    Padrão Aos gurus em seguranca (Melhorar firewall!)
    Pessoal quais regras devo adicionar ao script abaixo afim de amadurece-lo e melhora-lo no quesito protecao e qualidade:
    # Configuração Básica
    IPTABLES=`which iptables`
    PERMITIR_TCP="22 80 3389"
    PERMITIR_UDP="53"
    INET_INT="eth0"
    LAN_INT="eth1"
    INTERNAL_LAN="10.0.0.0/24 200.x.x.163 200.x.x.162"
    MASQ_LAN="10.0.0.0/24"
    # DROP: com log colocar "LDROP"
    #DROP="TREJECT"
    DROP="LDROP"
    # Tcp Forward: Pserv<IMG SRC="images/forum/icons/icon_razz.gif">estacao>Ip
    TCPFORWARD="3389:3389>10.0.0.152"
    UDPFORWARD=""
    # Criando as Regras
    REGRAS="ENTRADANET SAIDANET TCPPERMITIDO LDROP TREJECT"
    # Habilitando o Masquerade
    # Habilitando TCP Syncookies
    if [ -e /proc/sys/net/ipv4/tcp_syncookies ] ; then
    echo 1 > /proc/sys/net/ipv4/tcp_syncookies
    fi
    # Limpando as Regras Antigas
    ${IPTABLES} -t filter -F INPUT
    ${IPTABLES} -t filter -F OUTPUT
    ${IPTABLES} -t filter -F FORWARD
    ${IPTABLES} -t nat -F PREROUTING
    ${IPTABLES} -t nat -F OUTPUT
    ${IPTABLES} -t nat -F POSTROUTING
    ${IPTABLES} -t mangle -F PREROUTING
    ${IPTABLES} -t mangle -F OUTPUT
    for chain in ${REGRAS} ; do
    ${IPTABLES} -t filter -F ${chain} > /dev/null 2>&1
    ${IPTABLES} -t filter -X ${chain} > /dev/null 2>&1
    ${IPTABLES} -t filter -N ${chain}
    done
    ${IPTABLES} -t filter -P INPUT ACCEPT
    ${IPTABLES} -t filter -P OUTPUT ACCEPT
    ${IPTABLES} -t filter -P FORWARD DROP
    # Trafego Local
    for subnet in ${INTERNAL_LAN} ; do
    ${IPTABLES} -t filter -A FORWARD -s ${subnet} -j ACCEPT
    ${IPTABLES} -t filter -A FORWARD -d ${subnet} -m state --state ESTABLISHED,RELATED -j ACCEPT
    done
    # Habilitando NAT
    if [ "$MASQ_LAN" != "" ] ; then
    for subnet in ${MASQ_LAN} ; do
    ${IPTABLES} -t nat -A POSTROUTING -s ${subnet} -o ${INET_INT} -j MASQUERADE
    done
    fi
    # TCP Forward
    if [ "$TCPFORWARD" != "" ] ; then
    for rule in ${TCPFORWARD} ; do
    echo "$rule" | {
    IFS=&acute;:>&acute; read srcport destport host
    ${IPTABLES} -t nat -A PREROUTING -p tcp -i ${INET_INT} --dport ${srcport} -j DNAT --to-destination ${host}:${destport}
    ${IPTABLES} -t filter -A FORWARD -p tcp -d ${host} --dport ${destport} -j ACCEPT
    done
    fi
    # UDP Forward
    if [ "$UDPFORWARD" != "" ] ; then
    for rule in ${UDPFORWARD} ; do
    echo "$rule" | {
    ${IPTABLES} -t nat -A PREROUTING -p udp -i ${INET_INT} --dport ${srcport} -j DNAT --to-destination ${host}:${destport}
    ${IPTABLES} -t filter -A FORWARD -p udp -d ${host} --dport ${destport} -j ACCEPT
    done
    fi
    # Terminado configuraçao de regras
    ${IPTABLES} -t filter -A INPUT -i ${INET_INT} -j ENTRADANET
    ${IPTABLES} -t filter -A OUTPUT -o ${INET_INT} -j SAIDANET
    ${IPTABLES} -t filter -A LDROP -p tcp -m limit --limit 2/s -j LOG --log-level info --log-prefix "TCP Dropped "
