    shakejb
    Tenho uma placa de faxmodem Ambient tenho o drive dela mas nâo consegui instalar nem no constiva 7 e 8 e nem no Mandrake 9, tenho o manual em ingles mas não funciona.
    Obrigado!!!!
  2. Posta aqui seus passos e os respectivos erros, pra gente poder analisar melhor =)
    shakejb
    Este é o howtow:
    ReadMe file for the
    Intel® MD563X-HaM V.92 chipset Linux driver
    contents:
    1. License
    2. Release Notes
    3. Installation
    4. File Descriptions
    5. International Users
    6. Beta Tester appreciation
    7. Security issues
    8. Compilation issues
    a. Instructions for Debian Users
    b. Kernel Source
    9. What is the Hamregistry?
    10. what´s v92 and v44?
    11. The Hamregistry tool (for persistance)
    12. Known Bugs/Issues
    13. Comments, ideas, problems, fixes
    1. LICENSE
    IMPORTANT - read the file "LICENSE.txt" for the INTEL SOFTWARE LICENSE
    AGREEMENT BEFORE COPYING, INSTALLING OR USING.
    also note:
    The serial driver open source code located in the directory "serialdrv"
    is work covered under the GNU GENERAL PUBLIC LICENSE (GPL).
    The "serialdrv" directory has the GPL in the file "GPL.txt".
    2. Release Notes
    This release supports 2.4.x kernels.
    This release is not compatible to 2.2.x kernels, please use
    the 333-5 Linux HaM driver.
    The HaM corecode binary was compiled with gcc version 2.96
    v92 support added: modem on hold AT command set,
    PCM upstream, v44, and quick connect are implemented.
    Linux Compatability tests are performed on the latest or previous
    versions of the following distributions: Mandrake, RedHat, and SuSE
    3. INSTALLATION
    Prerequisites:
    1. root access
    2. bash shell to run install scripts
    3. a HaM modem
    4. KERNEL SOURCE HEADERS FOR THE KERNEL YOU ARE RUNNING
    (found on your distribution´s CD)
    6 steps to install
    1. login as ROOT
    2. extract the archive into a directory with "tar -zxvf <archivename>.tgz"
    3. cd into the directory it created.
    4. Type: make clean
    5. Type: make ham
    6. Type: make install
    The installation script has been designed for the following distributions
    release versions
    mandrake-release
    SuSE-release
    redhat-release
    debian_version (including Corel)
    slackware-version
    conectiva-version
    bluepoint-release
    Unknown distributions install modules and utilities but
    will not install boot scripts!.
    Please examine the haminst script if you have a different distribution.
    The driver is split in two. A ham serial driver and core driver.
    The core driver must be loaded first since the serial driver depends on it.
    The serial driver registers itself as character device
    major number 240, minor number 1.
    The serial driver takes one argument right now, which is a number to
    override the default major number if you need to.
    ATTENTION: if the driver compiles but the script just wont work for you.
    Here are the bare minimum steps to get your modem to work.
    0. log in as root.
    1. insmod -f hamcore.o
    2. insmod -f ham.o
    2a. you can start "hamregistry" at this point if you wish.
    3. rm /dev/ham
    4. mknod /dev/ham c 240 1 (note "240" is the default, if it does not
    work see what /proc/devices says ham&acute;s major number is)
    5. ln -s /dev/ham /dev/modem
    6. start a comm application like minicom and use the modem.
    7. see section 3 (International Users) for info on setting the correct
    country settings.
    4. FILE DESCRIPTIONS
    haminst installation script to install HaM modules and supporting files
    files copied to /lib/modules/(kernel-version)/misc
    hamcore.o driver core code module
    ham.o pseudo serial driver for HaM, depends on hamcore.o
    files copied to /etc/rc.d/... (path differes per distribution)
    hamboot boot scrip to start and stop HaM modules
    files copied to /usr/sbin
    hamregistry hamregistry is the "registry" like tool that the modem uses to
    get and store persistant data such as county info and profile strings.
    hamregistry.bin file that stores the initial persistant data for modem.
    5. INTERNATIONAL USERS
    hamregistry will store the last country setting you
    set in the modem.
    in minicom (or equivalent comm application)
    the commmand to change country setting is "AT+GCI="
    the command takes a t.35 country code in hexadecimal.
    below is a list of currently supported t.35 country codes.
    you can also put this "AT" command in the init string of
    the comm application you are using.
    if you are a CTR-21 country I think you should be able to
    choose a CTR-21 country on the list and be ok. but
    that&acute;s no guarantee.
    The same goes for countries that are "USA" compatable.
