    athayde2
    Padrão pop lento demora 20 segundos para autorizar
    RESOLV.CONF
    domain eturbo.com.br
    search srv.eturbo.com.br
    nameserver 200.171.107.182
    nameserver 200.205.175.2
    nameserver 200.204.0.10
    DNS
    $TTL 1d
    @ IN SOA srv.eturbo.com.br. sisop.eturbo.com.br. (
    2003042200 ; Serial
    1H ; Refresh
    15M ; Retry
    14D ; Expire
    12H ) ; Minimum
    NS srv.eturbo.com.br.
    srv IN A 200.171.xxx.xxx
    srv2 IN A 200.205.xxx.xxx
    gokussj4 IN A 200.205.xxx.xxx
    eturbo.com.br. IN A 200.171.xxx.xxx
    @ IN MX 5 srv.eturbo.com.br.
    @ IN NS srv.eturbo.com.br.
    @ IN NS srv2.eturbo.com.br.
    NSLOOKUP
    Server: 200.171.107.xxx
    Address: 200.171.107.xxx#53
    NSLOOKUP com SET Q=ANY
    eturbo.com.br mail exchanger = 5 srv.eturbo.com.br.
    eturbo.com.br
    origin = srv.eturbo.com.br
    mail addr = sisop.eturbo.com.br
    serial = 2003042200
    refresh = 3600
    retry = 900
    expire = 1209600
    minimum = 43200
    eturbo.com.br nameserver = srv.eturbo.com.br.
    eturbo.com.br nameserver = srv2.eturbo.com.br.
    POSTCONF
    2bounce_notice_recipient = postmaster
    access_map_reject_code = 554
    alias_database = hash:/etc/postfix/aliases
    alias_maps = hash:/etc/postfix/aliases
    allow_mail_to_commands = alias,forward
    allow_mail_to_files = alias,forward
    allow_min_user = no
    allow_percent_hack = yes
    allow_untrusted_routing = no
    alternate_config_directories =
    always_bcc =
    append_at_myorigin = yes
    append_dot_mydomain = yes
    authorized_verp_clients = $mynetworks
    berkeley_db_create_buffer_size = 16777216
    berkeley_db_read_buffer_size = 131072
    best_mx_transport =
    biff = yes
    body_checks = regexp:/etc/postfix/body_checks
    body_checks_size_limit = 51200
    bounce_service_name = bounce
    bounce_size_limit = 50000
    broken_sasl_auth_clients = no
    canonical_maps =
    cleanup_service_name = cleanup
    command_directory = /usr/sbin
    command_expansion_filter = [email protected]%-_=+:,./abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ
    command_time_limit = 1000s
    config_directory = /etc/postfix
    content_filter = vscan:
    daemon_directory = /usr/lib/postfix
    daemon_timeout = 18000s
    debug_peer_level = 2
    debug_peer_list =
    default_database_type = hash
    default_delivery_slot_cost = 5
    default_delivery_slot_discount = 50
    default_delivery_slot_loan = 3
    default_destination_concurrency_limit = 10
    default_destination_recipient_limit = 50
    default_extra_recipient_limit = 1000
    default_minimum_delivery_slots = 3
    default_privs = nobody
    default_process_limit = 100
    default_rbl_reply = $rbl_code Service unavailable; $rbl_class [$rbl_what] blocked using $rbl_domain${rbl_reason?; $rbl_reason}
    default_recipient_limit = 10000
    default_transport = smtp
    default_verp_delimiters = +=
    defer_code = 450
    defer_service_name = defer
    defer_transports =
    delay_notice_recipient = postmaster
    delay_warning_time = 0h
    deliver_lock_attempts = 20
    deliver_lock_delay = 1s
    disable_dns_lookups = no
    disable_mime_input_processing = no
    disable_mime_output_conversion = no
    disable_verp_bounces = no
    disable_vrfy_command = no
