Pessoal ja olhei milhares de topicos e videos e nao conseguir resolver a conexao remota da minha RB, atualmente ela esta discando o PPPOE pro modem adsl que esta em bridged, e a RB esta recebendo o IP externo, eu consigo acessar a pagina ddns pela rede local mais por outra rede nao consigo acesso... meu script.
# No-IP User account info
:local noipuser "[email protected]"
:local noippass "******"
# Set the hostname or label of network to be updated.
# Hostnames with spaces are unsupported. Replace the value in the quotations below with your host names.
# To specify multiple hosts, separate them with commas.
:local noiphost "testando.zapto.org"
# Change to the name of interface that gets the dynamic IP address
:local inetinterface "2 - Velox"
# No more changes need
:global previousIP
# get the current IP address from the internet (in case of double-nat)
/tool fetch mode=http address="checkip.dyndns.org" src-path="/" dst-path="/dyndns.checkip.html"
:local result [/file get dyndns.checkip.html contents]
# parse the current IP result
:local resultLen [:len $result]
:local startLoc [:find $result ": " -1]
:set startLoc ($startLoc + 2)
:local endLoc [:find $result "</body>" -1]
:local currentIP [pick $result $startLoc $endLoc]
# :log info "UpdateDynDNS: currentIP = $currentIP"
:if ($currentIP != $previousIP) do={
:log info "No-IP: Current IP $currentIP is not equal to previous IP, update needed"
:set previousIP $currentIP
# The update URL. Note the "\3F" is hex for question mark (?). Required since ? is a special character in commands.
:local url "http://dynupdate.no-ip.com/nic/update\3Fmyip=$currentIP"
:local noiphostarray
:set noiphostarray [:toarray $noiphost]
:foreach host in=$noiphostarray do={
:log info "No-IP: Sending update for $host"
/tool fetch url=($url . "&hostname=$host") user=$noipuser password=$noippass mode=http dst-path=("no-ip_ddns_update-" . $host . ".txt")
:log info "No-IP: Host $host updated on No-IP with IP $currentIP"
} else={
:log info "No-IP: Previous IP $previousIP is equal to current IP, no update needed"
} else={
:log info "No-IP: $inetinterface is not currently running, so therefore will not update."
Eu consigo acesso na minha propria rede pelo endereço ddns porem externo não dá,, alguem pode me ajudar...
no log esta assim:
https://under-linux.org/attachment.p...810497&thumb=1
Uso modem ADSL e está em bridged, a RB esta discando e recebendo o IP externo....
por favor se alguem ajudar agradeço!!!
			 Rb 750 DDNS Via ADSL Velox nao autentica o DDNS
						 Citação
  Citação
						 Re: Rb 750 DDNS Via ADSL Velox nao autentica o DDNS
			 Postado originalmente por RobsonCostta
