    May 2010
    Carapicuíba, Brazil, Brazil
    Padrão Novo firmware ubnt 5.5.10 .
    saiu o novo firmware ubnt 5.5.10 olhem o change log.
    AirOS V Firmware Revision History====================================================================Supported products * Bullet M2/M5/Titanium * Rocket M2/M2 Titanium/M3/M365/M900/M5/M5 GPS/M5 Titanium/M6 * NanoStation M2/M3/M365/M5/M6 * NanoStation Loco M2/M900/M5 * NanoBridge M2/M3/M365/M900/M5 * AirGrid M2/M5/HP/HP New * PowerBridge M3/M365/M5/M10 * PicoStation M2 * AirRouter/HP * PowerAP N ====================================================================Version 5.5.10-Service release (October 01, 2014)-------------------------------------------------Regulatory updates:- New: Open 5150-5250MHz frequency range for United States and Puerto Rico (U.S. territory) countries. This change applies for product models listed bellow: * Rocket M5/Rocket M5 Titanium * NanoStation M5 * NanoStation M5 Loco * NanoBridge M5- New: Add 40MHz channel bandwidth for New Zealand
    Padrão Re: Novo firmware ubnt 5.5.10 .
    No caso da linha XW ouve mais mudança.
    Fixes:
    - Fix: airSync crashes on new Rocket M5 Titanium
    - Fix: airView causes device to reboot (US version products)
    - Fix: Ethernet negotiation issues when using 100Mbps PoE with gigabit capable devices
    - Fix: Remote station management issues on high traffic load (WPA2-AES, WDS)
    - Fix: AutoACK miscalculation for 8MHz and 30MHz channel widths
    - Fix: Device bricks when using configuration backup file taken from NanoStation device with PoE passthrough option enabled
    - Fix: EAP TTLS/PEAP do not check time in TLS sessions
    - Fix: Get Last IP from VLAN tagged traffic
    - Fix: RADIUS accounting issue
    - Fix: Site Survey improvements
    - Fix: Don't offer to store WPA PSK key as login credentials
    Improvements:
    - Low TX issue improvements
    - airMax: Improvements for narrow channel widths usage scenarios
    - airMax: Improvements addressing Low TX when connecting to XM AP
    - Ethernet: 100Mbps negotiation for NanoBeam M5 400 (XW) and Rocket M5 Titanium (XW)
    - Data rates: Improved Data Rate selection when connecting to XM devices
    Será que resolveram esse problema: https://under-linux.org/showthread.p...013#post726013
    Porque ta tenso.
    Firmware image check failed. Error code: -6
    é o que acontece quando tento atualizar a versão 5.5.6 para a 5.5.10
    testei outro método: fazer o update da 5.5.6 pra 5.5.8 e só depois pra 5.5.10 mas mesmo assim:
    5.5.6 IS THE BEAST ! NÃO TROCO POR NENHUMA OUTRA
    Verifique se vc baixou a versao XM e nao a XW, a versao XW eh somente para modelos novos, tp NanoBeam, PowerBeam e afins.
    Pra mim ubiquiti não presta 1° é boa por pouco tempo depois de um tempo começa a dar muitos problemas com perda de potencia , porta lan , erro de software etc...
    2° nunca vi tanta atualização de firmware assim como a ubiquiti faz vai se lascar e ainda faz pra pior parece . fica ai minha ondignção , viva o mikrotik ubiquiti nao chega nem perto .
    Citação Postado originalmente por leme101 Ver Post
    Mikrotik pra que?
    Radio? BGP? PPPoE? Swithing? Firewall?
    Sei lá, não tenho nada contra ninguém mais Ubiquiti nunca me deixou na mão. RouterOS (CCR principalmente) cada atualização é uma caixinha de surpresas. Minha sorte é que nem tenho ideia de o que é um BGP com MK.
    Mais antes que isso vire uma história sem fim, há quem defenda intelbras e diga que é a quinta maravilha do mundo, assim como outros defendem a Mikrotik, eu particularmente gosto de Ubiquiti, pelo simples fato que me atende muito bem.
