    Delano
    Padrão Problema com sarg
    Boa tarde pessoal!
    Preciso da ajuda de vcs. Estou tentando ver os logs do squid pelo sarg. Ja li todas as mensagens anteriores sobre esse assunto e por enquanto...nada.
    Bom, é o seguinte: no /root eu executo o seguinte comando: /usr/sbin/sarg -f /etc/sarg/sarg.conf -l /var/log/squid/access.log -o /var/www/html/squid-report/dia
    Já tentei usar somente "sarg", colocar a općão -d com o periodo e sempre da a mesma mensagem:
    SARG: Nao ha registros
    SARG: Fim
    Eu uso o Redhat 8.
    O meu sarg.conf está assim:
    # sarg.conf
    # TAG: language
    # Available languages:
    # Bulgarian_windows1251
    # Czech
    # Dutch
    # English
    # French
    # German
    # Hungarian
    # Indonesian
    # Italian
    # Japanese
    # Latvian
    # Polish
    # Portuguese
    # Romanian
    # Russian_koi8
    # Russian_windows1251
    # Serbian
    # Spanish
    # Turkish
    language Portuguese
    # TAG: access_log file
    # Where is the access.log file
    # sarg -l file
    #access_log /usr/local/squid/logs/access.log
    access_log /var/log/squid/access.log
    # RedHat version
    # Especify the font for html page.
    font_face Arial
    # TAG: header_color
    # Especify the header color
    header_color darkblue
    # TAG: header_bgcolor
    # Especify the header bgcolor
    header_bgcolor blanchedalmond
    # TAG: font_size
    # TAG: font_size
    # Especify the font size
    header_font_size -1
    # TAG: background_color
    # Html page background color
    background_color white
    # TAG: text_color
    # Html page text color
    text_color black
    # TAG: text_bgcolor
    # Html page text background color
    text_bgcolor beige
    # TAG: title_color
    # Html page title color
    title_color green
    # TAG: logo_image
    # Html page logo.
    #logo_image none
    # TAG: logo_text
    # Html page logo text.
    #logo_text ""
