    Porque não esta gravando nestas pastas?
    # This is the main Samba configuration file. You should read the
    #"smb.conf" 245L, 9090C 34,0-1 Top
    # smb.conf(5) manual page in order to understand the options listed
    # here. Samba has a huge number of configurable options (perhaps too
    # many!) most of which are not shown in this example
    # Any line which starts with a ; (semi-colon) or a # (hash)
    # is a comment and is ignored. In this example we will use a #
    # for commentry and a ; for parts of the config file that you
    # may wish to enable
    # NOTE: Whenever you modify this file you should run the command "testparm"
    # to check that you have not many any basic syntactic errors.
    #======================= Global Settings =====================================
    [global]
    # workgroup = NT-Domain-Name or Workgroup-Name
    workgroup = GRUPO
    # server string is the equivalent of the NT Description field
    server string = Samba Server
    # This option is important for security. It allows you to restrict
    # connections to machines which are on your local network. The
    # following example restricts access to two C class networks and
    # the "loopback" interface. For more examples of the syntax see
    # the smb.conf man page
    ; hosts allow = 192.168.1. 192.168.2. 127.
    # if you want to automatically load your printer list rather
    # than setting them up individually then you´ll need this
    printcap name = /etc/printcap
    load printers = yes
    # It should not be necessary to spell out the print system type unless
    # yours is non-standard. Currently supported print systems include:
    # bsd, sysv, plp, lprng, aix, hpux, qnx
    printing = lprng
    # Uncomment this if you want a guest account, you must add this to /etc/passwd
    # otherwise the user "nobody" is used
    ; guest account = pcguest
    # this tells Samba to use a separate log file for each machine
    # that connects
    log file = /var/log/samba/log.%m
    # Put a capping on the size of the log files (in Kb).
    max log size = 50
    # Log level (0=none, 1=normal, 2 and above not recommended for production box)
    debug level = 1
    # Security mode. Most people will want user level security. See
    # security_level.txt for details.
    security = share
    # Use password server option only with security = server
    ; password server = <NT-Server-Name>
    # Password Level allows matching of _n_ characters of the password for
    # all combinations of upper and lower case.
    ; password level = 8
    ; username level = 8
    # You may wish to use password encryption. Please read
    # ENCRYPTION.txt, Win95.txt and WinNT.txt in the Samba documentation.
    # Do not enable this option unless you have read those documents
    ; encrypt passwords = yes
    ; smb passwd file = /etc/smbpasswd
    # The following are needed to allow password changing from Windows to
    # update the Linux sytsem password also.
    # NOTE: Use these with &acute;encrypt passwords&acute; and &acute;smb passwd file&acute; above.
    # NOTE2: You do NOT need these to allow workstations to change only
    # the encrypted SMB passwords. They allow the Unix password
    # to be kept in sync with the SMB password.
    ; unix password sync = Yes
    ; passwd program = /usr/bin/passwd %u
    ; passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
    # Unix users can map to different SMB User names
    ; username map = /etc/smbusers
    # Using the following line enables you to customise your configuration
    # on a per machine basis. The %m gets replaced with the netbios name
    # of the machine that is connecting
    ; include = /etc/smb.conf.%m
    # Most people will find that this option gives better performance.
    # See speed.txt and the manual pages for details
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    # Configure Samba to use multiple interfaces
