Tenho um balance pcc na minha loja e um roteador na minha casa.
Todas as minhas 6 internet disconectan 24h apos eu ter conectado manualmente,e todo dia no mesmo horário acontece a mesma coisa.. Uso algar telecom gostaria de saber se isso e uma rotina da empresa ou do mikrotik.
Obs... Ja disconectei manualmente a adsl... Em horarios variados e a mesma volta a disconectar 24h depois sozinha...
jun/29 06:46:24 pppoe,ppp,info pppoe-out4: terminating...
jun/29 06:46:24 pppoe,ppp,info pppoe-out4: disconnected
jun/29 06:46:24 pppoe,ppp,info pppoe-out4: initializing...
jun/29 06:46:24 pppoe,ppp,info pppoe-out4: connecting...
jun/29 06:46:27 pppoe,ppp,info pppoe-out4: authenticated
jun/29 06:46:28 pppoe,ppp,info pppoe-out4: connected
jun/29 06:47:37 pppoe,ppp,info pppoe-out5: terminating...
jun/29 06:47:37 pppoe,ppp,info pppoe-out5: disconnected
jun/29 06:47:37 pppoe,ppp,info pppoe-out5: initializing...
jun/29 06:47:37 pppoe,ppp,info pppoe-out5: connecting...
jun/29 06:47:41 pppoe,ppp,info pppoe-out5: authenticated
jun/29 06:47:41 pppoe,ppp,info pppoe-out5: connected
jun/29 06:48:49 pppoe,ppp,info pppoe-out3: terminating...
jun/29 06:48:49 pppoe,ppp,info pppoe-out3: disconnected
jun/29 06:48:49 pppoe,ppp,info pppoe-out3: initializing...
jun/29 06:48:49 pppoe,ppp,info pppoe-out3: connecting...
jun/29 06:48:52 pppoe,ppp,info pppoe-out3: authenticated
jun/29 06:48:52 pppoe,ppp,info pppoe-out3: connected
jun/29 06:49:29 pppoe,ppp,info pppoe-out2: terminating...
jun/29 06:49:29 pppoe,ppp,info pppoe-out2: disconnected
jun/29 06:49:30 pppoe,ppp,info pppoe-out2: initializing...
jun/29 06:49:30 pppoe,ppp,info pppoe-out2: connecting...
jun/29 06:49:38 pppoe,ppp,info pppoe-out2: authenticated
jun/29 06:49:38 pppoe,ppp,info pppoe-out2: connected
jun/29 06:50:29 pppoe,ppp,info pppoe-out1: terminating...
jun/29 06:50:29 pppoe,ppp,info pppoe-out1: disconnected
jun/29 06:50:29 pppoe,ppp,info pppoe-out1: initializing...
jun/29 06:50:29 pppoe,ppp,info pppoe-out1: connecting...
jun/29 06:50:38 pppoe,ppp,info pppoe-out1: authenticated
jun/29 06:50:38 pppoe,ppp,info pppoe-out1: connected
Toda minha comfig caso alguem queira olhar
# jul/04/2016 01:04:43 by RouterOS 6.34.1
# software id = 07TA-R0A5
/interface ethernet
set [ find default-name=sfp1 ] comment=Fibra disabled=yes name=Fibra
set [ find default-name=ether1 ] comment=\
"#######################Portas giga lan#######################"
set [ find default-name=ether5 ] comment=\
"#######################Link Balanceado#######################" name=\
"ether5 Balance"
set [ find default-name=ether6 ] comment=\
"#######################Portas Fast Eternet#######################" name=\
"ether6 Net-01"
set [ find default-name=ether7 ] name="ether7 Net-02"
set [ find default-name=ether8 ] name="ether8 Net-03"
set [ find default-name=ether9 ] name="ether9 Net-04"
set [ find default-name=ether10 ] name="ether10 Net-05"
/interface pppoe-client
add allow=pap comment=\
"#######################PPPOE Clientes#######################" disabled=\
no interface="ether6 Net-01" name=pppoe-out1 password=teste user=teste
add allow=pap disabled=no interface="ether7 Net-02" name=pppoe-out2 password=\
algar [email protected]
add allow=pap disabled=no interface="ether8 Net-03" name=pppoe-out3 password=\
add allow=pap disabled=no interface="ether9 Net-04" name=pppoe-out4 password=\
add allow=pap disabled=no interface="ether10 Net-05" name=pppoe-out5 \
password=algar [email protected]
/ip neighbor discovery
set Fibra comment=Fibra
set ether1 comment=\
set "ether5 Balance" comment=\
set "ether6 Net-01" comment=\
set pppoe-out1 comment=\
