- problema com cdrom
problema com cdrom
Opá galera legal mais uma vez eu estou pedindo uma força a vcs do forum estou com um problema não consigo acessar meu cdrom procurei algumas informações e quando eu do o seguinte comando dmesg aparece isso ai ow se alguem puder me ajudar eu agradeço até mais valeu ..
hda: command error: error=0x50
end_request: I/O error, dev 03:00 (hda), sector 6
Uniform CD-ROM driver unloaded
SUPERMOUNT error (device 0/13): supermount_read_super: no dev=<filesystem> option
SUPERMOUNT error (device 0/14): supermount_read_super: no dev=<filesystem> option
SUPERMOUNT error (device 0/15): supermount_read_super: no dev=<filesystem> option
ide-floppy driver 0.97.sv
hda: ATAPI 40X CD-ROM drive, 128kB Cache
Uniform CD-ROM driver Revision: 3.12
hda: command error: status=0x51 { DriveReady SeekComplete Error }
end_request: I/O error, dev 03:00 (hda), sector 64
isofs_read_super: bread failed, dev=03:00, iso_blknum=16, block=32
SUPERMOUNT error (device 0/16): supermount_read_super: no dev=<filesystem> option
SUPERMOUNT error (device 0/17): supermount_read_super: no dev=<filesystem> option
end_request: I/O error, dev 03:00 (hda), sector 0
end_request: I/O error, dev 03:00 (hda), sector 2
end_request: I/O error, dev 03:00 (hda), sector 4
SUPERMOUNT error (device 0/20): supermount_read_super: no dev=<filesystem> option
SUPERMOUNT error (device 0/21): supermount_read_super: no dev=<filesystem> option
SUPERMOUNT error (device 0/22): supermount_read_super: no dev=<filesystem> option
FAT: unable to read boot sector
SUPERMOUNT error (device 0/23): supermount_read_super: no dev=<filesystem> option
SUPERMOUNT error (device 0/29): supermount_read_super: no dev=<filesystem> option
CSLIP: code copyright 1989 Regents of the University of California
PPP generic driver version 2.4.1
PPP BSD Compression module registered
PPP Deflate Compression module registered
SUPERMOUNT error (device 0/30): supermount_read_super: no dev=<filesystem> option
SUPERMOUNT error (device 0/31): supermount_read_super: no dev=<filesystem> option
cdrom: open failed.
cdrom: open failed.
cdrom: open failed.
Unable to identify CD-ROM format.
problema com cdrom
Meo, depois disso ele entra normalmente? Seu linux eh um super-heroi..
Aparentemente nao eh soh um errinho nao, escuta, voce mexeu no kernel antes de acontecer isso?
problema com cdrom
OPá blz ..
Eu não mexi no kernel não ...
Fui colocar minha partição fat para inicializar no boot pelo Linuxconf depois disso ficou assim
poxa eu novato.. ainda não tô acostumado a usar bastante modo texto, tem coisas q tenho q usar o Linuxconf <IMG SRC="images/forum/icons/icon_smile.gif"> ok.. ele funciona normal tudo só o cdrom q não.. valeu ..
problema com cdrom
Apartir dai ja nao sei mais, BugHat-like nao eh comigo meeeesmo..
problema com cdrom
cara ponha a configuração do fstab
e qual é seu linux se for conectiva vc tem que colocar auto no tipo naum vfat
AndrewAmorimdaSilva
problema com cdrom
Se for RedHat8, desinstale o pacote magicdev, tipo muito problemas parecidos com o gravador de cd.....
Um abraço! <IMG SRC="images/forum/icons/icon_razz.gif">
problema com cdrom
Ai agradeço a todos q deram uma força valeu ok....valeu mesmo eu estou com o conectiva 8 blz .. Deu certo....
[]os até mais
kras vcs são d+ não sei como agradecer ....
problema com cdrom
Agradeca sempre ajudando os outros membros da comunidade =)
