    Padrão SLACK9 e kernel 2.4.21
    estou tentando compilar meu kernel, porem, estoum tendo os seguintes erros
    *** End of Linux kernel configuration.
    *** Check the top-level Makefile for additional configuration.
    *** Next, you must run ´make dep´.
    [email protected]:/usr/src/linux-2.4.21# make bzImage
    gcc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -o scripts/mkdep scripts/mkdep.c
    In file included from /usr/include/bits/posix1_lim.h:126,
    from /usr/include/limits.h:144,
    from /usr/lib/gcc-lib/i386-slackware-linux/3.2.2/include/limits.h:132,
    from /usr/lib/gcc-lib/i386-slackware-linux/3.2.2/include/syslimits.h:7,
    from /usr/lib/gcc-lib/i386-slackware-linux/3.2.2/include/limits.h:11,
    from scripts/mkdep.c:35:
    /usr/include/bits/local_lim.h:36:26: linux/limits.h: No such file or directory
    scripts/mkdep.c: In function `add_path´:
    scripts/mkdep.c:221: `PATH_MAX´ undeclared (first use in this function)
    scripts/mkdep.c:221: (Each undeclared identifier is reported only once
    scripts/mkdep.c:221: for each function it appears in.)
    scripts/mkdep.c:221: warning: unused variable `resolved_path´
    make: *** [scripts/mkdep] Error 1
    <IMG SRC="images/forum/icons/icon_cool.gif">
    Jul 2001
    Campinas Area
    Bom Belotto, faca:
    make dep ; make clean ; make bzImage ; cp /usr/src/linux-2.4.21/arch/i386/boot/bzImage /boot/vmlinuz ; make modules ; make modules_install ; make bzlilo ; reboot
    desculpa
    enviei o texto errado
    eu to tentando dar o make dep primeiro
    so q ele ja ta dando erro, eh q eu fiz um teste usando direto make bzImage
    e acabei copiando o texto errado
    eu vo pegar o texto certinho de quando do o make dep e posto aki depois
    beijos!
    vai no no ftp do slackware baixa e instala o kernel-headers-2.4.21
    KsKtA
    KsKtA