    (this table also exist in the source file wwh_dflt.c that
    ships with the hamcore driver)
    country code t.35 code
    USA 1 B5
    KOR 82 61
    ECU 593 35
    BOL 591 14
    CHL 56 15
    COL 57 27
    PAN 507 85
    PER 51 88
    SAU 966 98
    THA 66 A9
    VNM 84 BC
    SWE 46 A5
    DNK 45 31
    FIN 358 3C
    NOR 47 82
    ISL 354 52
    IRL 353 57
    ISR 972 58
    LIE 423 68
    ESP 34 A0
    TUR 90 AE
    DEU 49 42
    AUT 43 0A
    CHE 41 A6
    CYP 357 2D
    GRC 30 46
    ITA 39 59
    LUX 352 69
    NLD 31 7B
    GBR 44 B4
    BEL 32 0F
    FRA 33 3D
    PRT 351 8B
    PAK 92 84
    JPN 81 00
    RUS 7 B8
    AUS 61 09
    MYS 60 6C
    CHN 86 26
    HKG 852 50
    SGP 65 9C
    NZL 64 7E
    ARG 54 07
    BRA 55 16
    MEX 52 73
    TWN 886 E3
    IND 91 53
    PHL 63 89
    IDN 62 54
    BHS 103 0B
    BRB 104 0E
    BMU 105 12
    GTM 502 49
    HTI 509 4E
    HND 504 4F
    JAM 1 5B
    NIC 505 7F
    PRY 595 87
    PRI 121 8C
    SUR 597 A3
    TTO 117 AC
    URY 598 B7
    VEN 58 BB
    ZWE 263 C4
    GUY 592 4D
    EST 372 E0
    HUN 36 51
    SVN 386 E2
    ARE 971 B3
    SVK 421 2E
    CAN 107 14
    CRI 506 1B
    DOM 110 33
    SLV 503 37
    GMB 220 41
    GIB 350 45
    POL 48 8A
    EGY 20 36
    CZE 420 2E
    ZAF 27 9F
    GUF 594 E1
    6. Thanks to the following beta testers for their valuable input and
    suggestions during the HaM 333 beta test between January 2 - 26, 2001
    Dorian S. Araneda
    Sean Walbran
    Rob Clark
    Marvin Stodolsky
    Dominique Duval
    Roman Krais
    Ulrich Guenther
    Marcelino Viana Pinheiro
    Thomas S. Iversen
    Jospeh Teichman
    Michel Bartolone (MED)
    Ramon Gonzalez Montoiro
    Ryoji Kawagishi
    Torsten Vogel
    "jandro"
    Ian Carr-de Avelon
    Helga Weindl
    Ed Casas
    Bernhard Hoelcker
    Alexander "Sasha" Voytov
    Albert Woo
    Peter Hirschmann
    and all of the helpful Linux HaM users
    around the world and at www.linmodems.org
    7. Security issues
    the haminst and hamboot file install the files and device nodes as
    root for the owner and group.
    this will cause problems for those who want to user the modem to dialout
    using an account other than root.
    In SuSE, "dialout" is the group used to install the files and device node.
    This way, anyone belonging to the "dialout" group can use the modem to dialout.
    (take a look at /etc/group)
    I did not want the script to allow full access of the modem to everyone without
    "root" knowing.
    Edit the hamboot and haminst scripts to fit your needs.
    8. Compile issues
    a. this driver will now compile with the this path:
    /lib/modules/<kernel version>/build/include
    the 2.4.4+ kernels says to copy the /boot/vmlinuz.version.h
    over to the kernel build path. I have the makefile do this
    if this file exists. You must install the kernel source
    code anyways. It should be on your distribution&acute;s CD.
    The hamregistery is an application that stores data for the ham driver onto
    the disk. hamregistry stores information from the driver that needs to
    persist from reboot to reboot such as you current country setting.
    The haminst install script and the hamboot script start this utility
    automatically for you.
    If this tool is not present when the driver gets used your profile,
    quickconnect, and current country setting will not be saved but the driver
    should still work fine. The only step that would need to be done is to
    make sure that the driver is set to the correct country with
    at+gci= (see section 5)
    10. What&acute;s v92 and v44?
    a. modem on hold: (ISP and your ISP dialer must also support this)
    This will allow you to pause your ppp connection to answer an incoming
    call. You will need call waiting, dialer, and ISP support for this to
    work. When you are done with the call you can resume your ppp connection
    without having to reconnect. The AT command set for this feature exist
    in the driver.
    b, pcm upstream:
    (ISP must also support this, as of version 4.32 I
    dont know any ISP&acute;s that do)
    This will allow faster upload speeds.
    to enable: at+pig=0
    to disable: at+pig=1
    c. quickconnect:
    Once you make a call to a v92 modem, your phoneline characteristics are
    stored. Whenever you make a new v92 connection it will use this data
    to make the call negotiation quicker (approx 10 seconds).
    to enable: at+pqc=0 at+pss=0
    to disable: at+pss=2
    d. v44: (ISP must also support this)
    A better compression protocol than v42 which can give you better transfer
    speeds.