    # TAG: logo_text_color
    # Html page logo texti color.
    #logo_text_color black
    # TAG: logo_image_size
    # Html page logo image size.
    # width height
    #image_size 80 45
    # TAG: background_image
    # Html page background image
    #background_image none
    # TAG: password
    # User password file used by authentication
    # If you put here, reports will be generated only for users in.
    #password none
    # TAG: temporary_dir
    # Temporary directory name
    # sarg -w dir
    temporary_dir /tmp
    # TAG: output_dir
    # Where is the reports will ne stored.
    # sarg -o dir
    #output_dir /usr/local/etc/httpd/htdocs/squid-reports
    output_dir /home/httpd/html/squid-reports
    # RedHat version
    # TAG: output_email
    # Email address to send the reports
    # sarg -e email
    #output_email none
    # TAG: resolve_ip yes/no
    # Convert ip address to dns name
    # sarg -n
    resolve_ip no
    # TAG: user_ip yes/no
    # Use Ip Address instead userid (reports)
    # sarg -p
    user_ip yes
    # TAG: topuser_sort_field field normal/reverse
    # Sort field for the Topuser Report.
    # Allowed fields: USER CONNECT BYTES TIME
    topuser_sort_field BYTES reverse
    # TAG: user_sort_field field normal/reverse
    # Sort field for the User Report.
    # Allowed fields: SITE CONNECT BYTES TIME
    # TAG: exclude_users file
    # users within the file will be excluded from reports.
    # you can use indexonly to have only index.html file.
    exclude_users none
    # TAG: exclude_hosts file
    # Hosts, domains or subnets will be excluded from reports.
    # Eg.: 192.168.10.10 - exclude ip address only
    # 192.168.10.0 - exclude full C class
    # s1.acme.foo - exclude hostname only
    # acme.foo - exclude full domain name
    exclude_hosts none
    # TAG: useragent_log file
    # Put here where is useragent.log to nable useragent report.
    useragent_log none
    # TAG: date_format
    # Date format in reports: e (Europe=dd/mm/yy), u (USA=mm/dd/yy), w (Weekly=yy.ww)
    date_format e
    # TAG: per_user_limit file MB
    # Save userid on file if download exceed n MB.
    # This option can be used to disable user access if user exceed a download limit.
    per_user_limit none
    # TAG: lastlog n
    # How many reports files must be keept in reports directory.
    # The oldest report file will be automatically removed.
    # 0 - no limit.
    lastlog 0
    # TAG: remove_temp_files yes
    # Remove temporary files: geral, usuarios, top, periodo from root report directory.
    # TAG: index yes|no|only
    # Generate the main index.html.
    # only - generate only the main index.html
    index yes
    # TAG: overwrite_report yes|no
    # yes - if report date already exist then will be overwrited.
    # no - if report date already exist then will be renamed to filename.n, filename.n+1
    # TAG: records_without_userid ignore|ip|everybody
    # What can I do with records without user id (no authentication) in access.log file ?
    # ignore - This record will be ignored.
    # ip - Use ip address instead. (default)
    # everybody - Use "everybody" instead.
    # TAG: use_comma no|yes
    # Use comma instead point in reports.
    # Eg.: use_comma yes => 23,450,110
    # use_comma no => 23.450.110
    use_comma no
    # TAG: mail_utility mail|mailx
    # Mail command to use to send reports via SMTP
    #mail_utility mailx
    # TAG: topsites_num n
    # How many sites in topsites report.
    topsites_num 10
    # TAG: topsites_sort_order CONNECT|BYTES A|D
    # Sort for topsites report, where A=Ascendent, D=Descendent
    topsites_sort_order BYTES D
    # TAG: exclude_codes file
    # Ignore records with these codes. Eg.: NONE/400
    exclude_codes /usr/local/sarg/exclude_codes
    # TAG: replace_index string
    # Replace "index.html" in the main index file with this string
    # If null "index.html" is used
    #replace_index <?php echo str_replace(".", "_", $REMOTE_ADDR); echo ".html"; ?>
    # TAG: max_elapsed milliseconds
    # If elapsed time is recorded in log is greater than max_elapsed use 0 for elapsed time.
    # Use 0 for no checking
    #max_elapsed 0
    # 8 Hours
    max_elapsed 28800000
    # TAG: report_type type
    # What kind of reports to generate.
    # topsites - shows the site, connect and bytes
    # sites_users - shows which users were accessing a site
    # users_sites - shows sites accessed by the user
    # date_time - shows the amount of bytes used by day and hour
    # denied - show all denied sites with full URL
    # auth_failures - show autentication failures
    # Eg.: report_type topsites denied
    report_type topsites users_sites sites_users date_time denied auth_failures site_user_time_date
    # TAG: usertab filename
    # You can change the "userid" or the "ip address" to be a real user name on the rpeorts.
    # Table syntax:
    # userid name or ip address name
    # Eg:
    # SirIsaac Isaac Newton
    # vinci Leonardo da Vinci
    # 192.168.10.1 Karol Wojtyla
    # Each line must be terminated with &acute;\n&acute;
    usertab none
    # TAG: long_url yes|no
    # If yes, the full url is showed in report.
    # If no, only the site will be showed
    # YES option generate very big sort files and reports.
    long_url no
    # TAG: date_time_by bytes|elap
    # Date/Time reports will use bytes or elapsed time?
    date_time_by bytes
    # TAG: charset name
    # ISO 8859 is a full series of 10 standardized multilingual single-byte coded (8bit)
    # graphic character sets for writing in alphabetic languages
    # You can use the following charsets:
    # Latin1 - West European
    # Latin2 - East European
    # Latin3 - South European
    # Latin4 - North European
    # Cyrillic
    # Arabic
    # Greek
    # Hebrew
    # Latin5 - Turkish
    # Latin6
    # Windows-1251
    # Koi8-r
    charset Latin1
    # TAG: user_invalid_char "&/"
    # Records that contain invalid characters in userid will be ignored by Sarg.
    #user_invalid_char "&/"
    # TAG: privacy yes|no
    # privacy_string "***.***.***.***"
    # privacy_string_color blue
    # In some countries the sysadm cannot see the visited sites by a restrictive law.
    # Using privacy yes the visited url will be changes by privacy_string and the link
    # will be removed from reports.
    #privacy no
    #privacy_string "***.***.***.***"
    #privacy_string_color blue
    # TAG: include_users "user1:user2:...:usern"
    # Reports will be generated only for listed users.
    include_users none
    # TAG: exclude_string "string1:string2:...:stringn"
    # Records from access.log file that contain one of listed strings will be ignored.
    #exclude_string none
    # TAG: show_successful_message yes|no
    # Show "Successful report generated on dir" at end of process.
    # TAG: topuser_fields
    # Which fields must be in Topuser report.
    topuser_fields NUM DATE_TIME USERID CONNECT BYTES %BYTES IN-CACHE-OUT USED_TIME MILISEC %TIME TOTAL AVERAGE
    # TAG: topuser_num n
    # How many users in topsites report. 0 = no limit
    topuser_num 0
    Se alguem puder ajudar agradećo.null
    pensador-ce
    galera eu to com o mesmo problema do colega, alguém pode nojs ajuadar??? <IMG SRC="images/forum/icons/icon_confused.gif">
    Bom dia pensador!
    Conseguiu resolver o problema: Faltavam algumas linhas no sarg.conf da versão do sarg que eu fiz download. Segue abaixo a versão correta. Note que as ultima linhas não estavam na minha primeira mensagem. Vc precisa digitar apenas "sarg" para gerar o relotório, ou "sarg -d 07/09/03" por exemplo se quiser o relatorio do dia 07/09. Me mande um email se deu certo.
