
    Por wolf no fórum Servidores de Rede
    Último Post: 27-04-2005, 08:40
  5. Problemas no envio de formulários por e-mail
    Por TonTux no fórum Servidores de Rede
    Último Post: 14-01-2004, 11:03
