    pessoal, eu nao consigo me logar como anonimo, apenas com usuario normal, alguem sabe o pq?
    minha conf esta abaixo:
    # This is a basic ProFTPD configuration file (rename it to
    # ´proftpd.conf´ for actual use. It establishes a single server
    # and a single anonymous login. It assumes that you have a user/group
    # "nobody" and "ftp" for normal operation and anon.
    ServerName "Servidor de FTP"
    ServerType standalone
    DefaultServer on
    # Port 21 is the standard FTP port.
    Port 21
    # Umask 022 is a good standard umask to prevent new dirs and files
    # from being group and world writable.
    Umask 022
    # To prevent DoS attacks, set the maximum number of child processes
    # to 30. If you need to allow more than 30 concurrent connections
    # at once, simply increase this value. Note that this ONLY works
    # in standalone mode, in inetd mode you should use an inetd server
    # that allows you to limit maximum number of processes per service
    # (such as xinetd).
    MaxInstances 30
    # Set the user and group under which the server will run.
    User nobody
    Group nogroup
    # To cause every FTP user to be "jailed" (chrooted) into their home
    # directory, uncomment this line.
    DefaultRoot ~
    # Normally, we want files to be overwriteable.
    <Directory />
    AllowOverwrite on
    </Directory>
    # A basic anonymous configuration, no upload directories. If you do not
    # want anonymous users, simply delete this entire <Anonymous> section.
    <Anonymous ~/var/ftp/>
    #RequireValidShell no
    AnonRequirePassword no
    # Maximum clients with message
    MaxClients 10 "Desculpe, numero maximo de clientes (%m)"
    User ftp
    Group ftp
    # We want clients to be able to login with "anonymous" as well as "ftp"
    UserAlias anonymous ftp
    # Limit WRITE everywhere in the anonymous chroot
    <Limit WRITE>
    DenyAll
    </Limit>
    </Anonymous>
    alguem sabe o pq?
    nos logs soh mostra "session opened" e logo em seguida "session closed"
    Versao 1.2.8 compilada.
    Obrigado.
    dboom
    o mue funcionava mas eu bloq. hehehe... tenta ai...
    <Anonymous ~ftp>
    User ftp
    Group ftp
    # Limit the maximum number of anonymous logins
    MaxClients 10
    # We want &acute;welcome.msg&acute; displayed at login, and &acute;.message&acute; displayed
    # in each newly chdired directory.
    # DisplayLogin welcome.msg
    # DisplayFirstChdir .message
    <Limit WRITE>
    DenyAll
    </Limit>
    </Anonymous>
  1. Falha com ProFTPd
    Por juniox no fórum Servidores de Rede
    Respostas: 11
    Último Post: 19-01-2003, 04:11
  2. Desafio Proftpd
    Por MiddleEarth no fórum Servidores de Rede
    Respostas: 34
    Último Post: 11-12-2002, 18:06
  3. Respostas: 4
    Último Post: 11-12-2002, 14:06
  4. negar acesso a usuários nao autorizados no proftpd
    Por ediguedes no fórum Servidores de Rede
    Último Post: 09-12-2002, 20:36
  5. Proftpd - Acesso anonimo negado
    Último Post: 29-11-2002, 09:57
