  1. Ae galera tentei aquelas jogadas de colocar o .xinitrc no home do usuário e nada dá esse erro:
    $ startx
    Using authority file /home/caline/.Xauthority
    Writing authority file /home/caline/.Xauthority
    Fatal server error:
    Cannot move old logfile "/var/log/XFree86.0.log.old"
    When reporting a problem related to a server crash, please send
    the full server output, not just the last messages.
    Please report problems to xfree86@xfree86.org.
    giving up.
    xinit: Connection refused (errno 111): unable to connect to X server
    xinit: No such process (errno 3): Server error.
    Couldnt get a file descriptor referring to the console"
  2. Dei permissoes para os arquivos de log e o erro trocou para este, só que não faço nem idéia de como achar o arquivo de config disso!
    se alguem souber...
    Agradeço desde já!
    $ startx
    XFree86 Version 4.3.0 (Red Hat Linux release: 4.3.0-2)
    Release Date: 27 February 2003
    X Protocol Version 11, Revision 0, Release 6.6
    Build Operating System: Linux 2.4.20-3bigmem i686 [ELF]
    Build Date: 27 February 2003
    Build Host: porky.devel.redhat.com
    Before reporting problems, check http://www.XFree86.Org/
    to make sure that you have the latest version.
    Module Loader present
    OS Kernel: Linux version 2.4.20-8 (bhcompile@stripples.devel.redhat.com) (gcc version 3.2.2 20030222 (Red Hat Linux 3.2.2-5)) #1 Thu Mar 13 16:42:56 EST 2003
    Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    (==) Log file: "/var/log/XFree86.0.log", Time: Thu Sep 4 17:41:40 2003
    (==) Using config file: "/etc/X11/XF86Config"
    Fatal server error:
    xf86OpenConsole: Server must be suid root
    This can be found in the log file "/var/log/XFree86.0.log".
    XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0"
    after 0 requests (0 known processed) with 0 events remaining.
  1. O site do ig.com.br não consigo abrir
    Por ccbsumare no fórum Redes
    Respostas: 5
    Último Post: 09-06-2014, 09:23
  2. nao consigo abrir o kernel..
    Por Danilo_Montagna no fórum Servidores de Rede
    Respostas: 14
    Último Post: 06-03-2003, 20:29
  3. Não consigo fazer redirecionamento com iptables
    Por Ganymede no fórum Servidores de Rede
    Respostas: 7
    Último Post: 20-01-2003, 16:47
  4. não consigo abrir me ajudem III
    Último Post: 07-01-2003, 19:33
  5. Não consigo abrir esta planilha me ajudem
    Último Post: 07-01-2003, 16:01
