    JDboard
    Padrão Socorroooooooooooo!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Gente eu estou precisando muito configurar o samba e u ja fiz de tudo e nada da certo !!
    O smb.conf esta tudo em branco o que que eu faco!!Olhem So:
    [[email protected] samba-2.2.8a]# smbclient -l webstream
    params.c<IMG SRC="images/forum/icons/icon_eek.gif">penConfFile() - Unable to open configuration file "/etc/samba/smb.conf":
    No such file or directory
    Can&acute;t load /etc/samba/smb.conf - run testparm to debug it
    added interface ip=10.10.0.10 bcast=10.10.0.255 nmask=255.255.255.0
    Usage: smbclient service <password> [options]
    Version 2.2.7a
    -s smb.conf pathname to smb.conf file
    -O socket_options socket options to use
    -R name resolve order use these name resolution services only
    -M host send a winpopup message to the host
    -i scope use this NetBIOS scope
    -N don&acute;t ask for a password
    -n netbios name. Use this name as my netbios name
    -d debuglevel set the debuglevel
    -P connect to service as a printer
    -p port connect to the specified port
    -l log basename. Basename for log/debug files
    -h Print this help message.
    -I dest IP use this IP to connect to
    -E write messages to stderr instead of stdout
    -U username set the network username
    -L host get a list of shares available on a host
    -t terminal code terminal i/o code {sjis|euc|jis7|jis8|junet|hex}
    -m max protocol set the max protocol level
    -A filename get the credentials from a file
    -W workgroup set the workgroup name
    -T<c|x>IXFqgbNan command line tar
    -D directory start from directory
    -c command string execute semicolon separated commands
    -b xmit/send buffer changes the transmit/send buffer (default: 65520)
    Me deem uma luz p[or favor nao sei mas o que fazer !!
    O manual manda uma coisa e o computador outra !!
    LeonSimpai <IMG SRC="images/forum/icons/icon_biggrin.gif">
    dark_exs
    Meu é facil, vc vai fazer o seguinte:
    instale o pacote do samba swat, libere e linha do swat no arquivo "/etc/inetd.conf" , reinicie o serviço inetd.
    De um browser vc acessa "http://<ip do smb>:901" e pronto é só configurar
    Falow,
    Qualquer coisa escreva
    Dark_exs
    [email protected]