    [email protected].( não esqueça de ver se seu caminho para os logs do squid é o mesmo do meu arquivo)
    # sarg.conf
    # TAG: language
    # Catalan
    # Czech
    # Dutch
    # English
    # French
    # German
    # Hungarian
    # Indonesian
    # Italian
    # Japanese
    # Latvian
    # Polish
    # Portuguese
    # Romanian
    # Russian_koi8
    # Serbian
    # Spanish
    # Turkish
    language English
    # sarg -l file
    access_log /etc/access.log
    # TAG: title
    # Especify the title for html page.
    title "Squid User Access Reports"
    # TAG: font_face
    font_face Arial
    # TAG: header_color
    # TAG: font_size
    # TAG: font_size
    header_font_size -1
    # TAG: text_color
    text_color black
    # TAG: text_bgcolor
    text_bgcolor beige
    # TAG: title_color
    title_color green
    # TAG: logo_image
    # Html page logo.
    logo_image none
    # TAG: logo_text
    logo_text ""
    # width height
    image_size 80 45
    # TAG: password
    # If used here, reports will be generated only for that users.
    #password /root/passwd_internet
    # Temporary directory name for work files
    # sarg -w dir
    temporary_dir /tmp
    # TAG: output_dir
    # The reports will be saved in that directory
    # sarg -o dir
    output_dir /var/www/html/squid1
    # TAG: output_email
    # Email address to send the reports. If you use this tag, no html reports will be generated.
    # sarg -e email
    #output_email none
    # sarg -n
    #resolve_ip no
    # Use Ip Address instead userid in reports.
    # sarg -p
    #user_ip no
    #exclude_users none
    #exclude_hosts none
    #useragent_log none
    # TAG: date_format
    date_format e
    #per_user_limit none
    # TAG: lastlog n
    # 0 - no limit.
    lastlog 0
    index yes
    records_without_userid ip
    #use_comma no
    #mail_utility mailx
    topsites_num 100
    topsites_sort_order CONNECT D
    # TAG: index_sort_order A/D
    # Sort for index.html, where A=Ascendent, D=Descendent
    index_sort_order D
    #max_elapsed 0
    # 8 Hours
    # denied - shows all denied sites with full URL
    # auth_failures - shows autentication failures
    # site_user_time_date - shows sites, dates, times and bytes
    report_type topsites sites_users users_sites date_time denied auth_failures site_user_time_date
    # Table syntax:
    # Eg:
    #usertab none
    #long_url no
    date_time_by bytes
    # TAG: charset name
    # Cyrillic
    # Arabic
    # Greek
    # Hebrew
    # Latin5 - Turkish
    # Latin6
    # Windows-1251
    # Koi8-r
    charset Latin1
    #privacy no
    #include_users none
    # Shows "Successful report generated on dir" at end of process.
    # TAG: show_read_statistics yes|no
    # Shows some reading statistics.
    # TAG: user_report_fields
    # Which fields must be in User report.
    #user_report_fields CONNECT BYTES %BYTES IN-CACHE-OUT USED_TIME MILISEC %TIME TOTAL AVERAGE
    topuser_num 0
    # TAG: site_user_time_date_type list|table
    # generate reports for site_user_time_date in list or table format
    #site_user_time_date_type table
    # TAG: datafile file
    # Save the report results in a file to populate some database
    #datafile none
    # TAG: datafile_delimiter ";"
    # ascii character to use as a field separator in datafile
    #datafile_delimiter ";"
    # TAG: datafile_fields all
    # Which data fields must be in datafile
    # user;date;time;url;connect;bytes;in_cache;out_cache;elapsed
    #datafile_fields user;date;time;url;connect;bytes;in_cache;out_cache;elapsed
    # TAG: weekdays
    # The weekdays to take account ( Sunday->0, Saturday->6 )
    # Example:
    #weekdays 1-3,5
    # Default:
    #weekdays 0-6
    # TAG: hours
    # The hours to take account
    # Example:
    #hours 7-12,14,16,18-20
    # Default:
    #hours 0-23
    # TAG: squidguard_log_path file
    # Generate reports from SquidGuard logs.
    #squidguard_log_path none
    # TAG: show_sarg_info yes|no
    # shows sarg information and site patch on each report bottom
    show_sarg_info yes
    # TAG: parsed_output_log directory
    # Saves the processed log in a sarg format after parsing the squid log file.
    # This is a way to dump all of the data structures out, after parsing from
    # the logs (presumably this data will be much smaller than the log files themselves),
    # and pull them back in for later processing and merging with data from previous logs.
    #parsed_output_log none
    # TAG parsed_output_log_compress /bin/gzip|/usr/bin/bzip2|nocompress
    # sarg logs compress util
    # TAG displayed_values bytes|abbreviation
    # how the values will be displayed in reports.
    # eg. bytes - 209.526
    # abbreviation - 210K
    displayed_values abbreviation
    obs.: Consegui esta copia na lista do Orso-br