    dont_remove = 0
    double_bounce_sender = double-bounce
    duplicate_filter_limit = 1000
    empty_address_recipient = MAILER-DAEMON
    error_notice_recipient = postmaster
    error_service_name = error
    expand_owner_alias = no
    export_environment = TZ MAIL_CONFIG
    extract_recipient_limit = 10240
    fallback_relay =
    fallback_transport =
    fast_flush_domains = $relay_domains
    fast_flush_purge_time = 7d
    fast_flush_refresh_time = 12h
    fault_injection_code = 0
    flush_service_name = flush
    fork_attempts = 5
    fork_delay = 1s
    forward_expansion_filter = [email protected]%-_=+:,./abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ
    forward_path = $home/.forward${recipient_delimiter}${extension},$home/.forward
    hash_queue_depth = 1
    hash_queue_names = incoming,active,deferred,bounce,defer,flush,hold
    header_address_token_limit = 10240
    header_checks = regexp:/etc/postfix/header_checks
    header_size_limit = 102400
    helpful_warnings = yes
    home_mailbox =
    hopcount_limit = 50
    ignore_mx_lookup_error = no
    import_environment = MAIL_CONFIG MAIL_DEBUG MAIL_LOGTAG TZ XAUTHORITY DISPLAY
    in_flow_delay = 1s
    inet_interfaces = all
    initial_destination_concurrency = 5
    invalid_hostname_reject_code = 501
    ipc_idle = 100s
    ipc_timeout = 3600s
    line_length_limit = 2048
    lmtp_cache_connection = yes
    lmtp_connect_timeout = 0s
    lmtp_data_done_timeout = 600s
    lmtp_data_init_timeout = 120s
    lmtp_data_xfer_timeout = 180s
    lmtp_lhlo_timeout = 300s
    lmtp_mail_timeout = 300s
    lmtp_quit_timeout = 300s
    lmtp_rcpt_timeout = 300s
    lmtp_rset_timeout = 300s
    lmtp_sasl_auth_enable = no
    lmtp_sasl_password_maps =
    lmtp_sasl_security_options = noplaintext, noanonymous
    lmtp_skip_quit_response = no
    lmtp_tcp_port = 24
    local_command_shell =
    local_destination_concurrency_limit = 2
    local_destination_recipient_limit = 1
    local_recipient_maps = proxy:unix<IMG SRC="images/forum/icons/icon_razz.gif">asswd.byname $alias_maps
    local_transport = local:$myhostname
    luser_relay =
    mail_name = Postfix
    mail_owner = postfix
    mail_release_date = 20030305
    mail_spool_directory = /var/spool/mail
    mail_version = 2.0.6
    mailbox_command = /usr/bin/procmail -Y -a $DOMAIN
    mailbox_command_maps =
    mailbox_delivery_lock = fcntl, dotlock
    mailbox_size_limit = 15000000
    mailbox_transport =
    mailq_path = /usr/bin/mailq.postfix
    manpage_directory = /usr/share/man
    maps_rbl_domains = relays.ordb.org blackholes.mail-abuse.org
    maps_rbl_reject_code = 554
    masquerade_classes = envelope_sender, header_sender, header_recipient
    masquerade_domains =
    masquerade_exceptions =
    max_idle = 100s
    max_use = 100
    maximal_backoff_time = 4000s
    maximal_queue_lifetime = 5d
    message_size_limit = 10240000
    mime_boundary_length_limit = 2048
    mime_header_checks = $header_checks
    mime_nesting_limit = 100
    minimal_backoff_time = 1000s
    mydestination = $myhostname, localhost.$mydomain, $mydomain, mail.$mydomain, www.$mydomain, ftp.$mydomain
    mydomain = eturbo.com.br
    myhostname = srv.eturbo.com.br
