    Kernel_Panic
    Padrão Iptables ! ! ! HELP ME
    é o seguinte galera . . . inclui umas regras no meu firewall . . .
    iptables -t nat -A PREROUTING -d 172.0.0.0/255.0.0.0 -i eth0 -j DNAT --to 10.0.0.1
    iptables -t nat -A POSTROUTING -s 10.0.0.0/255.255.255.0 -o eth0 -j SNAT --to 172.0.0.1
    blz a internet funciona so que está liberado tudo . .certo entao inclui as seguintes regras
    iptables -A FORWARD -s 127.0.0.1 -j ACCEPT
    iptables -A FORWARD -p tcp --dport 22 -j ACCEPT
    iptables -A FORWARD -p udp --dport 22 -j ACCEPT
    iptables -A FORWARD -p tcp --dport 21 -j ACCEPT
    iptables -A FORWARD -p udp --dport 21 -j ACCEPT
    iptables -A FORWARD -p tcp --dport 25 -j ACCEPT
    iptables -A FORWARD -p udp --dport 25 -j ACCEPT
    iptables -A FORWARD -p tcp --dport 80 -j ACCEPT
    iptables -A FORWARD -p udp --dport 80 -j ACCEPT
    iptables -A FORWARD -p tcp --dport 110 -j ACCEPT
    iptables -A FORWARD -p udp --dport 110 -j ACCEPT
    iptables -A FORWARD -p tcp --dport 1080 -j ACCEPT
    iptables -A FORWARD -p udp --dport 1080 -j ACCEPT
    iptables -A FORWARD -p tcp --dport 3128 -j ACCEPT
    iptables -A FORWARD -p udp --dport 3128 -j ACCEPT
    e depois
    iptables -A INPUT -s 127.0.0.1 -j ACCEPT
    iptables -A INPUT -p tcp --dport 22 -j ACCEPT
    iptables -A INPUT -p udp --dport 22 -j ACCEPT
    iptables -A INPUT -p tcp --dport 21 -j ACCEPT
    iptables -A INPUT -p udp --dport 21 -j ACCEPT
    iptables -A INPUT -p tcp --dport 25 -j ACCEPT
    iptables -A INPUT -p udp --dport 25 -j ACCEPT
    iptables -A INPUT -p tcp --dport 80 -j ACCEPT
    iptables -A INPUT -p udp --dport 80 -j ACCEPT
    iptables -A INPUT -p tcp --dport 110 -j ACCEPT
    iptables -A INPUT -p udp --dport 110 -j ACCEPT
    iptables -A INPUT -p tcp --dport 1080 -j ACCEPT
    iptables -A INPUT -p udp --dport 1080 -j ACCEPT
    iptables -A INPUT -p tcp --dport 3128 -j ACCEPT
    iptables -A INPUT -p udp --dport 3128 -j ACCEPT
    blz mais todo mundo ainda accessa tudo . . entaum coloco
    iptables -P INPUT DROP
    blz ta funcionando a internet . . .ai quando insiro
    iptables -P FORWARD DROP
    ele trava tudo . . . O QUE ESTA ACONTECENDO ? ? ? ?
    <IMG SRC="images/forum/icons/icon_mad.gif">
    Futuremax
    Tá faltando as linhas
    iptables -A FORWARD -m state --state ESTABLISHED,RELATED -j ACCEPT
    iptables -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
    Devem ser as primeiras regras a serem colocadas logo após o DROP que tem que vir primeiro, depois vc libera o que quizer....
    <IMG SRC="images/forum/icons/icon_wink.gif">
    pensador-ce
    cria um script deste modo e coloca os endereços de sua rede, é bem simples mais funciona.
    #! /bin/sh
    # carga do iptable
    case "$1" in
    start)
    modprobe ipt_MASQUERADE
    modprobe ip_nat_ftp
    modprobe ip_conntrack_ftp
    # Bloqueia a porta 80
    iptables -t nat -A PREROUTING -j DROP -p tcp --dport 80
    iptables -t nat -A PREROUTING -j DROP -p tcp --dport 1214
    iptables -t nat -A PREROUTING -j DROP -p tcp --dport 1340
    iptables -t nat -A PREROUTING -j DROP -p tcp --dport 1341
    # Mascaramento da placa eth1
    iptables -t nat -A POSTROUTING -s 192.168.45.0/24 -j MASQUERADE
    iptables -A FORWARD -s 192.168.45.0/24 -j ACCEPT
    iptables -A FORWARD -d 192.168.45.0/24 -j ACCEPT
    # Mascaramento da placa eth1:0
    iptables -t nat -A POSTROUTING -s 172.16.0.0/16 -j MASQUERADE
    iptables -A FORWARD -s 172.16.0.0/16 -j ACCEPT
    iptables -A FORWARD -d 172.16.0.0/16 -j ACCEPT
    # Mascaramento da placa eth1:1
    iptables -t nat -A POSTROUTING -s 172.45.0.0/16 -j MASQUERADE
    iptables -A FORWARD -s 172.45.0.0/16 -j ACCEPT
    iptables -A FORWARD -d 172.45.0.0/16 -j ACCEPT
    # Mascaramento da placa eth1:2
    iptables -t nat -A POSTROUTING -s 172.23.0.0/16 -j MASQUERADE
    iptables -A FORWARD -s 172.23.0.0/16 -j ACCEPT
    iptables -A FORWARD -d 172.23.0.0/16 -j ACCEPT
    echo -n "Starting Firewall:"
    return=$rc_failed
    sleep 1
    echo -e "$return"
    stop)
    echo -n "Shutting down Firewall:"
    iptables -F -t nat
    iptables -F
    status)
    echo -n "Checking for Firewall: "
    iptables -L
    iptables -L -t nat
    restart)
    $0 stop && $0 start || return=$rc_failed
    echo "Usage: $0 {start|stop|status|restart}"
    exit 1
    esac
    <IMG SRC="images/forum/icons/icon_biggrin.gif">
    Kernel_Panic
    Futuremaxx . .
    eu coloquei essa linha e blz ta dropando tudo , valeu . so que temos um problema depois de uns 10 minutos ele perde a conexão ! ! !
    o que acontece ! ! !
