    Moderador Avatar de Bruno
    Nov 2002
    Guarapuava-PR
    Padrão programa para lan house
    e ai andre agora sim
    como asim compila o qt
    vc pode me ensinar paso a passo ?
    tar -zxvf qtXXXXX
    cd qtXXXX
    ./configure
    make
    make install
    mas vc jah deve ter o qt instalado... ele jah vem com o conectiva
    tenta ai rpm -qi qt
    aaa aki tem o qt em RPM caso vc num tenha ele instalado:
    http://rpmfind.net/linux/rpm2html/search.php?query=qt
    Nov 2002
    Guarapuava-PR
    olha eu abaixei ele em tgz
    [[email protected] qt-x11-free-3.1.1]# ./configure
    WARNING: /usr/lib/libGL.so.1 is threaded!
    The Qt OpenGL module requires Qt to be configured with -thread.
    This is the Qt/X11 Free Edition.
    You are licensed to use this software under the terms of either
    the Q Public License (QPL) or the GNU General Public License (GPL).
    Type ´Q´ to view the Q Public License.
    Type ´G´ to view the GNU General Public License.
    Type ´yes´ to accept this license offer.
    Type ´no´ to decline this license offer.
    Do you accept the terms of either license?
    ué digita yes e da enter!!!
    Nov 2002
    Guarapuava-PR
    sim eu gitei yes
    Nov 2002
    Guarapuava-PR
    eu isntalei ele e agora
    agora instala o programa q o andrew te passou...
    Nov 2002
    Guarapuava-PR
    como instala o zebe
    ué..... eu nem sei q programa eh esse <IMG SRC="images/forum/icons/icon_razz.gif">
    ele eh .tar.gz tb?? se for eh do mesmo jeito q o qt...
    Nov 2002
    Guarapuava-PR
    eu descompactei ele
    da uma olhada no install.txt dele
    Getting the Code
    you can get the code from
    http://zeiberbude.sourceforge.net
    Requirements
    zeiberbude
    - QT 3.x
    zbdesk-x11
    - XFree-devel
    - libxml2
    zbdesk-win32
    - libxml2
    (there is an installer available)
    Compiling
    zeiberbude
    $ qmake zeiberbude.pro
    $ make
    $ make install
    $ cp config.xml db.xml /usr/local/share/zeiberbude
    $ chmod 666 /usr/local/share/zeiberbude/db.xml
    install paths are
    /usr/local/bin - the binary
    /usr/local/share/zeiberbude - the translations and configuration files
    /usr/local/info - the documentation
    zbdesk-x11
    $ cd clients/x11
    $ make
    $ make install
    install paths are
    zbdesk-win32
    there is an installer for the windows platforms
    in the directory clients/win
    Nov 2002
    Guarapuava-PR
    o que vc axa?????
    qual q dificuldade??? ai ta passo a passo oq deve ser feito... O qt vc jah instalou agora vai pra proxima fase
    Nov 2002
    Guarapuava-PR
    o 1c3 eu vou usar aquele scipt seu mesmo este programa eu naum to conseguindo instalar mesmo
    OK qq coisa me chama no icq...
    AndrewAmorimdaSilva
    Você decompactou o programa....agora entra na pasta e usa.
    ai compila....
    testa ai..
