    dr4k
    Padrão Iptables - Dando acesso á internet para rede interna
    Olá, consegui com a ajuda de vc´s conectar a rede interna, só falta esse ultimo passo e poderei
    ficar integralmente no linux para aprender sozinho <IMG SRC="images/forum/icons/icon_smile.gif">
    Um amigo meu me passou um script que deveria automatizar a configuracao, porem qdo eu executo
    o script ele me retorna varios erros
    Meu SO é Debian 3.0
    a seguir, o SCRIPT:
    IPTABLES=/sbin/iptables
    EXTIF="eth0"
    INTIF="eth2"
    # See how we were called.
    case "$1" in
    start)
    echo "Setting up iptables rules: "
    echo "1" > /proc/sys/net/ipv4/ip_forward
    echo "1" > /proc/sys/net/ipv4/ip_dynaddr
    $IPTABLES -P INPUT ACCEPT
    $IPTABLES -F INPUT
    $IPTABLES -P OUTPUT ACCEPT
    $IPTABLES -F OUTPUT
    $IPTABLES -P FORWARD DROP
    $IPTABLES -F FORWARD
    $IPTABLES -t nat -F
    $IPTABLES -A FORWARD -i $EXTIF -o $INTIF -m state --state ESTABLISHED,RELATED -j ACCEPT
    $IPTABLES -A FORWARD -i $INTIF -o $EXTIF -j ACCEPT
    $IPTABLES -A FORWARD -j LOG
    $IPTABLES -t nat -A POSTROUTING -o $EXTIF -j MASQUERADE
    echo -e "done.\n"
    stop)
    echo -e "\nFlushing firewall and setting default policies to DROP\n"
    $IPTABLES -P INPUT DROP
    $IPTABLES -F INPUT
    $IPTABLES -P OUTPUT DROP
    $IPTABLES -F OUTPUT
    $IPTABLES -F -t nat
    # Delete all User-specified chains
    $IPTABLES -X
    # Reset all IPTABLES counters
    $IPTABLES -Z
    restart)
    $0 stop
    $0 start
    status)
    $IPTABLES -L
    mlist)
    cat /proc/net/ip_conntrack
    echo "Usage: firewall-2.4 {start|stop|status|mlist}"
    exit 1
    esac
    exit 0
    Eu coloquei esse arkivo em /etc/init.d
    qdo eu mando ele executar /etc/init.d/iptables.firewall start
    ele retorna os seguintes ERROS
    cyberw:~# /etc/init.d/iptables.firewall start
    modprobe: Can&acute;t locate module ip_tables
    iptables v1.2.6a: can&acute;t initialize iptables table `filter&acute;: iptables who? (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded.
    iptables v1.2.6a: can&acute;t initialize iptables table `nat&acute;: iptables who? (do you need to insmod?)
    done.
    é isso, quem mais uma vez puder me ajudar, serei imensamente grato
    dr4k
    tive um problema semelhante esses dias...
    faz o seguinte:
    desabilita o ipchains no ntsysv, e recompile o kernel habilitando o suporte ao iptables e tire o suporte ao ipchains
    acho q um comando pra desabilitar o modulo do ipchains éh rmprobe uma coisa assim....
    mas se vc recompilar o kernel e tirar o ipchains na marra o negocio fica blzinha
    qq coisa posta ae....
    t+
    dr4k
    Umm, tipo assim, eu entendo oq vc kis dizer
    mas nao sei como...
    por isso se vc desse os comandos passo a passo ia ser de grande ajuda...
    blz
    tipow... naum sei se nah sua distro tem o ntsysv, se tiver, executa ele, procura por ipchains, e desabilita, certifique-se d que o iptables esteja habilitado
    se naum tiver o ntsysv, vah em /etc/rd.d/rc3.d/
    essa eh a init default, procure por um arquivo qq com o nome ipchains, pode apaga-lose quiser, ou ainda renomea-lo p/ q o inicio dele ao inves d ter um "S" - q signifa q ele vai ser carregado -, tenha um "K" - que naum vai ser carregado
    faça o processo inverso no arquivo com iptables, ao inves do K, coloque um S
    o nº depois da letra indica a ordem d carregamento do serviço, na ordeem crescente
    se vc precisar recompilar o kernel, d uma olhada nesse artigo
    http://www.linuxdicas.com.br/tutoria...lar_kernel.htm
    habilite o iptables e retire o ipchains
    t+
    Mr_Mind
    recompila o teu kernel
    mas ja agora .. qual o teu interesse d por um script assim a trabalhar s nem sabes o q ele faz??? <IMG SRC="images/forum/icons/icon_confused.gif">
