    Question Script FW Mikrotik, ta certo?
    Galera meu firewall MK tá assim, tá certo? Falta algo? Criei de acordo que vi na net.
    Código :
    /ip firewall filteradd action=drop chain=input comment="Bloquear total acesso ao Winbox, exceto address list=Rede" dst-port=8291 protocol=tcp src-address-list=!Rede
    add action=add-src-to-address-list address-list=Syn_Flooder address-list-timeout=30m chain=input comment="Add Syn Flood IP to the list" connection-limit=30,32 protocol=tcp tcp-flags=syn
    add action=drop chain=input comment="Drop to syn flood list" src-address-list=Syn_Flooder
    add action=add-src-to-address-list address-list=Port_Scanner address-list-timeout=1w chain=input comment="Port Scanner Detect" protocol=tcp psd=21,3s,3,1
    add action=drop chain=input comment="Drop to port scan list" src-address-list=Port_Scanner
    add action=jump chain=input comment="Jump for icmp input flow" jump-target=ICMP protocol=icmp
    add action=jump chain=forward comment="Jump for icmp forward flow" jump-target=ICMP protocol=icmp
    add action=drop chain=forward comment="Drop to bogon list" dst-address-list=bogons
    add action=add-src-to-address-list address-list=spammers address-list-timeout=3h chain=forward comment="Add Spammers to the list for 3 hours" connection-limit=30,32 dst-port=25,587 limit=30/1m,0 protocol=tcp
    add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 protocol=tcp src-address-list=spammers
    add chain=forward comment="Libera porta 80." dst-port=80 protocol=tcp src-address=192.168.1.0/24
    add chain=forward comment="Libera porta 443(https)." dst-port=443 protocol=tcp src-address=192.168.1.0/24
    add chain=input comment="Aceita DNS - UDP" port=53 protocol=udp
    add chain=input comment="Aceita DNS - TCP" port=53 protocol=tcp
    add chain=input comment="Aceita Conexoes estabilizadas" connection-state=established
    add chain=input comment="Permitir Conexoes Relacionadas" connection-state=related
    add action=drop chain=input comment="Dropar conexoes invalidas" connection-state=invalid
    add chain=input comment="Libera acesso Rede ao Router e Internet" connection-state=new in-interface=Rede
    add action=drop chain=forward comment="Dropar conexoes invalidas" connection-state=invalid protocol=tcp
    add chain=forward comment="Permitir Conexoes ja estabelecidas" connection-state=established
    add chain=forward comment=Steam dst-port=27000-27015 protocol=udp
    add chain=forward comment=Steam dst-port=27015-27030 protocol=udp
    add chain=forward comment=Steam dst-port=27014-27050 protocol=tcp
    add chain=forward comment=Steam dst-port=27031-27036 protocol=udp
    add chain=forward comment=Steam dst-port=27036-27037 protocol=tcp
    add chain=forward comment=Steam dst-port=4380 protocol=udp
    add chain=forward comment=Steam dst-port=27015 protocol=tcp
    add chain=output comment=Steam dst-port=3478 protocol=udp
    add chain=output comment=Steam dst-port=4379 protocol=udp
    add chain=output comment=Steam dst-port=4380 protocol=udp
    add chain=input comment="Acesso Full address list=Rede" src-address-list=Rede
    add chain=forward comment="..::Libera ping::.." protocol=icmp src-address=192.168.1.0/24
    add action=drop chain=input comment="Dropar todo o resto"
    add action=drop chain=forward comment="::::::: Bloqueio Full ::::::::"
    add chain=ICMP comment="Echo request - Avoiding Ping Flood" icmp-options=8:0 limit=1,5 protocol=icmp
    add chain=ICMP comment="Echo reply" icmp-options=0:0 protocol=icmp
    add chain=ICMP comment="Time Exceeded" icmp-options=11:0 protocol=icmp
    add chain=ICMP comment="Destination unreachable" icmp-options=3:0-1 protocol=icmp
    add chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
    add action=drop chain=ICMP comment="Drop to the other ICMPs" protocol=icmp
    add action=jump chain=output comment="Jump for icmp output" jump-target=ICMP protocol=icmp
    Última edição por sn0wt; 24-08-2015 às 17:57.
    Padrão Re: Script FW Mikrotik, ta certo?
    Firewall se cria conforme a necessidade da rede, pode ter uma polita de drop, e liberar apenas oque precisa
    Pois é, é o que estou fazendo, mas essas ai são as básicas, chamadas de proteção do MK, pelo que estou estudando!!
    opa, tudo em ordem?
    Notei varias inconsistências, mas vamos pelo básico:
    Para uma config. de rede mais simples, acho mais interessante definir a interface outside. Ficaria assim:
    add action=drop chain=input comment="Bloquear total acesso ao Winbox da internet" dst-port=8291 protocol=tcp in-interface=internet
    E para brincar um pouco, dá pra permitir o acesso a esta porta vindo da internet criando regra pra adicionar o IP entrante a uma lista quando ele tentar se conectar a uma porta alta especifica e outra regra liberando o acesso a porta do winbox para aquela lista.
    Eu prefiro trocar a porta para uma acima de 50000 e pronto. Contanto que a regra de acesso fique abaixo da regra de bloqueio de port scan.
    Está faltando regras de condição para esta regra.
    certifique que em IP-DNS esteja desativado Allow Remote Requests ou coloque um in-interface=!internet. Falta o action.
    Esta regra poderia morrer. A nao ser que vc tenha um servidor dns em casa que faça transferencia de zona.
    Edit: vi que sua regra é de input... pode matar, sem dó.
    Voce pode matar uma dessas regras e reconfigurar a outra para que que aceite ambas related e estabilished. Só não esqueça da action, que está faltando acima.
    Otimize as regras adicionando as portas em uma mesma regra usando virgula para portas diversas ou hifen para ranges.
    As regras são tratadas no modo TOP->DOWN, mas o routerOS possui as chains, que também possuem sequência de tratamento. Então, a sua ordem das regras não estão erradas, mas como Best Practice, organize elas para sua melhor compreensão e para uma possível redução de processamento(que voce não vai notar, por não ter muitas conexões). Um exemplo são suas regras de ICMP, as regras de jump estão quase no topo e as regras de condiçoes estáo no final. Não está errado, mas fica horrível de compreender, ainda mais que o routerOS não é um CheckPoint onde você pode ver onde estão aplicados os objetos. :-)
    abraço!
