    Padrão Erro em tudo que tenta compilar !!!!!!!!!!!!!HEEEEELLLLPPP!!
    sempre que tento usar ./configure para compilar qualquer coisa
    dá este mesmo erro:
    [[email protected] xmms-1.2.7]# ./configure
    loading cache ./config.cache
    checking host system type... i686-pc-linux-gnu
    checking for a BSD compatible install... /usr/bin/install -c
    checking whether build environment is sane... yes
    checking whether make sets ${MAKE}... yes
    checking for working aclocal... missing
    checking for working autoconf... missing
    checking for working automake... missing
    checking for working autoheader... missing
    checking for working makeinfo... missing
    checking for prefix by checking for xmms... /usr/bin/xmms
    checking for gcc... gcc
    checking whether the C compiler (gcc ) works... no
    configure: error: installation or configuration problem: C compiler cannot create executables.
    tenho os gcc´s instalados:
    [[email protected] netscape-installer]# rpm -qa | grep gcc
    gcc2.95-2.95.3-36cl
    gcc-2.95.3-36cl
    O QUE POSSO FAZER ??!?!?!?!?!?!?!?!?!!? <IMG SRC="images/forum/smilies/icon_evil.gif">
    lippe
    tenta instalar os sources do kernel
    kernel-source.x.x.x
