- Erro a Instalar Mplayer
Creating config.mak
Creating config.h
Creating libvo/config.mak
Creating libao2/config.mak
Creating help_mp.h
Adding untranslated messages to help_mp.h
Config files successfully generated by ./configure !
Install prefix: /usr/local
Data directory: /usr/local/share/mplayer
Config direct.: /usr/local/etc/mplayer
Byte order: Little Endian
Optimizing for: i686 mmx mmx2 sse mtrr
Enabled optional drivers:
Input: streaming edl tv cdda mpdvdkit2 vcd
Codecs: qtx libavcodec real xanim dshow/dmo win32 libvorbis libmad gif
Audio output: esd arts oss sdl mpegpes(file)
Video output: xvidix sdl vesa gif89a jpeg png mpegpes(file) fbdev svga aa xmga mga opengl dga xv x11
Disabled optional drivers:
Input: tv-v4l tv-bsdbt848 dvdnav dvdread dvdcss smb
Codecs: opendivx xvid libdv liblzo
Audio output: sgi sun alsa dxr2 nas win32
Video output: bl zr dxr3 dxr2 directx ggi directfb tdfxfb 3dfx
´config.h´ and ´config.mak´ contain your configuration options.
Note: If you alter theses files (for instance CFLAGS) MPlayer may no longer
compile *** DO NOT REPORT BUGS if you tweak these files ***
´make´ will now compile MPlayer and ´make install´ will install it.
Note: On non-Linux systems you might need to use ´gmake´ instead of ´make´.
Please check mtrr settings at /proc/mtrr (see DOCS/video.html#mtrr)
Check configure.log if you wonder why an autodetection failed (check whether
the development headers/packages are installed).
If you suspect a bug, please read DOCS/bugreports.html.
