:local username "Aqui seu usuario"
:local password "Aqui sua senha"
:global hostname "aqui seu host name criado no site"
:global dyndnsForce
:global previousIP
:local resolvedIP [:resolve $hostname]
#print some debug
#:log info ("UpdateDynDNS: username = $username")
#:log info ("UpdateDynDNS: password = $password")
:log info ("UpdateDynDNS: hostname = $hostname")
:log info ("UpdateDynDNS: previousIP = $previousIP")
:log info ("UpdateDynDNS: resolvedIP = $resolvedIP")
# get the current IP address from the internet (in case of double-nat)
/tool fetch mode=http address="checkip.dyndns.org" src-path="/" dst-path="/dyndns.checkip.html"
:local result [/file get dyndns.checkip.html contents]
# parse the current IP result
:local resultLen [:len $result]
:local startLoc [:find $result ": " -1]
:set startLoc ($startLoc + 2)
:local endLoc [:find $result "" -1]
:local currentIP [:pick $result $startLoc $endLoc]
:log info "UpdateDynDNS: currentIP = $currentIP"
# Remove the # on next line to force an update every single time - useful for debugging,
# but you could end up getting blacklisted by DynDNS!
# Edit: Not really needed anymore... the result is not equal... Update will happen.
#:set dyndnsForce true
# Determine if dyndns update is needed
# more dyndns updater request details
http://www.dyndns.com/developers/specs/syntax.html
#This is where we check the DNS record against actual result. Thanks to jimstolz76
:if (($currentIP != $resolvedIP) || ($dyndnsForce = true)) do={
  :set dyndnsForce false
  :set previousIP $currentIP
  /tool fetch user=$username password=$password mode=http address="members.dyndns.org" \
  src-path="/nic/update?hostname=$hostname&myip=$currentIP" dst-path="/dyndns.txt"
  :local result [/file get dyndns.txt contents]
  :log info ("UpdateDynDNS: Dyndns update needed")
  :log info ("Update Result: " . $result)
  :put ("Dyndns Update Result: " . $result)
} else= {
  :log info ("UpdateDynDNS: No dyndns update needed")
