    Padrão Resolução de video no slack 8
    pessoal que deixa meu X com resolução 800X600 mas não funciona
    eu mudo mas parece não surti efeito . segue abaixo o meu XF86config
    Section "ServerLayout"
    Identifier "XFree86 Configured"
    Screen 0 "Screen0" 0 0
    InputDevice "Mouse0" "CorePointer"
    InputDevice "Keyboard0" "CoreKeyboard"
    EndSection
    Section "Files"
    RgbPath "/usr/X11R6/lib/X11/rgb"
    ModulePath "/usr/X11R6/lib/modules"
    FontPath "/usr/X11R6/lib/X11/fonts/misc/"
    FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
    FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
    FontPath "/usr/X11R6/lib/X11/fonts/CID/"
    FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
    FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
    EndSection
    Section "Module"
    Load "dbe"
    Load "dri"
    Load "extmod"
    Load "glx"
    Load "record"
    Load "xtrap"
    Load "speedo"
    Load "type1"
    EndSection
    Section "InputDevice"
    Identifier "Keyboard0"
    Driver "keyboard"
    Option "XkbModel" "microsoft"
    Option "XkbLayout" "br"
    EndSection
    Identifier "Mouse0"
    Driver "mouse"
    Option "Protocol" "auto"
    Option "Device" "/dev/mouse"
    EndSection
    Section "Monitor"
    #DisplaySize 280 210 # mm
    Identifier "Monitor0"
    VendorName "DWE"
    ModelName "5093"
    HorizSync 31.5 - 31.5
    VertRefresh 50.0 - 70.0
    Option "DPMS"
    EndSection
    Section "Device"
    ### Available Driver options are:-
    ### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
    ### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
    ### [arg]: arg optional
    #Option "SWcursor" # [<bool>]
    #Option "PciRetry" # [<bool>]
    #Option "NoAccel" # [<bool>]
    #Option "SetMClk" # <freq>
    #Option "MUXThreshold" # <i>
    #Option "ShadowFB" # [<bool>]
    #Option "Rotate" # [<str>]
    #Option "VideoKey" # <i>
    #Option "NoMMIO" # [<bool>]
    #Option "NoPciBurst" # [<bool>]
    #Option "MMIOonly" # [<bool>]
    #Option "CyberShadow" # [<bool>]
    #Option "CyberStretch" # [<bool>]
    #Option "XvHsync" # <i>
    #Option "XvVsync" # <i>
    #Option "XvBskew" # <i>
    #Option "XvRskew" # <i>
    Identifier "Card0"
    Driver "trident"
    VendorName "Trident"
    BoardName "Blade3D"
    BusID "PCI:1:0:0"
    EndSection
    Section "Screen"
    Identifier "Screen0"
    Device "Card0"
    Monitor "Monitor0"
    DefaultDepth 16
    SubSection "Display"
    Depth 15
    Modes "800x600"
    EndSubSection
    Depth 16
    Modes "800x600"
    EndSubSection
    EndSection
    replicante
    tipo ... vc tem q ter em mãos o nome da tua placa de video e os hz do teu monitor Vertical e Horizontal, ae vc digita:
    # xf86config
    ele vai perdir configurações do mouse, teclado e depois vai pedir do monitor e placa de video, se vc naum tiver ideia do teu monitor nem placa coloque a opção 6 para monitor (que funciona bem para monitores mais novos) e 0 para placa de video que é o genericão das placas de video.
    falow,
    Já tentou rodar o Xconfigurator ???
    Solver
    Naum deixa ele escolher automaticamente as opcoes de video e monitor,
    falou!
    na sessão screen eu coloquei option "800" "600"
    e funcionou . agora estou com dois problemas o monitor muito claro , muito brilhante acho que isso tem haver com a pronfudidade , não é ? e outra coisa eu instalai as fontes do windows(arial,verdana) e coloquei pra ele colocar anti-alising . beleza no menu K ta fucionando mas no navegador não eu utilizo o netsacep. o que poderia ser ?
