    Padrão Duvida em VPN no Centos 7
    Boa noite pessoal,
    Estou com o seguinte cenário, tenho que fazer um servidor AD (Samba4) em uma cloud na AWS e conectar ela em minhas filiais, para fazer propagar o DNS via vpn nos mikoritk. Segue o esboço:
    SERVER-AD:
    /etc/hosts
    #::1 localhost localhost.localdomain localhost6 localhost6.localdomain6127.0.0.1 localhost localhost.localdomain localhost4 localhost4.localdomain4
    127.0.0.1 s1.athenas.local s1 athenas.local
    172.31.12.155 s1.athenas.local s1 athenas.local
    /etc/resolv.conf
    ; generated by /usr/sbin/dhclient-script#search sa-east-1.compute.internal
    search athenas.local
    domain athenas.local
    nameserver 172.31.12.155
    nameserver 8.8.8.8
    #nameserver 172.31.0.2
    /etc/named.conf
    options { listen-on port 53 { 127.0.0.1;any; };
    tkey-gssapi-keytab "/var/lib/samba/bind-dns/dns.keytab";
    listen-on-v6 port 53 { ::1; };
    forwarders { 172.31.12.155; 10.255.255.1; };
    directory "/var/named";
    dump-file "/var/named/data/cache_dump.db";
    statistics-file "/var/named/data/named_stats.txt";
    memstatistics-file "/var/named/data/named_mem_stats.txt";
    recursing-file "/var/named/data/named.recursing";
    secroots-file "/var/named/data/named.secroots";
    allow-query { localhost;any; };
    - If you are building an AUTHORITATIVE DNS server, do NOT enable recursion.
    - If you are building a RECURSIVE (caching) DNS server, you need to enable
    recursion.
    - If your recursive DNS server has a public IP address, you MUST enable access
    control to limit queries to your legitimate users. Failing to do so will
    cause your server to become part of large scale DNS amplification
    attacks. Implementing BCP38 within your network would greatly
    reduce such attack surface
    recursion yes;
    dnssec-enable yes;
    dnssec-validation yes;
    /* Path to ISC DLV key */
    bindkeys-file "/etc/named.iscdlv.key";
    managed-keys-directory "/var/named/dynamic";
    pid-file "/run/named/named.pid";
    session-keyfile "/run/named/session.key";
    logging {
    channel default_debug {
    file "data/named.run";
    severity dynamic;
    zone "." IN {
    type hint;
    file "named.ca";
    include "/etc/named.rfc1912.zones";
    include "/etc/named.root.key";
    include "/var/lib/samba/bind-dns/named.conf";
    /etc/xl2tpd/xl2tpd.conf
    [global]port = 1701
    [lns default]
    ;ip range = 10.255.252.10-10.255.255.100
    ;local ip = 10.255.255.1
    ip range = 172.31.12.180-172.31.15.200
    local ip = 172.31.12.155
    require chap = yes
    refuse pap = yes
    require authentication = yes
    name = l2tpd
    pppoptfile = /etc/ppp/options.xl2tpd
    length bit = yes
    /etc/ipsec.conf
    version 2.0
    config setup
    virtual-private=%v4:10.0.0.0/8,%v4:192.168.0.0/16,%v4:172.16.0.0/12,%v4:!192.168.42.0/24,%v4:!192.168.43.0/24
    protostack=netkey
    interfaces=%defaultroute
    uniqueids=no
    plutoopts=“--interface=eth0”
    conn shared
    left=%defaultroute
    leftid=MEU-IP-PUBLICO
    right=%any
    encapsulation=yes
    authby=secret
    pfs=no
    rekey=no
    keyingtries=5
    dpddelay=30
    dpdtimeout=120
    dpdaction=clear
    ike=aes256-sha2,aes128-sha2,aes256-sha1,aes128-sha1,aes256-sha2;modp1024,aes128-sha1;modp1024
    phase2alg=aes_gcm-null,aes128-sha1,aes256-sha1,aes256-sha2_512,aes128-sha2,aes256-sha2
    sha2-truncbug=yes
    conn l2tp-psk
    auto=add
    leftprotoport=17/1701
    rightprotoport=17/%any
    type=transport
    phase2=esp
    also=shared
    conn xauth-psk
    auto=add
    leftsubnet=0.0.0.0/0
    #rightaddresspool=10.255.255.10-10.255.255.100
    rightaddresspool=172.31.12.180-172.31.15.200
    modecfgdns="8.8.8.8 8.8.4.4"
    leftxauthserver=yes
    rightxauthclient=yes
    leftmodecfgserver=yes
    rightmodecfgclient=yes
    modecfgpull=yes
    xauthby=file
    ike-frag=yes
    ikev2=never
    cisco-unity=yes
    also=shared
    Agora é a configuração do meu mikrotik:
Nome:	         08-5-2019_21-09-14.jpg
Visualizações:	197
Tamanho: 	21,5 KB
    Consigo pingar dentro do MK, mas não consigo pingar dentro da minha maquina.
Nome:	         08-5-2019_21-10-15.jpg
Visualizações:	234
Tamanho: 	25,7 KB
Nome:	         08-5-2019_21-10-50.jpg
Visualizações:	239
Tamanho: 	8,2 KB
    Configurações do mikrotik:
Nome:	         08-5-2019_21-11-07.jpg
Visualizações:	189
Tamanho: 	12,0 KB
    Como poderia da melhor maneira, fazer esse AD(Samba4) funcionar via VPN ?
    Padrão Re: Duvida em VPN no Centos 7
    O problema aí é de roteamento. Já tive um caso desses mas não me lembro qual arquivo mexi.
    Você teria duas opções para fazer funcionar:
    1) fazer nat para acessar o CentOS. Fácil e funciona mas para o CentOS acaba aparecendo só o IP do mikrotik que está fechando a VPN. Dependendo do cenário, não é legal.
    2) Adicionar rotas estáticas ou rodar OSPF na subrede que fecha a vpn para que o servidor consiga alcançar as redes internas das filiais.
    Pensei em fechar VPN em todos os mikrotiks, onde está instalado o samba é o l2tp server e os mikrotis sao os clientes, consegui conexão com o samba via vpn, porém tem hora que o meu dominio se resolve para o ip externo e tem hora para o ip interno e também o named (servidor DNS ) está demorando muito para resolver os dominios.
    Estou usando o BIND9_DLZ ao invez do SAMBA INTERNAL, oque vocês me recomendam ?
