    Lightbulb Unbound Dns no Debian
    Ola galera preciso de um Help, instalei o Debian e levantei o serviço do unbound dns fiz todo processo porem percebo que não esta resolvendo meu DNS e minhas num.queries nao passa de 0,
    https://under-linux.org/image/png;ba...AAAElFTkSuQmCC
    segui esse tutorial : http://tutoriaisredes.blogspot.com/2...s-unbound.html
    Padrão Re: Unbound Dns no Debian
    Posta seu unbound.conf p dar uma olhada...
    Citação Postado originalmente por Pedro H Almeida Ver Post
    server:
    port: 53
    interface: 0.0.0.0
    access-control: 0.0.0.0/0 refuse
    access-control: 10.0.0.0/8 allow
    access-control: 100.64.0.0/10 allow
    access-control: 172.16.0.0/12 allow
    access-control: 192.168.0.0/16 allow
    access-control: 127.0.0.0/8 allow
    verbosity: 1
    num-threads: 4
    outgoing-range: 8192
    num-queries-per-thread: 4096
    so-rcvbuf: 4m
    so-sndbuf: 4m
    cache-max-ttl: 86400
    cache-min-ttl: 0
    infra-host-ttl: 900
    infra-cache-slabs: 2
    infra-cache-numhosts: 432000
    key-cache-size: 4
    neg-cache-size: 1
    msg-cache-slabs: 2
    rrset-cache-slabs: 2
    key-cache-slabs: 2
    rrset-cache-size: 200m
    msg-cache-size: 4000m
    do-ip4: yes
    do-ip6: yes
    do-udp: yes
    do-tcp: yes
    do-daemonize: yes
    module-config: "iterator"
    local-data: "localhost A 127.0.0.1"
    local-data-ptr: "127.0.0.1 localhost"
    root-hints: "/etc/unbound/named.cache"
    use-syslog: yes
    logfile: "/etc/unbound/unbound.log"
    pidfile: "/var/run/unbound.pid"
    hide-identity: yes
    hide-version: yes
    # DNSSEC validation usind the root trust anchor.
    auto-trust-anchor-file: "/var/lib/unbound/root.key"
    remote-control:
    control-enable: yes
    control-interface: 127.0.0.1
    control-port: 8953
    Última edição por Andersonseifert; 10-06-2020 às 08:57. Razão: Envio invalido, porem corrigido.
    Citação Postado originalmente por Andersonseifert Ver Post
    server:
    port: 53
    interface: 0.0.0.0
    verbosity: 1
    num-threads: 4
    so-rcvbuf: 4m
    so-sndbuf: 4m
    cache-min-ttl: 0
    infra-host-ttl: 900
    key-cache-size: 4
    neg-cache-size: 1
    msg-cache-slabs: 2
    key-cache-slabs: 2
    do-ip4: yes
    do-ip6: yes
    do-udp: yes
    do-tcp: yes
    do-daemonize: yes
    use-syslog: yes
    hide-identity: yes
    hide-version: yes
    remote-control:
    control-enable: yes
    control-port: 8953
    Bom dia, tenta sem essa linda de configuração.
Nome:	         refu.png
Visualizações:	201
Tamanho: 	6,0 KB