    ${IPTABLES} -t filter -A LDROP -p udp -m limit --limit 2/s -j LOG --log-level info --log-prefix "UDP Dropped "
    ${IPTABLES} -t filter -A LDROP -p icmp -m limit --limit 2/s -j LOG --log-level info --log-prefix "ICMP Dropped "
    ${IPTABLES} -t filter -A LDROP -f -m limit --limit 2/s -j LOG --log-level warning --log-prefix "FRAGMENT Dropped "
    ${IPTABLES} -t filter -A LDROP -j DROP
    ${IPTABLES} -t filter -A TREJECT -p tcp -j REJECT --reject-with tcp-reset
    ${IPTABLES} -t filter -A TREJECT -p ! tcp -j REJECT --reject-with icmp-port-unreachable
    ${IPTABLES} -t filter -A TREJECT -j REJECT
    # Protegendo contra TCP SYN Flood
    ${IPTABLES} -t filter -A TCPPERMITIDO -p tcp --syn -m limit --limit 4/s -j ACCEPT
    ${IPTABLES} -t filter -A TCPPERMITIDO -p tcp ! --syn -j ACCEPT
    ${IPTABLES} -t filter -A TCPPERMITIDO -m limit --limit 2/s -j LOG --log-prefix "Mismatch in TCP"
    ${IPTABLES} -t filter -A TCPPERMITIDO -j ${DROP}
    # Pacotes com flag invalidas
    ${IPTABLES} -t filter -A ENTRADANET -m state --state INVALID -j ${DROP}
    # Descartando Ping flood
    ${IPTABLES} -t filter -A ENTRADANET -p icmp --icmp-type echo-request -m limit --limit 1/s -j ACCEPT
    ${IPTABLES} -t filter -A ENTRADANET -p icmp --icmp-type ! echo-request -j ACCEPT
    # Portas TCP a serem abertas
    if [ "$PERMITIR_TCP" != "" ] ; then
    for port in ${PERMITIR_TCP} ; do
    ${IPTABLES} -t filter -A ENTRADANET -p tcp --dport ${port} -j TCPPERMITIDO
    done
    fi
    #Teste com UDP ports
    if [ "$PERMITIR_UDP" != "" ] ; then
    for port in ${PERMITIR_UDP} ; do
    ${IPTABLES} -t filter -A ENTRADANET -p udp --dport ${port} -j ACCEPT
    done
    fi
    # Pacotes com flags validas
    ${IPTABLES} -t filter -A ENTRADANET -m state --state ESTABLISHED -j ACCEPT
    # TOS
    ${IPTABLES} -t mangle -A OUTPUT -p tcp --dport 23 -j TOS --set-tos 0x10
    ${IPTABLES} -t mangle -A OUTPUT -p tcp --dport 22 -j TOS --set-tos 0x10
    ${IPTABLES} -t mangle -A OUTPUT -p tcp --dport 21 -j TOS --set-tos 0x10
    ${IPTABLES} -t mangle -A OUTPUT -p tcp --dport 20 -j TOS --set-tos 0x02
    # Regras padrao
    ${IPTABLES} -t filter -A ENTRADANET -j ${DROP}
    ${IPTABLES} -t filter -A SAIDANET -j ACCEPT
    por acaso, se vc colocar somente .....
    $ iptables -F
    já naum limparia todas as regras???????
    substituiria essa parte do seu script:
    <IMG SRC="images/forum/icons/icon_eek.gif">
    [ Esta mensagem foi editada por: PiTsA em 17-02-2003 11:59 ]
    Parece muito bom para mim... bom ate demais <IMG SRC="images/forum/icons/icon_smile.gif">
    nao cheguei a ler tudo por completo... mas voce esta bloquenado pings (icmp echo reply) vi que voce bloqueou syn floods, o que eh bom <IMG SRC="images/forum/icons/icon_smile.gif"> dependendo do ping voce poderia bloquear tbm <IMG SRC="images/forum/icons/icon_smile.gif"> mas nao sei.. so uma dica <IMG SRC="images/forum/icons/icon_smile.gif">
    nem sempre eh ~bom~ bloquear ping