    # If you have multiple network interfaces then you must list them
    # here. See the man page for details.
    ; interfaces = 192.168.12.2/24 192.168.13.2/24
    # Configure remote browse list synchronisation here
    # request announcement to, or browse list sync from:
    # a specific host or from / to a whole subnet (see below)
    ; remote browse sync = 192.168.3.25 192.168.5.255
    # Cause this host to announce itself to local subnets here
    ; remote announce = 192.168.1.255 192.168.2.44
    # Browser Control Options:
    # set local master to no if you don&acute;t want Samba to become a master
    # browser on your network. Otherwise the normal election rules apply
    ; local master = no
    # OS Level determines the precedence of this server in master browser
    # elections. The default value should be reasonable
    ; os level = 33
    # Domain Master specifies Samba to be the Domain Master Browser. This
    # allows Samba to collate browse lists between subnets. Don&acute;t use this
    # if you already have a Windows NT domain controller doing this job
    ; domain master = yes
    # Preferred Master causes Samba to force a local browser election on startup
    # and gives it a slightly higher chance of winning the election
    ; preferred master = yes
    # Use only if you have an NT server on your network that has been
    # configured at install time to be a primary domain controller.
    ; domain controller = <NT-Domain-Controller-SMBName>
    # Enable this if you want Samba to be a domain logon server for
    # Windows95 workstations.
    ; domain logons = yes
    # if you enable domain logons then you may want a per-machine or
    # per user logon script
    # run a specific logon batch file per workstation (machine)
    ; logon script = %m.bat
    # run a specific logon batch file per username
    ; logon script = %U.bat
    # Where to store roving profiles (only for Win95 and WinNT)
    # %L substitutes for this servers netbios name, %U is username
    # You must uncomment the [Profiles] share below
    ; logon path = \\%L\Profiles\%U
    # All NetBIOS names must be resolved to IP Addresses
    # &acute;Name Resolve Order&acute; allows the named resolution mechanism to be specified
    # the default order is "host lmhosts wins bcast". "host" means use the unix
    # system gethostbyname() function call that will use either /etc/hosts OR
    # DNS or NIS depending on the settings of /etc/host.config, /etc/nsswitch.conf
    # and the /etc/resolv.conf file. "host" therefore is system configuration
    # dependant. This parameter is most often of use to prevent DNS lookups
    # in order to resolve NetBIOS names to IP Addresses. Use with care!
    # The example below excludes use of name resolution for machines that are NOT
    # on the local network segment
    # - OR - are not deliberately to be known via lmhosts or via WINS.
    ; name resolve order = wins lmhosts bcast
    # Windows Internet Name Serving Support Section:
    # WINS Support - Tells the NMBD component of Samba to enable it&acute;s WINS Server
    ; wins support = yes
    # WINS Server - Tells the NMBD components of Samba to be a WINS Client
    # Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
    ; wins server = w.x.y.z
    # WINS Proxy - Tells Samba to answer name resolution queries on
    # behalf of a non WINS capable client, for this to work there must be
    # at least one WINS Server on the network. The default is NO.
    ; wins proxy = yes
    # DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
    # via DNS nslookups. The built-in default for versions 1.9.17 is yes,
    # this has been changed in version 1.9.18 to no.
    dns proxy = no
    unix password sync = no
    encrypt passwords = no
    map to guest = never
    password level = 0
    null passwords = no
    os level = 0
    preferred master = no
    domain master = no
    wins support = no
    dead time = 0
    # Case Preservation can be handy - system default is _no_
    # NOTE: These can be set on a per share basis
    ; preserve case = no
    ; short preserve case = no
    # Default case is normally upper case for all DOS files
    ; default case = lower
    # Be very careful with case sensitivity - it can break things!
    ; case sensitive = no
    #============================ Share Definitions ==============================
    [homes]
    comment = Home Directories
    browseable = no
    writable = yes
    # Un-comment the following and create the netlogon directory for Domain Logons
    ; [netlogon]
    ; comment = Network Logon Service
    ; path = /home/netlogon
    ; guest ok = yes
    ; writable = no
    ; share modes = no
    # Un-comment the following to provide a specific roving profile share
    # the default is to use the user&acute;s home directory
    ;[Profiles]
    ; path = /home/profiles
    ; browseable = no
    ; guest ok = yes
    # NOTE: If you have a BSD-style print system there is no need to
    # specifically define each individual printer
    [printers]
    comment = All Printers
    path = /var/spool/samba
    browseable = no
    # Set public = yes to allow user &acute;guest account&acute; to print
    guest ok = no
    writable = no
    printable = yes
    [deposito]
    comment = Public
    available = yes
    browseable = yes
    public = yes
    guest only = no
    writable = yes
    allow hosts = 192.168.10.
    only user = no
    path = /home/samba
    [httpd]
    comment = Dinamic Pages
    available = yes
    browseable = yes
    path = /home/httpd
    public = yes
    guest only = no
    writable = yes
    only user = no
    glasswalk3r
    cheque as permissões do sistema de arquivos com ls -l e chmod.
  1. crontab -e não grava alterações
    Por nod3vic3 no fórum Servidores de Rede
    Último Post: 08-07-2005, 10:07
  2. Roaming Profile nao grava alteracoes de configuracao do XP
    Por jvdebian no fórum Servidores de Rede
    Respostas: 8
    Último Post: 31-05-2005, 11:20
  3. Fedora 2 não grava minhas configurações de video !
    Por ricardodru no fórum Servidores de Rede
    Último Post: 23-02-2005, 16:44
  4. k3b nao grava mp3
    Por SDM no fórum Servidores de Rede
    Respostas: 6
    Último Post: 13-02-2005, 15:35
  5. lokkit não grava as mudanças
    Último Post: 31-07-2003, 09:14