"#######################PPPOE Clientes#######################" discover=\
no
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
/ip pool
add name=pool1 ranges=10.2.2.2
/ip dhcp-server
add address-pool=pool1 disabled=no interface="ether5 Balance" name=server1
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
/ip address
add address=10.2.2.1/24 interface="ether5 Balance" network=10.2.2.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid
/ip dns
set allow-remote-requests=yes cache-size=4096KiB max-udp-packet-size=512 \
servers=8.8.8.8,8.8.4.4,189.38.95.95
/ip firewall address-list
add address=192.168.0.71 list=Vips
add address=192.168.0.72 list=Vips
add address=192.168.0.73 list=Vips
add address=192.168.0.74 list=Vips
add address=192.168.0.75 list=Vips
add address=192.168.0.76 list=Vips
add address=192.168.0.48 list=Vips
add address=192.168.0.11 list=Vips
add address=192.168.0.12 list=Vips
add address=192.168.0.13 list=Vips
add address=192.168.0.14 list=Vips
add address=192.168.0.15 list=Vips
add address=192.168.0.16 list=Vips
add address=192.168.0.10 comment=\
#############################LAN-HAUSE############################# list=\
Vips
/ip firewall mangle
add action=mark-routing chain=prerouting comment=\
##############################VIP############################## \
new-routing-mark=Rota5 passthrough=no src-address-list=Vips
"############################# Balance pcc #########################" \
dst-address-type=!local new-routing-mark=Rota1 passthrough=no \
per-connection-classifier=both-addresses:9/0
add action=mark-routing chain=prerouting dst-address-type=!local \
new-routing-mark=Rota2 passthrough=no per-connection-classifier=\
both-addresses:9/1
new-routing-mark=Rota3 passthrough=no per-connection-classifier=\
both-addresses:9/2
new-routing-mark=Rota4 passthrough=no per-connection-classifier=\
both-addresses:9/3
new-routing-mark=Rota5 passthrough=no per-connection-classifier=\
both-addresses:9/4
new-routing-mark=Rota1 passthrough=no per-connection-classifier=\
both-addresses:9/5
both-addresses:9/6
both-addresses:9/7
both-addresses:9/8
/ip firewall nat
add action=dst-nat chain=dstnat comment="Regirecionar dns" disabled=yes \
dst-port=53 protocol=tcp to-addresses=192.168.0.1 to-ports=53
dst-port=53 protocol=udp to-addresses=192.168.0.1 to-ports=53
add chain=dstnat disabled=yes dst-port=53 in-interface="ether5 Balance" \
protocol=udp
add action=masquerade chain=srcnat out-interface="!ether5 Balance"
/ip proxy
set cache-path=web-proxy1 max-cache-size=none parent-proxy=0.0.0.0
/ip route
add check-gateway=ping distance=1 gateway=pppoe-out4 routing-mark=Rota4
add check-gateway=ping comment="#############################Rotas Balance pcc\
#############################" distance=1 gateway=pppoe-out1 \
routing-mark=Rota1
add check-gateway=ping distance=1 gateway=pppoe-out2 routing-mark=Rota2
add check-gateway=ping distance=1 gateway=pppoe-out3 routing-mark=Rota3
add check-gateway=ping distance=1 gateway=pppoe-out5 routing-mark=Rota5
#############################" distance=2 gateway=pppoe-out1
add check-gateway=ping distance=3 gateway=pppoe-out2
add check-gateway=ping distance=4 gateway=pppoe-out3
add check-gateway=ping distance=5 gateway=pppoe-out4
add check-gateway=ping distance=6 gateway=pppoe-out5
add distance=1 dst-address=10.0.0.0/8 gateway=10.2.2.2
add distance=1 dst-address=172.16.0.0/12 gateway=10.2.2.2
add comment="#############################ROTAS IP PRIVADO####################\
#########" distance=1 dst-address=192.168.0.0/16 gateway=10.2.2.2
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.0.49/32
set ssh disabled=yes
