    Padrão Problemas com Make
    pessoal tou tentando instalar o courrier-imap e recebo esta mensagem quando dou MAKE ´´make´´.
    [email protected]:/usr/local/src/courier-imap-1.6.2> make
    make all-gmake-check FOO=BAR
    make[1]: Entering directory `/usr/local/src/courier-imap-1.6.2´
    make[1]: Leaving directory `/usr/local/src/courier-imap-1.6.2´
    Making all in numlib
    make[1]: Entering directory `/usr/local/src/courier-imap-1.6.2/numlib´
    make all-am
    make[2]: Entering directory `/usr/local/src/courier-imap-1.6.2/numlib´
    make[2]: Leaving directory `/usr/local/src/courier-imap-1.6.2/numlib´
    make[1]: Leaving directory `/usr/local/src/courier-imap-1.6.2/numlib´
    Making all in gdbmobj
    make[1]: Entering directory `/usr/local/src/courier-imap-1.6.2/gdbmobj´
    make all-am
    make[2]: Entering directory `/usr/local/src/courier-imap-1.6.2/gdbmobj´
    Compiling testgdbm.C
    ./../depcomp: exec: g++: not found
    make[2]: *** [testgdbm.o] Error 127
    make[2]: Leaving directory `/usr/local/src/courier-imap-1.6.2/gdbmobj´
    make[1]: *** [all] Error 2
    make[1]: Leaving directory `/usr/local/src/courier-imap-1.6.2/gdbmobj´
    make: *** [all-recursive] Error 1
    gdbm esta instalado
    este aqui no maildrop-1.3.7
    checking for gcc... gcc
    checking whether the C++ compiler (gcc ) works... no
    configure: error: installation or configuration problem: C++ compiler cannot create executables.
    configure: error: ./configure failed for gdbmobj
    []´s
    Fabio
    Pessoal
    o problema do maildrop eu jah resolvi, nada como um --nodeps --force
    O problema do courrier e que o g++ não está no meu path, como eu faço para inclui-lo ??
    []´s
    Fabio
