    Leyzem
    Padrão postfix maldito!!!!não autentica smtp...
    Caros amigos já cansei do postfix, não consigo fazer ele autenticar smtp, fá fiz de tudo, baixei as atualizações da conectiva cl8,
    smtpd_recipient_restrictions = permit_mynetworks,
    permit_sasl_authenticated,
    check_client_access hash:/etc/postfix/client_access,
    check_relay_domains
    smtp_sasl_auth_enable = yes
    smtp_sasl_password_maps = dbm:/etc/postfix/sasldb
    smtp_sasl_security_options = noanonymous
    smtpd_sasl_local_domain = $mydomain
    broken_sasl_auth_clients = yes
    o que eu preciso para ele autenticar?????? smtp....
    <IMG SRC="images/forum/icons/icon27.gif">
    ok, vc jah mostrou sua configuração.. quais sao os erros q ele mostra?
    Leyzem
    la vai minha configuração
    soft_bounce = yes
    queue_directory = /var/spool/postfix
    program_directory = /usr/sbin# The command_directory parameter specifies the location of all
    command_directory = /usr/sbin
    daemon_directory = /usr/lib/postfix
    mail_owner = postfix
    default_privs = nobody
    myhostname = maquina.meudominio.com.br
    mydomain = meudominio.com.br
    inet_interfaces = allmydestination = meudominio.com.br
    mynetworks = 192.168.0.0/24 127.0.0.0/8 200.198.156.186
    relay_domains = $mydestination
    default_transport = smtp
    alias_maps = hash:/etc/postfix/aliases
    alias_database = hash:/etc/postfix/aliases
    home_mailbox = Maildir/
    mailbox_command = /usr/bin/procmail
    smtpd_banner = $myhostname ESMTP $mail_name ($mail_version)
    debug_peer_level = 2
    debugger_command =
    PATH=/usr/bin:/usr/X11R6/bin
    xxgdb $daemon_directory/$process_name $process_id & sleep 5
    maps_rbl_domains = blackholes.mail-abuse.org relays.mail-abuse.org dialups.mail-abuse.org
    smtpd_helo_required = yes
    disable_vrfy_command = yes
    masquerade_domains = meudominio.com.br
    transport_retry_time = 60
    maximal_queue_lifetime = 5d
    queue_run_delay = 1000
    qmgr_message_active_limit = 10000
    qmgr_message_recipient_limit = 10000
    mailbox_size_limit = 204800000
    message_size_limit = 102400000
    bounce_size_limit = 102400000
    header_checks = regexp:/etc/postfix/header_checks
    append_at_myorigin=no
    check_relay_domainssmtp_sasl_auth_enable = yes
    smtp_sasl_password_maps = hash:/etc/postfix/sasldb
    permit_mynetworks,
    quero ver os logs de erros naum da configuração
    Leyzem
    digito o comando postconf ele me da.. isso ai
    postconf -v |grep sasl
    lmtp_sasl_auth_enable = no
    lmtp_sasl_password_maps =
    lmtp_sasl_security_options = noplaintext, noanonymous
    smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, check_client_access hash:/etc/postfix/client_access, check_relay_domains
    smtpd_sasl_auth_enable = no
    smtpd_sasl_security_options = noanonymou
    nessa parte ele deveria de ter o tipo de autenticação e não esta mostrando,
    mas quando eu
    telnet 127.0.0.1 25
    Trying 127.0.0.1...
    Connected to 127.0.0.1.
    Escape character is &acute;^]&acute;.
    220 meu.dominio.com.br ESMTP Postfix (Postfix-20010228-pl0<IMG SRC="images/forum/icons/icon_cool.gif">
    ehlo 127.0.0.1
    250-meu.dominio.com.br
    250-PIPELINING
    250-SIZE 102400000
    250-ETRN
    250 8BITMIME
    Leyzem
    ultimamente o pessoal dessa pagina esta deixando agente muito na mão, ou estão com ma vontade de ajudar a comunidade linux a resolver os seus problemas...
    que pena!!!!!!
    se não tiver um erro num tem como ajudar..... num adianta mostra oq ta certo, tem q mostra oq ta errado
    Leyzem
    quando eu digito postconf me aparece smtpd_sasl_auth_enable 2 vezes na
    -> 1º smtpd_sasl_auth_enable = yes esta assim
    -> 2º smtpd_sasl_auth_enable = no ele esta no
    se eu não me engao um se refere ao servido e o outro au cliente correto????
