- cyclades pathtouter snmp
alguem sabe me dizer como eu configuro o snmp no pathrouter para gerar o grafico pelo mrtg ?
SNMP no PathRouter
Serve um passo-a-passo:
Cyclades-PathRouter (NOMEdoROTEADOR) Management Menu
1-Statistics 2-Router Description 3-List Routing Table
4-HW Management 5-HW Setup Configuration 6-Event Logs
7-Filter 8-Frame Relay Map 9-Upgrade
10-ARP Cache 11-Configure Syslog 12-Configure DNS
13-TFTP Configuration 14-Static Routes 15-Configure NAT
16-DHCP Relay Agent 17-SNMP Management
Select option ==> 17
Cyclades-PathRouter (NOMEdoROTEADOR) SNMP - General Management Menu
1-Community Table 2-Host Table 3-Traps
Select option ==> 1
Cyclades-PathRouter (NOMEdoROTEADOR) SNMP Community Table Menu
1-List 2-Maintenance
Select option ==> 1
Community name Status Type
public Enabled read
Type <enter> to return
Select option ==> 2
Cyclades-PathRouter (NOMEdoROTEADOR) SNMP Host Table Menu
Select option ==> 11
Host IP Mask
ENDERECOipAUTORIZADOaCOLETARosDADOS MASCARAdesteENDERECOip
Select option ==> 2
Select option ==> 2
Cyclades-PathRouter (NOMEdoROTEADOR) Host Maintenance Menu
1-Insert 2-Delete 3-Clear All
Select option ==> 1
(...) é agora que se insere aquele endereço IP mostrado acima.
