    Padrão Digitar senha duas vezes?
    Boa tarde, galera.
    Porque as estações w2000 cada vez que se logam precisam na primeira pasta que acessam digitar novamente nome e senha após se logarem normalmete.
    Conectiva 8.0
    smb.conf abaixo
    Abraço
    [global]
    workgroup = MEDITEC
    server string = Meditec Server %v
    hosts allow = 192.168.0. 127.
    printcap name = /etc/printcap
    load printers = yes
    printing = lprng
    ;guest account =
    log file = /var/log/samba/log-%U.%m
    max log size = 5000
    debug level = 3
    security = user
    ;password server =
    password level = 8
    username level = 8
    encrypt passwords = no
    smb passwd file = /etc/smbpasswd
    unix password sync = Yes
    passwd program = /usr/bin/passwd %u
    passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
    username map = /etc/smbusers
    ;include = /etc/smb.conf.%m
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    ;interfaces = 192.168.12.2/24 192.168.13.2/24
    ;remote browse sync = 192.168.3.25 192.168.5.255
    ;remote announce = 192.168.1.255 192.168.2.44
    local master = yes
    os level = 99
    domain master = yes
    preferred master = yes
    ;domain controller = <NT-Domain-Controller-SMBName>
    domain logons = yes
    logon script = %U.bat
    logon path =
    ;logon home = \\%L\homes
    name resolve order = wins lmhosts bcast
    wins support = yes
    ;wins server = w.x.y.z
    ;wins proxy = yes
    dns proxy = no
    ;unix password sync = yes
    netbios name = SERVER
    keepalive = 20
    ;preserve case = no
    ;short preserve case = no
    ;default case = lower
    ;case sensitive = no
    ;admin users = root, osni
    ;valid users = osni, barbara, nelson, marcos, root, schlachter, marcelo, carlos, antonio, lemos, luis, tatiana, andrea, alceu, siqueira, antonio, fabiane, celio, clesio, rondineli, rondinelia, marcio, heloir, horacio, rose,
    logon drive = T:
    ;remote browse sync = 192.168.0.255
    ;remote announce = 192.168.0.255
    create mask = 0777
    time server = yes
    ;domain admin group = root
    oplock = false
    #============================ Share Definitions ==============================
    [homes]
    comment = Home Directories
    browseable = yes
    writable = yes
    available = yes
    public = yes
    [netlogon]
    comment = Network Logon Service
    path = /home/netlogon
    guest ok = yes
    writable = yes
    browseable = no
    [meditec]
    comment = meditec
    path = /files/med
    public = yes
    writable = yes
    browseable = no
    Acho que porque voce nao eh PDC deles? bom nao sei ao certo.
    troque sua linha
    security = user por
    security = domain
    deve funcionar ok
    vc tentou?
    Aqui não funcionou....
    Apague o arquivo name_user.pwd no c:\windows e logue novamente confirme com a mesma senha.
    Esse arquivo é para win9x.
    Marcos Amorim
    Vc adicionou a maquina no dominio veja o How-to nos artigos aqui na Underlinux .
    Marcos Amorim
    Sim com aquela técnica maquina$...
    Vamos tentar resolver isso:
    A maquina ja esta no dominio [ OK ]
    Quando vc vai logar esta logando no servidor ou na estação?
    esse parametro "encrypt passwords = no" vc fez a alteração no registro do windows?
    Marcos Amorim
    [ Esta mensagem foi editada por: marcosmamorim em 04-04-2003 13:41 ]
    Segui a risca os tutoriais da conectiva e da underlinux, li bastante a respeito do samba .
    as maquinas foram desabilitadas a cripto (lá no "parametes" do registro)
    me logo na estação.
    outro problema é que os scripts de netlogon não carregam eventualmente.
    Não sei se tem alguma valia mas o dominio todo foi migrado (antes era um server w2k e passou para linux)
    Obrigado
    Perai? voce disse que voce loga na estacao para depois logar no dominio ? pode ser por isso. tipo voce tem que logar no dominio. se voce logar na estacao ele nao ira carregar nenhum netlogon, pois voce nao efetuou logon. entretanto voce ainda consegue usar o share usando um user/pass ..
    deve ser por isso...
    faca com suas maquinas w2k loguem no dominio, entao assim voce podera usufruir do netlogon, ah e claro... nao se esqueca dos "perfis ambulantes" dos usuarios de w2k (eu ate que gostei mas ocupa muito espaco no servidor <IMG SRC="images/forum/icons/icon_smile.gif">) se eu nao me engano o samba nao cria automatico. voce tem que criar a pasta e dar chown entao ele ia criar os arquivos quando logar, bom se nao tiver a pasta dos perfis nao tem problema. ele da 2 erros na hora de logar e e so passar
    O mistymst
    Esta correto em sua informação eu resolvo o problema da criaçao da pasta assim
    [profile]
    Coment
    Path = /home/profile
    root preexec = /bin/mkdir /home/profile/%U; chmod 700 /home/profile/%U; /bin/chown %U /home/profile/%U
    Pronto assim eu naum preciso ficar criando as pastas de perfil no braço.
    E descreva o procedimento para adicionar a maquina no dominio.
    Quando vc for logar selecione o seu servidor no windows 2000 no 9x informe o nome do dominio.
    Marcos Amorim
    Isso já esta acontecendo...estou me logando no dominio (não criei nenhum desses usuarios localmente a não ser que aja algo sobrenatural ocorrendo...hehehe)
    O netlogon não funciona eventualmente, ou seja, de vez em quando ele não carreja outras vezes sim, não consegui identificar o porque, mas suspeito de um papo de conexões ativas.
    Ingressei no dominio "Meditec" e a autenticação é feita em dominio (no win2000 aparece a opção na tela de login de se logar no dominio ou an estação),
    Quando aos perfis não é necessário aqui pro isso desabilitei (isto foi assunto em outras discussões neste forum...
    Caras, eu comecei a usar linux em casa e em servidores instalados a pouco tempo, com o windows não era tão divertido... tava ficando chato.... vida eterna ao linux...
    O procedimento de ingresso na maquina é o mesmo dos tutoriais da under e conectiva...sem tirar nem por...
    A ideia do samba sem profiles é a seguinte:
    Path = (sem texto)
    assim acontece com W2k server
    assim quando o usuario se loga o w2k cria os profiles localmente.
    Então o problema esta no logon script?
    Se vc tiver ICQ ou msn me contate para tirar algumas duvidas q tenho com relação a este problema.
    Marcos Amorim
    MSN
    Última edição por osni_passos; 10-10-2015 às 14:49.
    Osni,
    Beleza?
    E ai conseguiu resolver o seu problema?
    Marcos Amorim
    O resolução do problema é bem simples...
    apenas abilitei a criptografia no samba...
    Legal né???
