    g0dz
    Padrão cache only
    tenho um dns cache configurado na minha maquina. o meu dominio eh feito pelo dyndns.org(alguem conhce?) o problema eh o seguinte quero conf. um sendmail e tudo aponta que meu dns nao esta conf. corretamente. por favor alguem poderia me dizer se o dns esta configurado corretamente para uso de sendmail ou nao?nao faz sentido?... ele funciona pra outros servicos. aqui vao os files
    named.conf
    acl lan { 192.168/16 ;
    127.0.0.1 ;
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    allow-query { lan ; } ;
    allow-recursion { lan ; } ;
    allow-transfer { lan ; } ;
    // a caching only nameserver config
    zone "." IN {
    type hint;
    file "named.ca";
    zone "localhost" IN {
    type master;
    file "localhost.zone";
    allow-update { none; };
    zone "0.0.127.in-addr.arpa" IN {
    type master;
    file "named.local";
    #zone "celsoandrade.homelinux.org" in {
    # type master ;
    # file "192.168.1.1" ;
    localhost.zone$ORIGIN localhost.
    @ 1D IN SOA @ root (
    42 ; serial (d. adams)
    3H ; refresh
    15M ; retry
    1W ; expiry
    1D ) ; minimum
    1D IN NS @
    1D IN A 127.0.0.1
    named.local
    $TTL 86400
    @ IN SOA localhost. root.localhost. (
    1997022700 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    IN NS localhost.
    1 IN PTR localhost.
    named.ca
    ; <<>> DiG 9.2.1 <<>> @F.ROOT-SERVERS.NET . ns
    ;; global options: printcmd
    ;; Got answer:
    ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 55793
    ;; flags: qr aa rd; QUERY: 1, ANSWER: 13, AUTHORITY: 0, ADDITIONAL: 13
    ;; QUESTION SECTION:
    ;. IN NS
    ;; ANSWER SECTION:
    . 518400 IN NS E.ROOT-SERVERS.NET.
    . 518400 IN NS F.ROOT-SERVERS.NET.
    . 518400 IN NS G.ROOT-SERVERS.NET.
    . 518400 IN NS H.ROOT-SERVERS.NET.
    . 518400 IN NS I.ROOT-SERVERS.NET.
    . 518400 IN NS J.ROOT-SERVERS.NET.
    . 518400 IN NS K.ROOT-SERVERS.NET.
    . 518400 IN NS L.ROOT-SERVERS.NET.
    . 518400 IN NS M.ROOT-SERVERS.NET.
    . 518400 IN NS A.ROOT-SERVERS.NET.
    . 518400 IN NS B.ROOT-SERVERS.NET.
    . 518400 IN NS C.ROOT-SERVERS.NET.
    . 518400 IN NS D.ROOT-SERVERS.NET.
    ;; ADDITIONAL SECTION:
    A.ROOT-SERVERS.NET. 3600000 IN A 198.41.0.4
    B.ROOT-SERVERS.NET. 3600000 IN A 128.9.0.107
    C.ROOT-SERVERS.NET. 3600000 IN A 192.33.4.12
    D.ROOT-SERVERS.NET. 3600000 IN A 128.8.10.90
    E.ROOT-SERVERS.NET. 3600000 IN A 192.203.230.10
    F.ROOT-SERVERS.NET. 3600000 IN A 192.5.5.241
    G.ROOT-SERVERS.NET. 3600000 IN A 192.112.36.4
    H.ROOT-SERVERS.NET. 3600000 IN A 128.63.2.53
    I.ROOT-SERVERS.NET. 3600000 IN A 192.36.148.17
    J.ROOT-SERVERS.NET. 3600000 IN A 192.58.128.30
    K.ROOT-SERVERS.NET. 3600000 IN A 193.0.14.129
    L.ROOT-SERVERS.NET. 3600000 IN A 198.32.64.12
    M.ROOT-SERVERS.NET. 3600000 IN A 202.12.27.33
    ;; Query time: 1528 msec
    ;; SERVER: 192.5.5.241#53(F.ROOT-SERVERS.NET)
    ;; WHEN: Fri Feb 21 17:10:04 2003
    ;; MSG SIZE rcvd: 436
    obrigado pela ajuda
    Padrão cache only
    no seu arquivo de hosts(zone). voce prescisa da entrada MX
    algo do tipo
    IN MX 20 mail.domain.net
    MX = mail eXchange
    20 - prioridade.
    coloque embaixo do seu IN NS que ira funcionar normal. <IMG SRC="images/forum/icons/icon_smile.gif">
    g0dz
    Padrão cache only
    obrigado.