    mynetworks = 168.168.0.0/16, 192.168.51.0/16, 192.168.10.0/16, 127.0.0.0/8, 200.205.175.0/8,200.158.0.0/8, 200.171.0.0/8, 200.148.0.0/8, 200.181.119.0/8, 200.206.165.0/8
    mynetworks_style = subnet
    myorigin = $mydomain
    nested_header_checks = $header_checks
    newaliases_path = /usr/bin/newaliases.postfix
    non_fqdn_reject_code = 504
    notify_classes = resource,software
    owner_request_special = yes
    parent_domain_matches_subdomains = debug_peer_list,fast_flush_domains,mynetworks,permit_mx_backup_networks,qmqpd_authorized_clients,relay_domains,smtpd_access_maps
    permit_mx_backup_networks =
    pickup_service_name = pickup
    prepend_delivered_header = command, file, forward
    process_id_directory = pid
    program_directory = /usr/libexec/postfix
    propagate_unmatched_extensions = canonical, virtual
    proxy_interfaces =
    proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks
    qmgr_clog_warn_time = 300s
    qmgr_fudge_factor = 100
    qmgr_message_active_limit = 20000
    qmgr_message_recipient_limit = 20000
    qmgr_message_recipient_minimum = 10
    qmqpd_authorized_clients =
    qmqpd_error_delay = 1s
    qmqpd_timeout = 300s
    queue_directory = /var/spool/postfix
    queue_file_attribute_count_limit = 100
    queue_minfree = 0
    queue_run_delay = 1000s
    queue_service_name = qmgr
    rbl_reply_maps =
    readme_directory = /usr/share/doc/postfix-2.0.6/README_FILES
    recipient_canonical_maps =
    recipient_delimiter =
    reject_code = 554
    relay_clientcerts =
    relay_domains = $mydestination, /etc/postfix/relay-domains
    relay_domains_reject_code = 554
    relay_recipient_maps =
    relay_transport = relay
    relayhost =
    relocated_maps =
    require_home_directory = no
    resolve_dequoted_address = yes
    rewrite_service_name = rewrite
    sample_directory = /usr/share/doc/postfix-2.0.6/samples
    sender_canonical_maps =
    sendmail_path = /usr/sbin/sendmail.postfix
    service_throttle_time = 60s
    setgid_group = postdrop
    show_user_unknown_table_name = yes
    showq_service_name = showq
    smtp_always_send_ehlo = yes
    smtp_bind_address =
    smtp_connect_timeout = 30s
    smtp_data_done_timeout = 600s
    smtp_data_init_timeout = 120s
    smtp_data_xfer_timeout = 180s
    smtp_destination_concurrency_limit = $default_destination_concurrency_limit
    smtp_destination_recipient_limit = $default_destination_recipient_limit
    smtp_enforce_tls = no
    smtp_helo_name = $myhostname
    smtp_helo_timeout = 300s
    smtp_line_length_limit = 990
    smtp_mail_timeout = 300s
    smtp_never_send_ehlo = no
    smtp_pix_workaround_delay_time = 10s
    smtp_pix_workaround_threshold_time = 500s
    smtp_quit_timeout = 300s
    smtp_randomize_addresses = yes
    smtp_rcpt_timeout = 300s
    smtp_sasl_auth_enable = no
    smtp_sasl_password_maps =
    smtp_sasl_security_options = noplaintext, noanonymous
    smtp_skip_4xx_greeting = yes
    smtp_skip_5xx_greeting = yes
    smtp_skip_quit_response = yes
    smtp_starttls_timeout = 300s
    smtp_tls_CAfile =
    smtp_tls_CApath =
    smtp_tls_cert_file =
    smtp_tls_cipherlist =
    smtp_tls_dcert_file =
    smtp_tls_dkey_file = $smtp_tls_dcert_file
    smtp_tls_enforce_peername = yes
    smtp_tls_key_file = $smtp_tls_cert_file
    smtp_tls_loglevel = 0