set www-ssl certificate=cert_1
set api disabled=yes
set api-ssl disabled=yes
/lcd
set backlight-timeout=never default-screen=informative-slideshow \
read-only-mode=yes touch-screen=disabled
/lcd interface pages
set 0 interfaces="Fibra,ether1,ether2,ether3,ether4,ether5 Balance,ether6 Net-\
01,ether7 Net-02,ether8 Net-03"
/system clock
set time-zone-autodetect=no
/system clock manual
set time-zone=-03:00
/system identity
set name=Balance
/system scheduler
add comment="Scheduler for daily backup of MT" interval=1d name=daily-backup \
on-event=backup policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=\
jan/01/1970 start-time=03:10:00
/system script
add name=backup owner=?????????? policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive source="# Mikro\
tik Backup Script for Mikrotik 6.x Series, well tested with 6.3x.x\r\
\n# Syed Jahanzaib / [email protected] / https://aacable.wordpress.com\r\
\n# SCRIPT LAST MODIFIED : 18-JAN-2016\r\
\n \r\
\n:log warning \"Mikrotik Router Backup JOB Started . . . Powered by Syed \
Jahanzaib\"\r\
\n:local backupfile mt_config_backup\r\
\n:local mikrotikexport mt_export_backup\r\
\n:local sub1 ([/system identity get name])\r\
\n:local sub2 ([/system clock get time])\r\
\n:local sub3 ([/system clock get date])\r\
\n:local company \"ZAIB Pvt Ltd\"\r\
\n:local adminmail1 [email protected]\r\
\n \r\
\n# GMAIL SMTP DYNAMIC Config Section, Make sure to change these values to\
\_match your's / Jz\r\
\n:local gmailid ????????????\r\
\n:local gmailuser ???????????\r\
\n:local gmailpwd xxxxxxxx\r\
\n:local gmailport 587\r\
\n \r\
\n:local gmailsmtp\r\
\n:set gmailsmtp [:resolve \"smtp.gmail.com\"];\r\
\n \r\
\n# Setting gmail options in tool email as well, useful when u dont have c\
onfigured toosl email option\r\
\n/tool e-mail set address=\$gmailsmtp port=\$gmailport start-tls=yes from\
=\$gmailid user=\$gmailuser password=\$gmailpwd\r\
\n \r\
\n:log warning \"\$company : Creating new up to date backup files . . . \"\
\r\
\n \r\
\n# Start creating Backup files backup and export both\r\
\n/system backup save name=\$backupfile dont-encrypt=yes\r\
\n/export file=\$mikrotikexport\r\
\n \r\
\n:log warning \"\$company : Backup JOB process pausing for 30s so it can \
complete creating backup. Usually for Slow systems ...\"\r\
\n:delay 30s\r\
\n \r\
\n:log warning \"Backup JOB is now sending Backup File via Email using GMA\
IL SMTP . . .\"\r\
\n \r\
\n# Start Sending email files, make sure you ahve configured tools email s\
ection before this. or else it will fail\r\
\n/tool e-mail send to=\$adminmail1 subject=\"\$sub3 \$sub2 \$sub1 Configu\
ration BACKUP File\" file=\$backupfile start-tls=yes\r\
ration EXPORT File\" file=\$mikrotikexport start-tls=yes\r\
\n \r\
\n:log warning \"\$company : BACKUP JOB: Sleeping for 600 seconds so email\
\_can be delivered, \"\r\
\n:delay 600s\r\
\n \r\
\n# REMOVE Old backup files to save space.\r\
\n/file remove \$backupfile\r\
\n/file remove \$mikrotikexport\r\
\n \r\
\n# Print Log for done\r\
\n:log warning \"\$company : Backup JOB: Process Finished & Backup File Re\
moved. All Done. You should verify your inbox for confirmation, Regard's S\
yed Jahanzaib\"\r\
\n \r\
\n# Script END"
/tool e-mail
set address=??????????? from=????????????password=???????????? \
port=587 start-tls=yes user=????????????
/tool graphing interface
add
add allow-address=192.168.0.49/32 interface="ether5 Balance"
/tool graphing queue
/tool graphing resource
add
/tool romon port
add
/tool traffic-monitor
add interface=pppoe-out1 name=tmon1 threshold=0
add interface=pppoe-out2 name=tmon2 threshold=0
