Boa tarde,
Alguém saberia me responder qual o limite máximo de throughput que a rb951g-2hnd suporta ?
Vlw !!!
Boa tarde,
Vlw !!!
Performance test results
RB951G-2HnD AR9344 1G all port test Mode Configuration 1518 byte 512 byte 64 byte kpps Mbps kpps Mbps kpps Mbps Bridging none (fast path) 81.0 983.7 232.0 950.3 269.6 138.0 Bridging 25 bridge filter rules 81.0 983.7 86.0 352.3 87.6 44.9 Routing none (fast path) 81.0 983.7 210.0 860.2 226.9 116.2 Routing 25 simple queues 81.0 983.7 103.9 425.6 106.6 54.6 Routing 25 ip filter rules 56.8 689.8 59.6 244.1 60.5 31.0
- All tests are done with Xena Networks specialized test equipment (XenaBay),and done according to RFC2544 (Xena2544)
 - Max throughput is determined with 30+ second attempts with 0,1% packet loss tolerance in 64, 512, 1518 byte packet sizes
 - Values in Italic indicate that max throughput was reached without maxing out CPU, but because board interface configuration was maxed out
 - Test results show device maximum performance, and are reached using mentioned hardware and software configuration, different configurations most likely will result in lower results