    smtp_tls_note_starttls_offer = no
    smtp_tls_per_site =
    smtp_tls_session_cache_database =
    smtp_tls_session_cache_timeout = 3600s
    smtp_use_tls = no
    smtpd_banner = "Servidor de Email do Provedor Eturbo"
    smtpd_client_restrictions =
    smtpd_data_restrictions =
    smtpd_delay_reject = yes
    smtpd_enforce_tls = no
    smtpd_error_sleep_time = 1s
    smtpd_etrn_restrictions = permit_mynetworks, hash:/etc/postfix/client_access, reject
    smtpd_expansion_filter = \t\40!"#$%&&acute;()*+,-./0123456789:;<=>[email protected][\\]^_`abcdefghijklmnopqrstuvwxyz{|}~
    smtpd_hard_error_limit = 20
    smtpd_helo_required = yes
    smtpd_helo_restrictions =
    smtpd_history_flush_threshold = 100
    smtpd_junk_command_limit = 100
    smtpd_noop_commands =
    smtpd_null_access_lookup_key = <>
    smtpd_recipient_limit = 1000
    smtpd_recipient_restrictions = permit_mynetworks, reject_unauth_destination
    smtpd_restriction_classes =
    smtpd_sasl_auth_enable = no
    smtpd_sasl_local_domain =
    smtpd_sasl_security_options = noanonymous
    smtpd_sender_login_maps =
    smtpd_sender_restrictions =
    smtpd_soft_error_limit = 10
    smtpd_timeout = 300s
    smtpd_tls_CAfile =
    smtpd_tls_CApath =
    smtpd_tls_ask_ccert = no
    smtpd_tls_auth_only = no
    smtpd_tls_ccert_verifydepth = 5
    smtpd_tls_cert_file =
    smtpd_tls_cipherlist =
    smtpd_tls_dcert_file =
    smtpd_tls_dh1024_param_file =
    smtpd_tls_dh512_param_file =
    smtpd_tls_dkey_file = $smtpd_tls_dcert_file
    smtpd_tls_key_file = $smtpd_tls_cert_file
    smtpd_tls_loglevel = 0
    smtpd_tls_received_header = no
    smtpd_tls_req_ccert = no
    smtpd_tls_session_cache_database =
    smtpd_tls_session_cache_timeout = 3600s
    smtpd_tls_wrappermode = no
    smtpd_use_tls = no
    soft_bounce = no
    stale_lock_time = 500s
    strict_7bit_headers = no
    strict_8bitmime = no
    strict_8bitmime_body = no
    strict_mime_encoding_domain = no
    strict_rfc821_envelopes = no
    sun_mailtool_compatibility = no
    swap_bangpath = yes
    syslog_facility = mail
    syslog_name = postfix
    tls_daemon_random_bytes = 32
    tls_daemon_random_source =
    tls_random_bytes = 32
    tls_random_exchange_name = ${config_directory}/prng_exch
    tls_random_prng_update_period = 60s
    tls_random_reseed_period = 3600s
    tls_random_source =
    transport_maps =
    transport_retry_time = 60s
    trigger_timeout = 10s
    undisclosed_recipients_header = To: undisclosed-recipients:;
    unknown_address_reject_code = 450
    unknown_client_reject_code = 450
    unknown_hostname_reject_code = 450
    unknown_local_recipient_reject_code = 550
    unknown_relay_recipient_reject_code = 550
    unknown_virtual_alias_reject_code = 550
    unknown_virtual_mailbox_reject_code = 550
    verp_delimiter_filter = -=+
    virtual_alias_domains = $virtual_alias_maps
    virtual_alias_maps = $virtual_maps
    virtual_gid_maps =
    virtual_mailbox_base =
    virtual_mailbox_domains = $virtual_mailbox_maps
    virtual_mailbox_limit = 51200000
    virtual_mailbox_lock = fcntl
    virtual_mailbox_maps =
    virtual_minimum_uid = 100
    virtual_transport = virtual
    virtual_uid_maps =
    ja resolvi troquei o imap pelo courier-imap agora fico um foguete
