    geek
    Nome: kernel-2.4.21.0.25mdk
    Versão: 1-1mdk
    Tamanho: 17665 KB
    Resumo: The Linux kernel (the core of the Linux operating system).
    Descrição: The kernel package contains the Linux kernel (vmlinuz), the core of your Mandrake Linux operating system. The kernel handles the basic functions of the operating system: memory allocation, process allocation, device input and output, etc.
    Nome: kernel-BOOT-2.4.21.0.25mdk
    Versão: 1-1mdk
    Tamanho: 6568 KB
    Resumo: The version of the Linux kernel used on installation boot disks.
    Descrição: This package includes a trimmed down version of the Linux kernel. This kernel is used on the installation boot disks only and should not be used for an installed system, as many features in this kernel are turned off because of the size constraints.
    Nome: kernel-doc
    Versão: 2.4.21-0.25mdk
    Tamanho: 5378 KB
    Resumo: Various documentation bits found in the kernel source.
    Descrição: This package contains documentation files form the kernel source. Various bits of information about the Linux kernel and the device drivers shipped with it are documented in these files. You also might want install this package if you need a reference to the options that can be passed to Linux kernel modules at load time.
    Nome: kernel-enterprise-2.4.21.0.25mdk
    Versão: 1-1mdk
    Tamanho: 17599 KB
    Resumo: The Linux Kernel compiled with options for Enterprise server usage.
    Descrição: This package includes a kernel that has appropriate configuration options enabled for the typical large enterprise server. This includes SMP support for multiple processor machines, support for large memory configurations and other appropriate items.
    Nome: kernel-secure-2.4.21.0.25mdk
    Versão: 1-1mdk
    Tamanho: 18068 KB
    Resumo: The Linux Kernel compiled for SECURE machines.
    Descrição: This package includes a SECURE version of the Linux 2.4.21 kernel. This package add options for kernel that make it more secure for servers and such. See :
    http://grsecurity.net/features.htm
    for list of features we have included.
    Nome: kernel-smp-2.4.21.0.25mdk
    Versão: 1-1mdk
    Tamanho: 18002 KB
    Resumo: The Linux Kernel compiled for SMP machines.
    Descrição: This package includes a SMP version of the Linux 2.4.21 kernel. It is required only on machines with two or more CPUs, although it should work fine on single-CPU boxes.
    Nome: kernel-source
    Tamanho: 158399 KB
    Resumo: The source code for the Linux kernel.
    Descrição: The kernel-source package contains the source code files for the Linux kernel. These source files are needed to build most C programs, since they depend on the constants defined in the source code. The source files can also be used to build a custom kernel that is better tuned to your particular hardware, if you are so inclined (and you know what you´re doing).
    Será que alguém poderia me dizer para que serve esses pacotes? Eu utilizo o Mandrake Linux 9.1, se alguém quiser traduzir... melhor ainda.
  2. Bom nao eh dificil isso ... apenas tenha em mente que voce prescisa do kernel , kernel-* , onde * eh boot, enterprise entre outros voce nao prescisa para sua maquina maquina desktop
    BOOT - usado em disketes de boot
    doc - documentacao (ohhh)
    enterprise - maquinas com > 4gb ram
    smp - 2 proc ou mais
    geek
    E ai mistymst,
    Para uma maquina desktop, do que eu precisaria então dentre todos esses ai?
    Eu não entendi muito bem sober esse smp, será que poderia me explicar também sobre o secure? Acho que você esqueceu.
  4. geek,
    o pacote secure adiciona ao kernel mais opções de segurança às suas ja existentes, tipow... naum conheco mto bem quais seriam essas opções, e o link q ele indica soh pra ajudar esta quebrado hehe
    o smp eh um outro kernel q eh usado quando vc tem uma placa q possua dois processadores, esse kernel possui uma estrutura diferente, uma vez instalado ele identifica as cpus e quebra o processamento entre os dois processadores existentes (mais ou menos)
    smp eh um topico interessante, usado com frequencia em servidores, acho q vale ateh uma pesquisa no google
    t+ kra <IMG SRC="images/forum/icons/icon_wink.gif"> <IMG SRC="images/forum/icons/icon_wink.gif"> <IMG SRC="images/forum/icons/icon_wink.gif">
    geek
    demiurgo,
    E esse pacote kernel-BOOT-2.4.21.0.25mdk serve para que?
    Diz rapido ae, porque já estou fazendo o download os pacotes para instala-los.
  1. Respostas: 1
    Último Post: 13-05-2007, 05:50
  2. Erro durante copilar kernel 2.4.21-31301U90_4cl do conectiva
    Por gilmarcabral no fórum Servidores de Rede
    Último Post: 27-05-2005, 15:31
  3. SLACK9 e kernel 2.4.21
    Último Post: 02-07-2003, 11:22
  4. kernel 2.4.21
    Último Post: 17-06-2003, 17:26
  5. Kernel 2.4.21 Conectiva CL 9.0
    Por Itise no fórum Servidores de Rede
    Respostas: 17
    Último Post: 08-05-2003, 21:56