    The hamregistry tool is used to provide persistance of settings across
    reboots. The haminst and hamboot scripts automatically setup and start
    the hamregistry background task for the modem to use.
    The hamregistry tool has command line arguments for those who wish to
    customize persistant settings. To use these command lines
    you must first stop the driver with "bash hamboot stop".
    Once the driver has been stopped you may run hamregistry with one of these
    arguments to store into the /etc/hamregistry.bin persistance file:
    (supply value for items in < &gt<IMG SRC="images/forum/icons/icon_wink.gif">
    -mfg <Modem manufactures name>
    -mod <Modem model name>
    -hookflash <0,1,2>
    hookflash method: 0=(default)without tone 1=with tone 2=reserved
    -v92rptopt <0,1>
    control v92 reporting: 0=PCM upsteam only 1=(default) all v92
    -gpio_lpohd <0,1>
    Handset Hook detection: 0=not supported 1=(default)supported
    -currentcountry <t.35 code>
    This info is written to the /etc/hamregistry.bin file.
    If hamregistry.bin exists along with the installation files, haminst will
    copy it to /etc/hamregistry.bin when installing the modem.
    a. If you see this message
    "ham:rs_open: DSP did not reset. try again or restart computer"
    and you KNOW you have a HaM modem installed
    Disable "PNP OS" in your bios. There is a problem with the driver and
    linux PNP. After a time, Linux PNP will disable the card and the driver
    currently can not reenable itself.
    b. Be aware that the build replaces your
    /lib/module/<kernver>//build/include/linux/version.h file with
    (this is what Linus T. told me to do with a compiler error)
    c. There may be an incompatibility with DevFS. The ham device may be located
    in /dev/tts/ham
    instead of /dev/ham. Be aware of this and link /dev/modem to the ham
    device that corresponds to your setup.
    d. SuSE 7.3 has our 412-3 HaM driver on the CD set.
    To install it the command is:
    rpm -Uhv /cdrom/suse/pay1/Intel-v92ham.rpm
    f. There is a compile problem with HaM version 4.25 and SuSe 7.2
    remove our comment the line "#define EXPORT_SYMTAB" for it to compile.
    e. Incase you are having problems making a ppp connection try using wvidal
    with this information below. execute the script and it will have wvdial
    make the ppp connection
    ------my script----------------------
    #! /bin/sh
    /usr/sbin/pppd -detach lock asyncmap 00000000 \
    defaultroute debug /dev/modem 57600 \
    ipparam ppp0 linkname ppp0 \
    noauth \
    connect "/usr/bin/wvdial --chat bellsouth"
    ------my /etc/wvdial.conf section ---
    [Dialer bellsouth]
    Modem = /dev/modem
    Baud = 57600
    Init1 = ATZ
    Inti2 = ATQ0 V1 E1 S0=0 &C1 &D2
    Dial Command = ATDT
    Phone = 6859500
    Username = myloginname
    Password = mysecretpassword
    #Ask Password = 1
    Stupid Mode = 0
    13. Comments, ideas, problems, fixes? please contact:
    Linux Voice Band Modems (VBM) of Intel Residential Access Division (RAD)
    vbm.linux@intel.com
    http://developer.intel.com/design/modems/
    To restrict email volume, please email only development related issues that are
    needed to fix a bug or improve the driver. General questions on how to use the
    Linux OS will have to be forwarded.
    Other resources and information on Linux controllerless modems can be found on
    these usefull sites
    http://www.linmodems.org
    and
    http://linmodems.technion.ac.il
    Mas não tem mensagem de erro simplemente não funciona.
    shakejb@hotmail.com
    Obrigado pela atenção.
  4. Atravez de qual software voce esta tentando se conectar?
    shakejb
    Usei o padrão do Mandrake 9, não lembro o nome e no Conectiva 7 e 8 usei o kppp.
    Obrigado.
  1. Configurar Placa de Rede - Genius LAN (ISA)
    Por seimon no fórum Sistemas Operacionais
    Último Post: 11-04-2004, 17:13
  2. Configurar placa de rede
    Por joe_fox no fórum Servidores de Rede
    Respostas: 10
    Último Post: 07-04-2004, 04:24
  3. Configurar placa de rede no Slackware 9
    Por K4n3 no fórum Servidores de Rede
    Último Post: 23-06-2003, 20:14
  4. Configurar placa de rede no linux!
    Último Post: 02-04-2003, 13:28
  5. Configurar Placa de Video S3 no Cl 8.0
    Por WebMic no fórum Servidores de Rede
    Último Post: 13-01-2003, 14:05
